    Solution for " White Screen of Death "
    145 Posts 20 Posters 92.9k Views
      MWGemini @fieldofcows
      @fieldofcows I'm currently using a modified version of the tronkyfran theme, with 18 systems on the main carousel, and videos in one of the systems. At version 2.1.0RP of ES, I did not have a WSOD issue (with an increase memory split of 384- default mem split did cause WSOD). With the latest update (2.1.2RP), I'm getting partial white screens on several systems.
      fieldofcowsF 1 Reply Last reply Reply Quote 1
      • mattrixkM
        mattrixk @fieldofcows
        @fieldofcows I know lots of people complained about the original "Simple" theme, but I haven't tried it myself (by the time I came along, Carbon was the default for RetroPie on the Raspberry Pi).
        • fieldofcowsF
          fieldofcows @MWGemini
          @MWGemini That's a big theme! I've just tried it with 62 systems if I counted that correctly on my RPi3. I haven't changed the memory split - everything is in it's default configuration. It works!
          A couple of the backgrounds are rendered a bit blurred. I'm not sure if that's my change or something else but I'll investigate.
          The other issue is that my caching will consume a fair amount of RAM. I'm not sure if that is going to cause any problems.
          M herb_fargusH 2 Replies Last reply Reply Quote 0
          • fieldofcowsF
            fieldofcows
            Commit is here if anybody fancies reviewing the code:
            https://github.com/fieldofcows/EmulationStation/commit/b4ad5eeda104b166667b8d4bc5262c925f6f86a3
              @fieldofcows 62 systems without a WSOD? Wow! As for blurred backgrounds, I know that at least a few are blurred on mine. Off the top of my head, Sega 32x and Sega CD are both blurred game images, and PC is a slightly blurred PC image. All of the other systems I have in my collection have pretty crisp backgrounds.
              With regards to the caching, will that be cleared or garbage collected when a game is launched? If not, I can try to pull down your changes and run a few of the more demanding games in my collection and see if I notice any significant performance changes. I'm guessing that PSX, N64 and Dreamcast will be the heaviest, but I don't have any sort of memory profiling system set up currently, so the best I can do is provide anecdotal evidence.
              dankcushionsD 1 Reply Last reply Reply Quote 1
              • herb_fargusH
                herb_fargus administrators @fieldofcows
                @fieldofcows if you're talking about some blurred images on the tronkyfran theme, some I think were reduced to 720p which may have cause some blur on downscaling perhaps, also the default simple images were left for systems tronkyfran didn't create a wallpaper for. might have to check against other images you know are full HD just to see if it's reproducible but I'm just guessing it's the incompleteness of the theme
                  dankcushions Global Moderator @MWGemini
                  @MWGemini said in Solution for " White Screen of Death ":
                  i second this question. if it remains in system memory, if i use a lite theme (pixel) i'd personally want it to use my VRAM over my system ram. VRAM is barely used in retropie outside of emulationstation, but system ram can be used a lot in mame games with large samples, or system compilation.
                  fieldofcowsF 1 Reply Last reply Reply Quote 0
                  • fieldofcowsF
                    fieldofcows @dankcushions
                    @dankcushions, @MWGemini
                    Yes, I too am concerned about memory usage in this situation so I'm looking at ways to mitigate this. There are two things I plan on looking at:
                    1. Compressing the images when stored in RAM
                    2. Freeing RAM for unused textures and reloading from disk where necessary
                    Compression is easy and will save a large amount of space on most themes. For example, the zoid theme is 36Mb on disk but takes >350Mb of texture memory when it is uncompressed. I'm not sure how much of a delay this will cause on the pi when decompressing just in time for rendering.
                    The second option may cause significant delay problems due to the speed of SD card storage.
                    Also, I may try to implement a priority cache where we can set a maximum VRAM usage and purge only the oldest entries to free room for new textures - this in conjunction with 1) or 2) above should hopefully sort us out.
                    Anyway, I'll try both these and see what happens.
                      KillerQ
                      Nice work.
                      I released a bandaid for this as well that involved a nice picture resizing algorithm that reduced picture sizes without a notcible difference - but your solution seems more appropriate.
                      The TronkyFran theme is the best to test with this since the images are so crisp, any resolution is immediately noticible.
                      Also, a few of the screens on the tronky theme revert to manually blurred images. Ignore those, and just focus on the system console photos.
                      Email me at mattborkin@gmail.com if you need me to test anything out. I've been working on this for weeks.
                      Thanks.
                      • fieldofcowsF
                        fieldofcows @KillerQ
                        Hi @KillerQ,
                        Yes the tronky theme is definitely the one to test with. The images are huge. They render perfectly with the exception of a few (e.g. Virtual Boy, Wii, WonderSwan/color, Dragon32, etc.) so I think they are just incomplete images in the theme.
                        Thanks for the offer of testing. I'm nearly ready to produce a good version of the fix - just a few things to iron out which I'll detail in a minute. The more testing the better :)
                        • fieldofcowsF
                          fieldofcows
                          Right, so it works. I've tried a couple of things out and it seems that dynamically loading and unloading the images rather than keeping them cached in RAM is the way to go. It does cause a bit of a delay when scrolling the carousel when using very large images (TronkyFran) but for smaller themes it is not noticable.
