    Having an issue with high score saving lr mame 2003 plus
    high scores
    29 Posts 7 Posters 4.8k Views
      grant2258 Banned
      Ill provide instructions for you to compile it im assuming you have a pi3 if not change the platform to rpi2.
      There is things to keep in mind one you should have mame2003-plus installed via retropie so everything is setup. The code below will compile mame for you at the bash prompt via ssh or f4 depending on your preference.
      git clone https://github.com/libretro/mame2003-plus-libretro.git
      cd mame2003-plus-libretro/
      wget https://github.com/libretro/mame2003-plus-libretro/pull/780.patch
      git am 780.patch
      make -j8 platform=rpi3
      copy the binary over that is made over the old one and be sure to delete the source directory when finished.
        mahoneyt944 @grant2258
        @grant2258 thank you.
        • RiverstormR
          Riverstorm
          @mahoneyt944 - Sorry, I see there are a few pull requests pending. =/
          arcadez2003A 1 Reply Last reply Reply Quote 0
          • arcadez2003A
            arcadez2003 @Riverstorm
            @Riverstorm said in Having an issue with high score saving lr mame 2003 plus:
            Yeah when i retired from active dev with regards to the MAME2003+ core i gave up my contributor status and my push and pull access
            when i left the libretro organization, i just wanted to add the code as per a request from @grant2258 as a favour due to him helping
            me out a fair times in that dept.
            So will just need to be patient until such a time as someone does the merge.
            Arcade Addict
            • RiverstormR
              Riverstorm
              @arcadez2003 - That's not an issue at all. I appreciate the past few years of hard work you put into the core and the little things you and grant keep adding. I got so used to the commits being pushed as fast as you and grant were banging them out. I didn't stop to think that it might not be merged when Mahoney had asked. No worries at all! ;)
                grant2258 Banned
                @arcadez2003 this isint quite working it must be shared memory needing mapped for it to work. It only worked because i had a previous nvram there is you delete the old one and create a fresh one it doesnt work will need to look into this driver more.
                  @grant2258 Mine works but already had an old nvram file too.
                    grant2258 Banned
                    Never ind me Its working fine i did a copy and paste error on my port is working fine here. If you have any issues let me know. test if you like move your nvram and try making a new one. Then move your old one back after testing.
                      @grant2258
                        mahoneyt944
                        This post is deleted!
