    Timeline for Retropie on Raspberry 4
    raspberry pi 4release datetime
    35 Posts 19 Posters 7.5k Views
    • roslofR
      roslof @Swampy
      @Swampy,
      As of today, the Apple II emulator (linapple) compiles without issue. It does run in a 1:1 pixel ratio in the upper-left of an HD screen. You'll likely want to edit the configuration file (linapple.conf) and tweak the "Screen factor" setting in order to make the window large enough to be enjoyable. I'm currently using a value of 2.5 and it looks just fine.
      • Mosaad-20M
        Mosaad-20
        are there any updates for supporting raspberry pi 4 and what is the the supported emulators?
        because I am planning to buy raspberry pi 4 but I am waiting for the image to release.
        mituM M 2 Replies Last reply Reply Quote 2
        • F
          ferhound
          It will never be released ok? stop asking.
            mitu Global Moderator @Mosaad-20
            @Mosaad-20 You can try the manual installation method - https://retropie.org.uk/docs/Manual-Installation/ - on a Pi4 mode. Work on the PI4 support is still ongoing, but most things should work.
              mth75 @tobias.haecker
              @tobias-haecker said in Timeline for Retropie on Raspberry 4:
              Hello everybody,
              is there an estimated timeline for the release of an Retropie version for Raspberry 4?
              Thank you very much for your answer.
              Tobi
              see answer below.
                mth75 @Mosaad-20
                @Mosaad-20 said in Timeline for Retropie on Raspberry 4:
                Just install the weekly build:
                https://files.retropie.org.uk/images/weekly/
                Everything works.
                After installing keep your install up to date by frequently upgrading the RetroPie-Setup scripts, Buster and the firmware:
                sudo apt-get update
                sudo apt-get upgrade
                sudo rpi-update (beware, only in case you experience problems or are asked by the devs' this is the bleeding edge firmware)
                That's it. I'm running a nice install since February.
                • N
                  notthesame
                  if we charged a penny for everytime for retropie, retropie devs would get rich, it will be done when its done, for now just go ahead and keep that smile and continue to wait in line for it :)
                    mth75 @notthesame
                    @notthesame The point is, one can use Retropie for RPI4. You don't have to wait.
                    • quicksilverQ
                      quicksilver @mth75
                      @mth75 said in Timeline for Retropie on Raspberry 4:
                      sudo apt-get update
                      sudo rpi-update
                      This is not the correct way. The first two lines will update your pi with the latest release firmware and packages. The third line (sudo rpi-update) will install bleeding edge firmware and quite possibly could introduce bugs and cause your pi not to boot. You should never use rpi-update unless instructed to do so by a rpi Dev. It warns you of this each time you attempt a rpi-update though most people it seems ignore this warning.
                        mth75 @quicksilver
                        @quicksilver said in Timeline for Retropie on Raspberry 4:
                        sudo apt-get update
                        sudo rpi-update
                        Yes, I know, I like my bleeding edge firmware.
                        quicksilverQ 1 Reply Last reply Reply Quote 1
                        • quicksilverQ
                          quicksilver @mth75
                          @mth75 if you like bleeding edge that's fine, Im not telling you what to do. I'm more worried about the users that don't understand the risks and follow your advice.
                            mth75 @quicksilver
                            You're right, I edited my original post.
                              AZBuckeye46
                              I installed Raspbian Lite then followed the instructions on the Manual Installation Page, https://retropie.org.uk/docs/Manual-Installation/ and it installed and plays quite well. No issues on my RPi4. Did NES, GB, GBC, SNES, and Sega to test it all out.
                                mth75 @AZBuckeye46
                                @AZBuckeye46 Lovely feeling eh!
                                  StigNasty @bombshelboy
                                  @bombshelboy I have an rPi 4, and it works just fine. You just have to install it yourself.
