Problem getting games to work in newly created custom system in ES
I'm on a Rpi3B+ RetroPie 4.4, using ES and Carbon theme. I'm trying to create Capcom Play System as a separate system. I followed the instructions here: https://retropie.org.uk/docs/Add-a-New-System-in-EmulationStation/ . I'm using the fba system as a template. I used a Windows batch file I found to separate the CPS games from a confirmed working .43 FBA romset. I currently have about 70 roms in the new CPS system. The games I tested works just fine on the same setup from the FBA system but not when trying to start them from the CPS system. The runcommand log suggests it doesn't find some ROMs but I don't understand what the problem is. Could someone check my runcommand log? Thank you.
--- start of joystick-selection log joystick selection by name is ON! joystick indexes for "all" was configured --- end of joystick-selection log Parameters: Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fbalpha/fbalpha_libretro.so --config /opt/retropie/configs/fba/retroarch.cfg "/home/pi/RetroPie/roms/cps/ghoulsu.zip" --verbose --appendconfig /dev/shm/retroarch.cfg [INFO] RetroArch 1.7.1 (Git 6fc6bfb) [INFO] Redirecting save file to "/home/pi/RetroPie/roms/cps/ghoulsu.srm". [INFO] Redirecting savestate to "/home/pi/RetroPie/roms/cps/ghoulsu.state". [INFO] === Build ======================================= Capabilities: NEON VFPv3 VFPv4 Built: Mar 19 2018 [INFO] Version: 1.7.1 [INFO] Git: 6fc6bfb [INFO] ================================================= [INFO] [Config]: loading config from: /opt/retropie/configs/fba/retroarch.cfg. [INFO] Config: appending config "/dev/shm/retroarch.cfg" [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-fbalpha/fbalpha_libretro.so" [INFO] [overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/FB Alpha/FB Alpha.cfg. [INFO] [overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/FB Alpha/ghoulsu.cfg. [INFO] Shaders: preset directory: /home/pi/.config/retroarch/shaders/presets [INFO] Shaders: no game-specific preset found at /home/pi/.config/retroarch/shaders/presets/FB Alpha/ghoulsu.cgp. [INFO] Shaders: no game-specific preset found at /home/pi/.config/retroarch/shaders/presets/FB Alpha/ghoulsu.glslp. [INFO] Shaders: no parent-dir-specific preset found at /home/pi/.config/retroarch/shaders/presets/FB Alpha/cps.cgp. [INFO] Shaders: no parent-dir-specific preset found at /home/pi/.config/retroarch/shaders/presets/FB Alpha/cps.glslp. [INFO] Shaders: no core-specific preset found at /home/pi/.config/retroarch/shaders/presets/FB Alpha/FB Alpha.cgp. [INFO] Shaders: no core-specific preset found at /home/pi/.config/retroarch/shaders/presets/FB Alpha/FB Alpha.glslp. [INFO] Remaps: remap directory: /opt/retropie/configs/fba/ [INFO] Remaps: no game-specific remap found at /opt/retropie/configs/fba/FB Alpha/ghoulsu.rmp. [INFO] Remaps: no core-specific remap found at /opt/retropie/configs/fba/FB Alpha/FB Alpha.rmp. [INFO] Redirecting save file to "/home/pi/RetroPie/roms/cps/ghoulsu.srm". [INFO] Redirecting savestate to "/home/pi/RetroPie/roms/cps/ghoulsu.state". [INFO] Environ GET_LOG_INTERFACE. [INFO] Content loading skipped. Implementation will load it on its own. [libretro INFO] Setting save dir to /home/pi/RetroPie/roms/cps/ [INFO] Environ SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS". [libretro INFO] Setting system dir to /home/pi/RetroPie/BIOS [INFO] Environ SET_CONTROLLER_INFO. [INFO] Controller port: 1 [INFO] Classic (ID: 5) [INFO] Modern (ID: 517) [INFO] Controller port: 2 [INFO] Classic (ID: 5) [INFO] Modern (ID: 517) [INFO] Environ SET_VARIABLES. [INFO] Environ GET_VARIABLE fba-cpu-speed-adjust: [INFO] 100 [INFO] Environ GET_VARIABLE fba-aspect: [INFO] DAR [INFO] Environ GET_VARIABLE fba-hiscores: [INFO] enabled [INFO] Environ GET_VARIABLE fba-samplerate: [INFO] 48000 [INFO] Environ GET_VARIABLE fba-sample-interpolation: [INFO] 4-point 3rd order [INFO] Environ GET_VARIABLE fba-fm-interpolation: [INFO] 4-point 3rd order [libretro INFO] [FBA] Archive: