    overscan_ NOT WORK AFTER UPDATE! 4.5 in EmulationStation.
    4.5updateoverscan
    33 Posts 5 Posters 5.5k Views
      mitu Global Moderator @matchaman
      @matchaman Are you also using a TV through HDMI ? Do you have explicit overscan_left/right/etc. settings in the config file.
      For the ones using a TV, can you try commenting/removing any overscan settings and leave just
      disable_overscan=1
      If this will behave like in @saccublenda's case, the console output would fill the screen, but Emulationstation would be off. Try using the TV settings and put the HDMI connecting into Game mode (or PC mode, I know my TV has a PC label for the HDMI connection which changes the output settings) or set it to stretch the image (fit-to-screen ?).
      EDIT: I assume you already have overscan_scale=1 in your config (which worked before 4.5).
      saccublendaS 1 Reply Last reply Reply Quote 0
      • saccublendaS
        saccublenda @mitu
        @mitu said in overscan_ NOT WORK AFTER UPDATE! 4.5 in EmulationStation.:
        I do.
          A Former User
          I have problem with overscan settings too, but only, when i am in the terminal or during boot. In ES everything is fine.
          I'm using the following settings in rasbian stretch/buster, retropie 4.4 without overscan problems:
           .***.     Friday,  5 July 2019, 08:44:51 PM
               *****     Linux 4.19.50-v7+ armv7l GNU/Linux
                |*|      Filesystem      Size  Used Avail Use% Mounted on
                |*|      /dev/root       6.7G  2.6G  3.8G  40% /
              ..|*|..    Uptime.............: 0 days, 00h00m40s
            .*** * ***.  Memory.............: 630396kB (Free) / 765608kB (Total)
            *******@@**  Running Processes..: 118
            `*****@@**'  IP Address.........: 192.168.1.2
             `*******'   Temperature........: CPU: 53°C/127°F GPU: 54°C/129°F
               `"""'     The RetroPie Project, https://retropie.org.uk
          pi@retropie:~ $ sudo nano /boot/config.txt
            GNU nano 2.7.4                File: /boot/config.txt
          # http://rpf.io/configtxt
          #hdmi_safe=1
          #disable_overscan=1
          overscan_left=-33
          overscan_right=-33
          overscan_top=-18
          overscan_bottom=-18
          results from fbset:
          mode "1250x660"
              geometry 1250 660 1250 660 32
              timings 0 0 0 0 0 0 0
              rgba 8/16,8/8,8/0,8/24
          endmode
          • saccublendaS
            saccublenda @A Former User
            @alphag Same here. Either I can make ES fit the screen or console/splashscreen, but not both. I was able to have both fit the screen on 4.4.
            • matchamanM
              matchaman
              @mitu yes, I'm experiencing the exact same issue with @saccublenda. I understand what's going on but I assume it should be fixed, it shouldn't be like that...
              • saccublendaS
                saccublenda
                As a check I downgraded the kernel as explained here and now the overscan settings apply both to ES and console, so they can now both fit the screen.
                I think it is then a problem with the new kernel.
                matchamanM 1 Reply Last reply Reply Quote 2
                • saccublendaS
                  saccublenda
                  Maybe everyone already knows that, but I've found out that disable_overscan=1 does not actually disable overscan (so ignoring the overscan settings), but instead disables some "default" overscan settings. In fact, with
                  #disable_overscan=1
                  #overscan_left=0
                  #overscan_right=0
                  #overscan_top=0
                  #overscan_bottom=0
                  I get from fbset
                  mode "1824x984"
                      geometry 1824 984 1824 984 32
                  endmode
                  meaning that without disable_overscan=1 I get a "default" border of 48 on top, bottom, left and right (my display size is 1920x1080). Any additional overscan border explicitly set in /boot/config.txt would add to this default values, in fact with
                  #disable_overscan=1
                  overscan_left=10
                  overscan_right=10
                  overscan_top=10
                  overscan_bottom=10
                  I get
                  mode "1804x964"
                      geometry 1804 964 1804 964 32
                  endmode
                  Instead with
                  disable_overscan=1
                  overscan_left=10
                  overscan_right=10
                  overscan_top=10
                  overscan_bottom=10
                  I get
                  mode "1900x1060"
                      geometry 1900 1060 1900 1060 32
                  endmode
                    SergioPoverony
                    @mitu need add this in isssue on github
                    mituM 1 Reply Last reply Reply Quote 1
                    • matchamanM
                      matchaman @saccublenda
                      @saccublenda said in overscan_ NOT WORK AFTER UPDATE! 4.5 in EmulationStation.:
                      I thin it is then a problem with the new kernel.
                      Same here. I'll wait for a while till I upgrade again.
                        mitu Global Moderator @SergioPoverony
                        @SergioPoverony Feel free to add it - github.com/raspberrypi/linux.
                          SergioPoverony @mitu
                          @mitu more rules. i bad understand
                            This post is deleted!
                            • saccublendaS
                              saccublenda
                              After downgrading the kernel to 1.20190401-1, I tried to run RetroPie-Setup which upgraded the kernel to 1.20190517-1. Now the overscan settings still apply to both console and ES. I don't know if this is because of the downgrade-upgrade procedure, or because of the changes I made to /boot/config.txt. Anyway I paste here the relevant settings I have in the file:
                              disable_overscan=1
                              overscan_left=20
                              overscan_right=20
                              overscan_top=11
                              overscan_bottom=11
                              overscan_scale=1
