    FBA input 1 control both coins
    controlsretroarch fba ccoins
    3 Posts 2 Posters 400 Views
      MISTERHOLLYW00D
      Anyway for FBA to have input 1 control coin and start for player 2?
      Or a way to use input 1 hotkey to activate player 2 button as exit?
        MISTERHOLLYW00D
        I’m trying to make player 1 start and player 2 start to exit game but I don’t think this is possible.
        Is there a way to make either the hotkey or the exit key to only activate when it’s held down for a couple seconds instead of just pressing?
        • IanDaemonI
          IanDaemon
          Check the dip switches. You may be able to control the coin chutes. That's something I've seen often in the test/mame menu. This solution would be per ROM though, not per core.
          • Cocktail Cabinet Games
          • Check out the MAME RoW
