    Two gamepads: control scheme not working
    gamepadnumber players
    3 Posts 2 Posters 184 Views
    • V
      v3xX
      Hello everyone,
      I have two gamepads (F360 Logitech and SNES N30). I configured the NES30 first and then the F360. With the 'Joystick selector' plugin I changed the player number so that 1:F360 and 2:N30.
      For some reason not all buttons work on the F360 (Start, Select, Left shoulder, right shoulder), but only correspond when I press it on the N30.
      Even after unplugging the N30 and restarting (hard reset) the above mention buttons are not working. After that I also reconfigured the controls with only the F360 present. Still not working.
      Is the first gamepad registered always the master? How can I change the priority? Are the buttons not equal on every gamepad? Especially crucial ones like START and SELECT?
        Can you add more details about your system and setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first ?
        The order of configuration in Emulationstation doesn't matter for controllers, the same configuration is created for a controller as long as you choose the same mapping.
        Are the buttons for the F360 working in Emulationstation ?
        • V
          v3xX
          In emulationstation everything works normal. So far I tested it with NES, SNES, N64, PSX and AMIGA emulator. The start, select and shoulder buttons only work on the NES30. All other buttons work on both
