    PS4/DS4 controller battery check?
    ds4 bluetoothds4controllerbattery
    6 Posts 5 Posters 5.3k Views
      Panja
      I searched the forum but I can only find a script for checking the battery for a wireless PS3 controller/six axes. But I'm rocking 2 DS4 controllers through bluetooth and it would be very handy to have an indicator or even a script to give me some indication of the battery percentage of my connected controllers.
      Is there anything out there that does the job?
        mitu Global Moderator @Panja
        Seems the battery level is readable via sysfs - https://wiki.gentoo.org/wiki/Sony_DualShock#Battery_charge_level
          Panja
          Yes, I noticed.
          cat /sys/class/power_supply/*/capacity will give you all the controller percentages.
          Though I'm not that skilled enough to create a RetroPie menu item for this.
          • X
            xm41907
            Any update to this? I hate not knowing how much battery life is in my controller.
              slutsteg @xm41907
              @xm41907
              This Woolf be amazing
              • roslofR
                roslof
                Seems pretty straightforward to run a script from EmulationStation. Proof of concept, here is a crude 10-minute version I made using Hursty's "Bluray" theme. It already contains a "Power" system, so I just added a small script, uploaded a small .png of the DualShock controller and edited the gamelist.xml file.
                MAIN MENU (from Hursty):
                SELECTION:
                OUTPUT W/Pause (currently requires a keystroke instead of a button-press, but can modify this):
                The simple script:
                #!/bin/bash
                clear
                echo PS4 Dual-Shock Battery Level:
                echo
                read -p "Press Enter to continue"
                Be sure that the script is set as executable.
                Lastly, the es_settings.cfg entry for the "Power" menu item to appear:
                <system>
                   <name>power</name>
                   <fullname>Power Menu</fullname>
                   <path>/home/pi/RetroPie/roms/power</path>
                   <extension>.sh .SH</extension>
                   <command>%ROM%</command>
                   <platform>linux</platform>
                   <theme>power</theme>
                 </system>
                Ideally, the output would be prettier and require a DualShock button to be pressed instead of the keyboard Enter key, but this will certainly work.
