    Weird sound issue
    retropie soundconfigs
    6 Posts 2 Posters 659 Views
      RpiBeginner
      Hi guys. I'm running Retropie 4.5.1 and for some reason I dont get sound through hdmi. I'm getting the error:
      failed to attach to default card and that is stopping me from playing most games.
      What I've tried:
      • Edit Config.txt to ensure that the line "dtparam=audio=on" was present. And it is
      -Edit retroarch.cfg and changed:
      audio_driver =
      audio_device =
      so it is:
      audio_driver = "ALSA"
      audio_device = "sysdefault:CARD=ALSA"
      I've also added the hdmi force lines as well.
      Lastly, I've tried with a completely different sound source (3.5mm jack) which does not work either.
      What can it be ?
        Are you sure it's not just the volume that's really low and you need to turn it up ? The retroarch.cfg lines are not necessary - just make sure HDMI is selected as audio (use the Audio entry in RetroPie to choose it) and use alsamixer to raise up the volume.
          RpiBeginner @mitu
          @mitu See that's also part of the problem.. When I press start and Sound settings, the volume is at 0% and everytime I turn it up, it is not saved, but goes back to 0%.. In Audio settings though, using the aslamixer, its on 58%. I have chosen HDMI with no result whatsoever.
            mitu Global Moderator @RpiBeginner
            @RpiBeginner The sound settings in Emulationstation do not affect RetroArch. You probably need to change Audio Device to PCM and you'll have the same sound level as in alsamixer.
            I was referring to the Audio settings entry in the RetroPie system - where you can choose the output (HDMI/Analog/Both).
              RpiBeginner @mitu
              I was also referring to the audio settings in the retropie system.. I was saying that I have looked both places,
              How would it matter if I change the volume in retropie system settings to the same as the alsa mixer? When I just told you it does not save the option? Anyway I did what you suggested and it did not do anything.
                RpiBeginner
                Okay so I ended up reflashing the sd card and start from scratch, which helped.
