    Extreme lag in Daphne emulator
    daphnedragons laircliffhanger
    3 Posts 2 Posters 509 Views
      Ken Tipton
      I have searched the internet and have not found anyone having the same issue I am having. I made a Bartop Arcade and am running retropie and several emulators. All of them work as expected except for Daphne. I only want to plat Dragons Lair and CliffHanger. After a bit of research I was able to successfully map all the buttons and got it working. The issue I am having is that the lag in the joystick makes it unplayable. I thought at first I was just horrible at the game but turns out the game doesn't see the actions from the joystick fast enough. If I play with the keyboard it works just fine. The joystick is absolutely mapped correctly because there are times it will see the action and make the move and I was able to confirm all 4 directions work. I am using Sansa Joysticks through a zero delay pad that the Retropie sees as "dragon" something or other. Anyway is there anyway to adjust for lag or is there another issue.
      Thank you
      Ken
        dizmodawg @Ken Tipton
        Dragon Rise encoders don't play well with Daphne.
          Ken Tipton @dizmodawg
          @dizmodawg so if I got a new encoder that would fix it? and if yes do you have a suggestion?
          Thanks again for your reply
