    Auto USB copy, how does it work? [solved]
    usbsdcardudevscript
    3 Posts 2 Posters 523 Views
    • muldjordM
      muldjord
      So I've been trying to figure out how the RetroPie USB-to-SD autocopy works. The functionality that takes any roms in retropie/roms from the USB stick and copies them to the appropriate folders on the SD card. I would have guessed it to be executed by some udev rule, but I can't for the life of me find any that seems to initiate any such thing.
      Does it run a script? What initiates this? Where are the relevant files located?
      Any help on the technical aspect of this would be appreciated. Thanks!
        mitu Global Moderator @muldjord
        @muldjord Hello there ! It's not using udev, but a special service - usbmount - which drops some files to be executed in /etc/usbmount/mount.d when a new mount-able device appears.
        • muldjordM
          muldjord
          Thanks @mitu, that'll get me started :D
