    Changing two buttons in the retroarch.cfg will not work
    buttons layout
    7 Posts 2 Posters 514 Views
    • top-specciT
      top-specci
      Hi,
      I try to change two buttons (X with the Y button) in the retroarch.cfg file, but it will not work, the change take not effect.
      I copy the file to Windows, change the enty, copy the file back, restart Emulationstation but still the old layout seems to work.
      I restart whole RaspberryPie, same (no change from the buttons)
      These are the lines, from /opt/retropie/configs/all/retroarch.cfg :
      input_player1_x = "a"
      input_player1_x_axis = "nul"
      input_player1_x_btn = "nul"
      input_player1_x_mbtn = "nul"
      input_player1_y = "s"
      input_player1_y_axis = "nul"
      input_player1_y_btn = "nul"
      input_player1_y_mbtn = "nul"
      Is there a misunderstanding or a mistake from my side,
      I thought Retropie Emulators will take these informations for button layout ...
      I have no Emulator specific key-configs in the subfolders!
      Only standard entries are there, here .i.e. in mame-libretro:
      input_remapping_directory = "/opt/retropie/configs/mame-libretro/"
      # video_smooth = ""
      # video_shader_enable = ""
      input_overlay_enable = "true"
        You're changing the button mapping for a keyboard type input - if you expect that buttons on the gamepad to work differently, then this is why they're not.
        top-specciT 1 Reply Last reply Reply Quote 0
        • top-specciT
          top-specci @mitu
          @mitu Ok, uppps...
          And where can I find the layout configuration file from the phy. buttons I have defined?
          thx!
            If you want to remap the buttons, then use the Core Input Remapping menu in the RGUI - https://retropie.org.uk/docs/RetroArch-Configuration/#core-input-remapping. No need to edit files and re-configure the controllers globally.
            • top-specciT
              top-specci @mitu
              @mitu Ok, I will check this.
              But in my case, I just want to switch 2 Buttons globally, is there no "simple" config file I can edit and change two lines ?
              Same as I reconfigure the joystick new (in principle I want to prevent this step, so my posting here)
                Your gamepad is configured in \\retropie\configs\all\retroarch-joypads, it has its own configuration file. You can change it there, but it's not so straightforward since the mappings are just some numbers.
                EDIT: you get the same result if you re-map your input in Emulationstation.
                • top-specciT
                  top-specci
                  Thanks, this was the file I'm looking for ...
