    USB sound hiss
    usbsoundhiss
    8 Posts 3 Posters 296 Views
      RpiBeginner
      Hi guys, I just got my
      VENTION 3.5mm External USB Sound Card, in order to increase the audio quality (instead of using 3.5 jack) and to get rid of the annoying hissing sound. I seem to notice the increase in quality, but I still hear the hissing sound. What can I do? And have anyone else experienced similar problems
      • lostlessL
        lostless @RpiBeginner
        @RpiBeginner could be a bad USB sound card or a noisy amp in your speaker system
          RpiBeginner
          This particular sound card was recommended by another user, who has the same sound card and amp, so it shouldn't be as simple as that.
            Clyde @RpiBeginner
            @RpiBeginner Can you test the usb card and the amplifier with other devices to rule out that one of them is responsible? Even if these models are recommended, yours could be defective.
              RpiBeginner
              Yes I tested it with my pc, and the hiss is still there
                Clyde @RpiBeginner
                @RpiBeginner Excuse me, do you mean that the hiss was or wasn't there on your PC, too?
                  RpiBeginner
                  Like I said, I tested it on my pc, and the hiss = still there.. So yes the hiss is (not was) still there
                    Clyde @RpiBeginner
                    @RpiBeginner Thank you. English isn't my native language and I wasn't sure if you meant "[A while ago] I tested it with my pc [and there was no hiss], and [now on the Raspberry Pi] the hiss is still there". :)
                    So it may very well be that the usb card is faulty or just not very good.
