    Cutscenes Missing or Just Not Playing with Turbo/PC Engine CD games
    turbo duoturbo cdpc engine cdpc egineexile
    1 Posts 1 Posters 302 Views
    • JirynJ
      Jiryn
      RetroPi: 4.5.18 running on a B+
      I just ran into this issue again, where certain cutscenes won't play with the PC-Fast emulator
      I'm not sure if it's the emulator or the rom file.. but at times cut scenes just won't play on certain Turbo/PC Engine games.
      I just played through Last Exile and certain cut scenes wouldn't play, while others were just entirely quiet.
      When I finally beat the game, it went to a black screen. Nothing played, the system wasn't frozen, it was just a black screen.
      I am curious if it is the same issue that was seen with Exile, where it doesn't run correctly on PC-Fast emulator, but the normal one hasn't been added to the image files/updates yet.
      I know it was the same error last time I played Last Alert, but I am using an ISO from a different source and having the same issue. (I rebuilt the system and redownloaded everything to a larger SD card)
      Sadly my physical copy can't be used any more due to age, and wear and tear.
      Thank you in advance for any advice!
