    No sound using OMXplayer / Arcade Bonnet
    arcade bonnetomxplayerno sound
    5 Posts 2 Posters 957 Views
    • BiZzAr721B
      BiZzAr721
      Hello all. I hope everyone has been staying healthy, and getting buy without too much difficulty. I have been using my "quarantine" time to finish a miniature arcade build I have been working on.
      I am having issues with video snaps. When I enable OMXplayer, I have video and no sound. Sound is working with OMXplayer off. I have tried changing many settings from /etc/.asound.conf, to /usr/share/alsa/alsa.conf
      I had no sound during spash screen but was able to correct that by changing
      omxplayer -o both
      to
      omxplayer -o alsa
      in /opt/retropie/supplementary/splashscreen/asplashscreen.sh as referenced in this post.
      I can play video previews from command line with
      omxplayer -o local /path/to/file/filename.mp4
      When
      <string name="OMXAudioDev" value="alsa:hw:0,0" />
      I do not get a video at all.
      When set to local, I get video, but no sound.
      Note: I have used these same video's with OMXplayer on a pi without a hat attached.
      aplay -L shows
      CARD=sndrpihifiberry,DEV=0
      I am using a Raspberry Pi 3b+, with a Canakit powersupply, ADAfruit Arcade Bonnet, running the latest Retropie image (v 4.5.1) from a clean install.
        Have you used this guide to set up the speaker ? Can you show the output of aplay -Ll in full ?
        BiZzAr721B 1 Reply Last reply Reply Quote 0
        • BiZzAr721B
          BiZzAr721 @mitu
          @mitu Yes, I did use that guide. I also saw it noted in that guide:
          omxplayer does not seem use the I2S interface for audio - only HDMI - so you won't be able to use it
          I did not pursue sound through OMX player after that until I came across your post about testing a file using
          omxplayer -o alsa
          and then proceeded to get splash screen sound back (Thank you BTW)
          aplay -Li
          null
              Discard all samples (playback) or generate zero samples (capture)
          speakerbonnet
          dmixer
          softvol
          default
          sysdefault:CARD=sndrpihifiberry
              snd_rpi_hifiberry_dac,
              Default Audio Device
          dmix:CARD=sndrpihifiberry,DEV=0
              Direct sample mixing device
          dsnoop:CARD=sndrpihifiberry,DEV=0
              Direct sample snooping device
          hw:CARD=sndrpihifiberry,DEV=0
              Direct hardware device without any conversions
          plughw:CARD=sndrpihifiberry,DEV=0
              Hardware device with all software conversions
          card 0: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 []
            Subdevices: 0/1
            Subdevice #0: subdevice #0
            @BiZzAr721 said in No sound using OMXplayer / Arcade Bonnet:
            If omxplayer -o alsa works, try changing the above to
            <string name="OMXAudioDev" value="alsa" />
            and see if it makes a difference.
            • BiZzAr721B
              BiZzAr721 @mitu
              @mitu Wow, well that definitely is a step in the right direction! Sound works, but is extremely low. I had to have the volume nearly all the way up, but then the emulator sound is nearly blowing the speaker.
              I only have sound with audio card set as sysdefault, HW, and default. All others will have the volume set to 0 when I go back into sound menu.
              Edit : As well as anything other than pcm for Audio Device
              I entered alsamixer, but didn't find anything useful there. Is there a way to control OMXplayer volume independant of software volume (or vice versa)?
              Temp fix noted: I added audio_volume = -24.0 into retroarch.cfg which for the most part normalizes OMXplayer video snap volume with LibRetro emulators. Since it's a miniature cabinet, I removed non-lr emulators that didn't really need to be on there. The only one I couldn't part with was Daphne (and OpenBOR when I set that back up)!
              note2: I altered daphne volume by creating a <gamename>.command file and adding volume variables (along with some other enhancements)
              -nocrc -volume_nonvldp 8 -volume_vldp 8 -noissues -nolog -noserversend
              Volume is rated 0-64. Daphne command line variables can be found here.
