    How do I install Retropie ontop of Ubuntu on raspberry pi 4B 4gb
    ubunturaspberry pi 4retropie 4.6
    9 Posts 3 Posters 750 Views
    • H
      hackedmacbook111 Banned
      I installed Retro Pi mostly but tis 1package libraspberry-dev how would I fix this I don't want to get rid of ubuntu andI don't want to go to a store withthe risk of getting covid-19
      I did all instructions to install on ubuntu
      Retro Arch was having problems before trying to install retropie
        We don't support Ubuntu on the Raspberry PI, only on PC (x86/x86_64).
        • H
          Will the raspbian commands work on ubuntu
            mitu Global Moderator @hackedmacbook111
            @hackedmacbook111 said in How do I install Retropie ontop of Ubuntu on raspberry pi 4B 4gb:
            I imagine specific Raspbian commands no, though they're just few, but not only the commands are the problem for installation. If you want to install RetroPie on a Pi4, then you'll need to use Raspbian.
            • H
              is there away I could get retro pi on pi4 with ubuntu
                Not without someone adding support for Ubuntu + PI4 in RetroPie.
                • H
                  Ubuntu should be added lots of people use it and its 64 bit
                  I tryed raspbian can't even watch youtube in1080p
                    On a Raspberry PI4, not as much as Raspbian. On a PC, yes.
                    You should search the Raspberry Pi forums for similar issues, I remember I've seen something similar that was easily solvable.
                    • H
                      thanks for your help mega man