ghoulsu [libretro INFO] [FBA] Archive: ghouls [libretro ERROR] [FBA] Failed to find archive: /home/pi/RetroPie/BIOS/ghouls, let's continue with other archives... [libretro INFO] [FBA] Parsing archive /home/pi/RetroPie/roms/cps/ghoulsu. [libretro WARN] [FBA] Searching ROM at index 4 with CRC 0x3ea1b0f2 and name dm-17.7j => Not Found [libretro WARN] [FBA] Searching ROM at index 5 with CRC 0x0ba9c0b0 and name dm-05.3a => Not Found [libretro WARN] [FBA] Searching ROM at index 6 with CRC 0x5d760ab9 and name dm-07.3f => Not Found [libretro WARN] [FBA] Searching ROM at index 7 with CRC 0x4ba90b59 and name dm-06.3c => Not Found [libretro WARN] [FBA] Searching ROM at index 8 with CRC 0x4bdee9de and name dm-08.3g => Not Found [libretro WARN] [FBA] Searching ROM at index 9 with CRC 0xae24bb19 and name 09.4a => Not Found [libretro WARN] [FBA] Searching ROM at index 10 with CRC 0xd34e271a and name 18.7a => Not Found [libretro WARN] [FBA] Searching ROM at index 11 with CRC 0x3f70dd37 and name 13.4e => Not Found [libretro WARN] [FBA] Searching ROM at index 12 with CRC 0x7e69e2e6 and name 22.7e => Not Found [libretro WARN] [FBA] Searching ROM at index 13 with CRC 0x37c9b6c6 and name 11.4c => Not Found [libretro WARN] [FBA] Searching ROM at index 14 with CRC 0x2f1345b4 and name 20.7c => Not Found [libretro WARN] [FBA] Searching ROM at index 15 with CRC 0x3c2a212a and name 15.4g => Not Found [libretro WARN] [FBA] Searching ROM at index 16 with CRC 0x889aac05 and name 24.7g => Not Found [libretro WARN] [FBA] Searching ROM at index 17 with CRC 0xbcc0f28c and name 10.4b => Not Found [libretro WARN] [FBA] Searching ROM at index 18 with CRC 0x2a40166a and name 19.7b => Not Found [libretro WARN] [FBA] Searching ROM at index 19 with CRC 0x20f85c03 and name 14.4f => Not Found [libretro WARN] [FBA] Searching ROM at index 20 with CRC 0x8426144b and name 23.7f => Not Found [libretro WARN] [FBA] Searching ROM at index 21 with CRC 0xda088d61 and name 12.4d => Not Found [libretro WARN] [FBA] Searching ROM at index 22 with CRC 0x17e11df0 and name 21.7d => Not Found [libretro WARN] [FBA] Searching ROM at index 23 with CRC 0xf187ba1c and name 16.4h => Not Found [libretro WARN] [FBA] Searching ROM at index 24 with CRC 0x29f79c78 and name 25.7h => Not Found [libretro WARN] [FBA] Searching ROM at index 25 with CRC 0x3692f6e5 and name 26.10a => Not Found [libretro WARN] [FBA] Searching ROM at index 26 with CRC 0xeb122de7 and name buf1 => Not Found [libretro WARN] [FBA] Searching ROM at index 27 with CRC 0x59c7ee3b and name ioa1 => Not Found [libretro WARN] [FBA] Searching ROM at index 28 with CRC 0xf1129744 and name prg1 => Not Found [libretro WARN] [FBA] Searching ROM at index 29 with CRC 0x41dc73b9 and name rom1 => Not Found [libretro WARN] [FBA] Searching ROM at index 30 with CRC 0x84f4b2fe and name sou1 => Not Found [libretro WARN] [FBA] Searching ROM at index 31 with CRC 0xf6e5f727 and name dm620.2a => Not Found [libretro WARN] [FBA] Searching ROM at index 32 with CRC 0xad52b90c and name lwio.8i => Not Found [libretro INFO] [FBA] Parsing archive /home/pi/RetroPie/roms/cps/ghoulsu. [libretro WARN] [FBA] Searching ROM at index 4 with CRC 0x3ea1b0f2 and name dm-17.7j => Not Found [libretro WARN] [FBA] Searching ROM at index 5 with CRC 0x0ba9c0b0 and name dm-05.3a => Not Found [libretro WARN] [FBA] Searching ROM at index 6 with CRC 0x5d760ab9 and name dm-07.3f => Not Found [libretro WARN] [FBA] Searching ROM at index 7 with CRC 0x4ba90b59 and name dm-06.3c => Not Found [libretro WARN] [FBA] Searching ROM at index 8 with CRC 0x4bdee9de and name dm-08.3g => Not Found [libretro WARN] [FBA] Searching ROM at index 9 with CRC 0xae24bb19 and name 09.4a => Not Found [libretro WARN] [FBA] Searching ROM at index 10 with CRC 0xd34e271a and name 18.7a => Not Found [libretro WARN] [FBA] Searching ROM at index 11 with CRC 0x3f70dd37 and name 13.4e => Not Found [libretro WARN] [FBA] Searching ROM at index 12 with CRC 0x7e69e2e6 and name 22.7e => Not Found [libretro WARN] [FBA] Searching ROM at index 13 with CRC 