    Help ! Can’t add anymore psx roms
    issueroms
    28 Posts 7 Posters 1.8k Views
    • nightbirdmediaN
      nightbirdmedia @atomicgarden
      @atomicgarden wow. weird. Can you send us a picture of what you are dealing with?
      Also I recommend installing Easy Hax Toolkit if you don't already have it in your retropie menu. I can walk you through the install if you need help. It has a check Disk Space feature that I use to see how much room I have left on my card. I think it will be just as accurate as what Mitu suggested in Exiting Emulation station. I've never exited the emulation station so I don't know. Lol
      EDIT. (Just checked and yes both numbers are identical). If you exit the Emulation Station you will need a keyboard to type in Reboot or Shutdown to get out of the Command Line.)
      But what I can tell you is be careful when you are in the RPsetup area and installing new things. Avoid trying to hit the back button function (B button) on your controller and manually move over to the selection that says "back" and click on it. You don't know how many times i reinstalled something by accident that I just uninstalled. Haha.
        atomicgarden
        This is how my menu looks like
          atomicgarden
          Can this help ? This is using winSCP to access the files.
          This is from /home/pi/RetroPie/retropiemenu
            That is fine. If you're using WinScp, then find the gamelist.xml file in /home/pi/.emulationstation/gamelists/retropie and see if it's empty.
              atomicgarden @mitu
              Ok, I just looked there. There is a only one file there. It is indeed gamelist.xml, but it is a size of 0kb. Now what do I do ?
                Remove the file, then re-install the retropiemenu package, this should re-generate it with the correct information.
                • nightbirdmediaN
                  @atomicgarden
                  Did you try selecting Detailed instead of Automatic?
                  Follow Mitu's advice and remember to Restart Emulation station after you updated or installed something, especially if the changes don't go into effect which most won't.
                  (Also if you bought a pre-loaded SD Card it may have come with several already installed themes...my newest card came with about 10 themes, most of which I uninstalled) When you hit Start and select UI Settings you may have chosen one of the installed themes instead of the one it came with. Let me know what themes, you have installed. )
                    atomicgarden
                    That did it ! Thanks both of you ! I removed the file, then update retropiemenu in manage package and restart emulationstation. Thanks again !
