    add custom system logo help
    custommamesystem
    4 Posts 3 Posters 650 Views
    • I
      ian02293
      i edited the es_systems.cfg file and added
      <system>
          <name>fighting</name>
          <fullname>street fighter collection</fullname>
          <path>/home/pi/RetroPie/roms/nes</path>
          <extension>.nes .zip .NES .ZIP</extension>
          <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ nes %ROM%</command>
          <platform>fighting</platform>
          <theme>mame</theme>
      </system>
      currently ignore this line in the code above
      am only trying to get the logo to show up,i added few roms and the logo shows up as mame logo with the roms i added inside of the folder.
      i added fighting folder in /etc/emulationstation/themes/ with the custom png and inc folder
      mituM EfriimE 2 Replies Last reply Reply Quote 0
        mitu Global Moderator @ian02293
        @ian02293 Try replacing
        <theme>mame</theme>
        with
        <theme>fighting</theme>
        • EfriimE
          Efriim @ian02293
          @ian02293
          You must use a theme as a base, different themes have different layouts. You could either study the .xml of the themes or try replacing some of the assets for one of the systems you don't use.
          <theme>virtualboy</theme>
          change this to the name of the themes system subfolder that you either replace or add.
          Hope that helps, the hard part is in the different unknown theme layouts
          • I
            ian02293
            i will try adding <theme>fighting</theme> hope this works.
            currently the home theme is set to carbon so do i change anything in emulationstation\themes\Carbon\theme name\FILENAME.svg.