0x37c9b6c6 and name 11.4c => Not Found [libretro WARN] [FBA] Searching ROM at index 14 with CRC 0x2f1345b4 and name 20.7c => Not Found [libretro WARN] [FBA] Searching ROM at index 15 with CRC 0x3c2a212a and name 15.4g => Not Found [libretro WARN] [FBA] Searching ROM at index 16 with CRC 0x889aac05 and name 24.7g => Not Found [libretro WARN] [FBA] Searching ROM at index 17 with CRC 0xbcc0f28c and name 10.4b => Not Found [libretro WARN] [FBA] Searching ROM at index 18 with CRC 0x2a40166a and name 19.7b => Not Found [libretro WARN] [FBA] Searching ROM at index 19 with CRC 0x20f85c03 and name 14.4f => Not Found [libretro WARN] [FBA] Searching ROM at index 20 with CRC 0x8426144b and name 23.7f => Not Found [libretro WARN] [FBA] Searching ROM at index 21 with CRC 0xda088d61 and name 12.4d => Not Found [libretro WARN] [FBA] Searching ROM at index 22 with CRC 0x17e11df0 and name 21.7d => Not Found [libretro WARN] [FBA] Searching ROM at index 23 with CRC 0xf187ba1c and name 16.4h => Not Found [libretro WARN] [FBA] Searching ROM at index 24 with CRC 0x29f79c78 and name 25.7h => Not Found [libretro WARN] [FBA] Searching ROM at index 25 with CRC 0x3692f6e5 and name 26.10a => Not Found [libretro WARN] [FBA] Searching ROM at index 26 with CRC 0xeb122de7 and name buf1 => Not Found [libretro WARN] [FBA] Searching ROM at index 27 with CRC 0x59c7ee3b and name ioa1 => Not Found [libretro WARN] [FBA] Searching ROM at index 28 with CRC 0xf1129744 and name prg1 => Not Found [libretro WARN] [FBA] Searching ROM at index 29 with CRC 0x41dc73b9 and name rom1 => Not Found [libretro WARN] [FBA] Searching ROM at index 30 with CRC 0x84f4b2fe and name sou1 => Not Found [libretro WARN] [FBA] Searching ROM at index 31 with CRC 0xf6e5f727 and name dm620.2a => Not Found [libretro WARN] [FBA] Searching ROM at index 32 with CRC 0xad52b90c and name lwio.8i => Not Found [libretro ERROR] [FBA] ROM at index 4 with CRC 0x3ea1b0f2 is required ... [libretro ERROR] [FBA] Cannot find driver. [libretro ERROR] [FBA] Cannot load this game. [ERROR] Failed to load content. [INFO] Saved core options file to "/opt/retropie/configs/all/retroarch-core-options.cfg" [ERROR] This core requires a content file, could not load content.
The logs shows you the problem - you're missing the parent ROM (
ghouls
) and FBAlpha cannot find it in either the BIOS dir or the ROM dir..... [libretro INFO] [FBA] Archive: ghoulsu [libretro INFO] [FBA] Archive: ghouls ....
@mitu Thanks. I guessed as much. The Windows batch file I used was found here: https://www.reddit.com/r/RetroPie/comments/73g1bg/how_separate_neogeo_from_other_fba_roms/ Other users seemed to be happy with the output of the batchfiles, but they are likely on some other os.. I’m having a hard time filtering the FBA romset. Any suggestions on how to proceed with getting CPS only? You mention bios, how do I know if it’s the roms or a bios mmissing? I have Clrmamepro (and have managed to filter the home console sets) but cannot find documentation on how to filter the FBA set, that’s why I used the batchfile.
@m2306 You need to use a Non-merged ROM set, so that each ROM is 'standalone' (well, except the BIOS files, but for arcade ROMs they are just a few) and it doesn't need the parent ROM to run - see https://retropie.org.uk/docs/Validating,-Rebuilding,-and-Filtering-ROM-Collections/
made 4 tools
1: Rom tester, test all runs on autopilot its 100% accurate, then all roms testers.checks roms using retroarch.exe if rom is bad, then sending it to bad folder for later test and send good roms to fixed folder.this way you know that all roms you have are working not like most testers I have used 1 or 2 or more be broken very disappointing results. -
If you want advice do this, install retroarch and emulationstation on windows.
test all roms before you work on raspberrypie. -
@mitu Thank you. I had read that guide several times. I can’t believe I overlooked that. I rebuilt a full non merged set with clrmamepro and then used the same batchfile I mentioned earlier. Now it works.
