Retropie Not Recognizing my SNES30 Pro+ Controllers
Raspberry PI 3B
v4.5.1 (Just updated through the system menu to whatever the current is if not 4.5.1)
Raspberry Pi Official AC Adapter
400GB Sandisc Card
2 SNES30 PRO+ Controllers (USB C)
1 SNES30 Controller (USB Micro)I recently bought two SNES30 PRO+ Controllers because they looked like the perfect retro controller, and by all accounts and reviews, I heard they are.
(Controller seen here https://www.amazon.com/8Bitdo-Sn30-Pro-Bluetooth-Gamepad-Sn/dp/B07T8JKVNT/ref=sr_1_3?keywords=snes30+pro%2B&qid=1569019522&sr=8-3 )I plugged them in via USB, just like I do my SNES30 controller, and while it system says it recognizes the 2 controllers, I cannot configure them. When I go to set the buttons, I hold down A or any other button and the input is never detected.
I don't use Blutooth with these devices, and they work fine over USB for PC, so I am curious if the drivers are missing, or did I screw something up?
(The controller may need an update, that HAS happened before)
@Jiryn Does the pair/usable mode have to be selected for usb? I have not tried through USB yet as my Pi is always too far away. I have the SN30 Pro i use over bluetooth (with ghost inputs in ES on a 3B+).
@KN4THX
Might have something to do with the "Modes" the website talks about,
I've been using the controllers for my Switch, but it seems i have to set it for different game play modes/settings.I am guessing Windows mode is what I should use?
(It has 4 modes, Switch, Android, Windows, and Mac)(Off topic, I am horrible at pairing Blutooth equipment with the Pi/Blue Config screen, it detects the controllers but every config fails)
@KN4THX Found the problem!
You have to switch modes while NOT connected via USB.
The mode cannot be switched while plugged in! -
@Jiryn For the Pi it is the Switch Mode.
Start + Y
. I tried using a different mode today to improve the ghost input situation but then some buttons are not detected. I know on my debian laptop I have to use another mode which is strange because they are both linux. Again, all of my experience is with bluetooth. I have been curious to see if the mode matters in USB. -
@Jiryn Glad you got it figured out and even beat my slow typing :) I wasn't sure about that but now I know!
@KN4THX
I got both Android and Microsoft mode detected when wired.
Android detects as a PS Controller
Microsoft as a 360 controller
it does NOT like Switch ModeOdd question, my Retropie's sound for PS1 games are really, really low and not sure why.