                          I need to finish a few things off before this is complete:
                          1. Tidy the code - it's still a bit experimental
                          2. Implement a texture cache where you can set a maximum VRAM size and it will only purge the oldest textures when this limit is reached - this should prevent the jerkyness on configurations where the WSOD was not previously happening
                          3. More testing
                          I've added the memory usage to the FPS display and get the following numbers:
                          Zoid Theme:
                          Font VRAM 25.17, Tex VRAM 8.90 Tex RAM: 0.00 Tex Total: 381.20
                          Oldroom (1080p) Theme:
                          Font VRAM 20.97, Tex VRAM 8.51 Tex RAM: 0.00 Tex Total: 157.91
                          TronkyFran Theme:
                          Font VRAM 25.17, Tex VRAM 17.31 Tex RAM: 0.00 Tex Total: 495.21
                          All the above had ~65 configured systems but each theme does not support all of them. An explanation of the fields:
                          Font VRAM: VRAM used in Mb to store font textures
                          Tex VRAM: VRAM in use for images and icons
                          Tex RAM: This is the one that I was using a lot of in my previous version - amount of system RAM used by textures. Now this is generally zero
                          Tex Total: The amount of texture memory that would have been used without my fix in place
                          dankcushionsD M 2 Replies Last reply Reply Quote 5
                            dankcushions Global Moderator @fieldofcows
                            @fieldofcows those are awesome results! what an achievement to quash one of the big ES bugs. sounds like an interesting bit of coding, also!
                            it's times like this that it's a shame that aloshi abandoned (temporarily? forever?) ES. i can imagine a popular project like that quickly becomes overwhelming (as i'm sure retropie can be!), but slowly but surely, people will take up the slack.
                            if it's not a pain, it might be nice to submit the finished PR to the main ES repo also. likely nothing happens, but he might at least see it :)
                              @fieldofcows When you're ready for people to test it, let me know and I can pull your code. With the official upgrade I did a day or two ago, I'm now seeing white screens on several systems, and jerkiness while switching. The one system that I put video previews into also is not displaying correctly, but that might be a theme issue and not a memory issue.
                              I'm impressed by the numbers you've posted! I'm glad it appears this was a relatively easy fix and did not require a total rewrite of the rendering system.
                              • fieldofcowsF
                                fieldofcows
                                Right, it's all done :)
                                I've completed the three tasks I gave myself above, having implemented a cache of active textures, purging the oldest ones to make room for newly loading textures when necessary.
                                I would appreciate some people picking up my experimental build and giving it a good thrashing. Release is here. I've only built it for Raspberry Pi 3 because that's all I've got at the moment. The change also works on Linux and Windows (although I've not yet tested the latter) but is not really necessary.
                                What I've done:
                                I had a bit of a u-turn on my first experiment where I loaded textures into memory then only populated them into VRAM when used as this was consuming a lot of system RAM which could prevent some other things (read emulators) from working.
                                Instead, I experimented with actually purging the texture completely from any memory and reloading from SD card when needed. The Pi performed remarkably well with this although there is some jerkiness. So I implemented a fixed VRAM limit using a LRU. Each time a texture is used it is loaded from the disk (causing a slight delay) but it remains in VRAM until the limit is reached. When this happens the least used texture is purged from VRAM to make space for the new one.
                                This cache is configurable in es_settings.cfg and via the UI in "Other Settings" -> "VRAM LIMIT". The default is 100Mb and I can push my RPi3 to about 120Mb before it starts dropping textures. Note that this limit does not include fonts which load on top of this limit.
                                The beauty of this approach is that for themes that fit nicely within the VRAM limit (basically any theme that does not WSOD on current ES) will not experience any jerkiness at all because no textures will be purged. Larger themes will only experience the jerkiness when shuffling textures in the cache - which I think is a better result than just getting a white screen :)
                                Anyway, please try it out and give feedback. It's all prepared ready to submit as a PR to RetroPie if there are no issues with it.
                                Wow - I write alot don't I?!
                                mattrixkM dankcushionsD 2 Replies Last reply Reply Quote 2
                                • fieldofcowsF
                                  fieldofcows
                                  Oh, I forgot to say. If you turn on the "Show Framerate" option then you get something like this:
                                  Font VRAM: 33.55 Tex VRAM: 120.31 Tex Max: 381.28
                                  This shows the VRAM used by the fonts, the VRAM used by all currently loaded textures (which should not be much greater than the limit you set), then the memory that is required to load all textures without caching. The last value is what would have been loaded in one go in the current ES.
                                    AgentGentner
                                    I had to go into the file manager without allowing ES to load. I went in and uninstalled all themes except Carbon. This allowed me to go back in to ES and do what I needed to do. I eliminated unnecessary consoles (I don't use INFOCOM or SCUMMVM or AppleII). Once I brought it down to <10, I went in and reinstalled Zoid.
                                    • mattrixkM
                                      @fieldofcows said in Solution for " White Screen of Death ":
                                      Wait until you see the design proposal doc I'm putting together in response to your Metadata Improvements in EmulationStation post.
                                      On a serious note, I'm blown away by the work you are doing to improve all parts of ES.
                                      fieldofcowsF M 2 Replies Last reply Reply Quote 1
                                      • fieldofcowsF
                                        fieldofcows @mattrixk
                                        @mattrixk said in Solution for " White Screen of Death ":
                                        Thanks :) I'm really enjoying this. If it wasn't for this forum, and the excellent work done by everyone else I would have lost motivation a long time ago. Now, where can I find more hours in the day...
                                        M mattrixkM 2 Replies Last reply Reply Quote 0
                                          If you figure that one out, please share with the rest of us! :)
                                          Do you happen to have installation steps for your latest patch handy? I'll pull my SD card and make a backup now and can report back after I get your patch up and running.
                                          • mattrixkM
                                            Insomnia?
                                            (please don't)
