    RetroFlag safe shutdown/reset script doesn't work on Retropie 4.6
    retroflagsafe shutdownscriptretropie 4.6
    7 Posts 4 Posters 5.0k Views
    • The ShadowT
      The Shadow
      Hello,
      I was using Retroflag Nespi Case+ and Raspberry Pi 3 Model B with Retropie 4.5 and I saw the new version has released. So I wiped my SD card and installed the new version of Retropie and then installed the safe shutdown/reset script for Nespi Case+. But it didn't work. Script installed properly and the system restarted after the installation but when I push the power buttons, nothing happens.
      Is this a bug or am I the only one having this problem?
      Regards.
      Pi Model or other hardware: Raspberry Pi 3 Model B
      Power Supply used: Original Raspberry Pi Adapter
      RetroPie Version Used : 4.6
      Built From: Retropie 4.6 Image from website, burned with Raspberry Pi Imager
      USB Devices connected: Logitech K400+
      Controller used: Xbox 360 Wireless Controller
      Error messages received: Nothing
      mituM cyperghostC 2 Replies Last reply Reply Quote 0
        mitu Global Moderator @The Shadow
        @The-Shadow said in RetroFlag safe shutdown/reset script doesn't work on Retropie 4.6:
        If it's a bug, is in the RetroFlag's script. I recommend installing @cyperghost's shutdown's script instead - https://github.com/crcerror/ES-generic-shutdown.
          cyperghost @The Shadow
          @The-Shadow Yes, true retoflag messed the scripts with the latest changes. Oh dear.... as @mitu said you can use my installers.
          Command for install
          wget -O - "https://raw.githubusercontent.com/crcerror/retroflag-picase/master/install.sh" | sudo bash
          Command for uninstall
          wget -O - "https://raw.githubusercontent.com/crcerror/retroflag-picase/master/uninstall_all.sh" | sudo bash
          • The ShadowT
            The Shadow
            Hi @mitu and @cyperghost
            This script working very well thank you so much. Also on Retropie 4.6, the system reboots itself very fast.
            I have 2 other questions.
            I don't remember how the reset button works (restarts whole system or just emulation station) but I tried the reset button with your script and only Emulation Station restarted, not the whole system. But this is not a problem for me. I just wondered.
            I also have a GPi Case for Raspberry Pi Zero W. Can I install this script for GPi Case too or is there another script for that?
            Regards.
              @The-Shadow It's a modification I've made. I think a reboot is not usefull. So reset just terminates any emulator (if one is running), otherwise it restart ES to update gamelists.
              You can reboot from the menu ;)
              For GPi - I've also used created a installer
              For GPi
              wget -O - "https://raw.githubusercontent.com/crcerror/retroflag-picase/master/install_gpi.sh" | sudo bash
                malingjc @cyperghost
                @cyperghost When I tried this on mine - it won't start up into the splash screen anymore - the display goes nuts. Running your uninstaller and rebooting brings it back to life.
                Does it do something to the display driver?
                  cyperghost @malingjc
                  @malingjc check content of your rc.local please. Can you post content of this file to pastebin.com please?
