    Can my usb device have data on it already?
    22 Posts 6 Posters 13.0k Views
      richeowens
      I have set up retropie and am going to move over some ROMs, but have 2 questions:
      1. Can I use an external hard drive instead of a usb stick? Pretty sure I can right?
      2. If I already have data on the hardrive will it overwrite when I plug it in to the pi?
      Basically, do I have to buy a new usb stick or can i use an existing usb hard drive even though there's important data already on it?
        ShootHere
        Considering the price of USB Stick storage and the fact that you are working with software that can bug out in many ways, I would suggest you use a dedicated storage for Retropie
        Also: be sure to make backups of that important data!
          edmaul69 @richeowens
          @richeowens i modify the es_systems.cfg to look for the roms on the hard drive (ie: nes roms are located in /media/usb0/nes) im not sufe if the method that they recommend messes with your data. I wouldnt think so. But my method cant mess with your data. I used to have other important data as well on well until i got a new hard drive.
            @edmaul69 said in Can my usb device have data on it already?:
            I can confirm that the recommended method does not mess with your data. Modifying the es_systems.cfg is not recommended for a few reasons. First and foremost, some facets of RetroPie are hardcoded to use ~/RetroPie/roms/ and don't reference es_systems.cfg, thereby creating technical problems with some emulators. Secondly, even with a "system" in place, changing the es_systems.cfg after every update is really unnecessary and can be a laborious chore.
            Edit: It should be noted that reformatting a drive will indeed write over all your data. However, it is also not necessary nine out of ten times as almost every USB stick comes formatted as FAT32 out of the box. In any uncertain cases where concern is an issue, making a quick backup of your data is always recommended.
              cyperghost
              The easiest solution imho is to link to your external USB-stick or HDD.
              Use terminal and login as root or user pi.
              The best solution is to use the same file structure as used for retropie roms.
              Then just use the commands ...
              As mediamogul said, it's better to not change the es_systems.cfg
              cd /home/pi/RetroPie
              mv roms roms_backup
              ln -s /media/usb/roms roms
              et voilà you've got a symlink to roms.... if you now enter cd roms and use ls then all roms from your usb stick are listed. I just tried with fat32 format but ot works 100%. I think it's a bad idea to use the sd-card as roms storage because for update reasons.
              I think working with fstab is the ... well... the professional way. But the usb_automount package is installed by default in retropie and to link to a folder is a neat way. What do you think?
                mediamogul Global Moderator @cyperghost
                @cyperghost said in Can my usb device have data on it already?:
                It's main purpose is to allow scripts to function from a FAT32 formatted drive that otherwise wouldn't. Without that step, certain emulators won't be able to launch.
                In the interest of full transparency and so that I don't seem like a complete contrarian to this discussion, I have to admit that I have altered the recommended steps in certain ways myself. I'll refrain from detailing them as not to muddy the waters any further. At the end of the day, everyone has their own personal preferences and as long as nothing is noticeably broken, there's probably no real harm. However, I think it's important to remember what changes were made and how in the event that troubleshooting becomes necessary.
                  cyperghost @mediamogul
                  @mediamogul
                  ahhh yes.... I totally agree.
                  To avoid the fact that only with linking on a fat32 device the file permissions are gone and you're unable to launch bash files, then just edit the es_systems.cfgand add a bash next to the <command> section. Then you're allowed to execute bash scripts even on linked fat32 device.
                  As I said, linking to the roms folder is just a neat solution and you don't have to be being a linux professional :)
                  mediamogulM dankcushionsD 2 Replies Last reply Reply Quote 0
                    Very nice tip. I'll have to file that one away.
                    That's a good point. Personally, I plan on maintaining my amateur status so I can compete in the Linux Olympics.
                      cyperghost
                      This post is deleted!
                        @mediamogul
                        Well I just tested for Quake and DOOM-builds as you maybe know.
                        With the bash-commands they work all flawless as linked FAT32 files.
                        Maybe a linux pro just taunts me now as noob because it isn't the pro solution but better suggestion are welcomed.
                          I hope you don't think I was taunting you, as that was definitely not my intent. However, if you're also mistaking me for a Linux professional, I might have to roll with it and add the title to my business cards right next to "Bikini Inspector".
                            @mediamogul
                            No no... you were not taunting me :)
                            No problem
                              @cyperghost
                              Ah, good. I can still call myself a "Bikini Inspector" though, right? ;)
                                dankcushions Global Moderator @cyperghost
                                @mediamogul
                                To avoid the fact that only with linking on a fat32 device the file permissions are gone and you're unable to launch bash files, then just edit the es_systems.cfgand add a bash next to the <command>y section. Then you're allowed to execute bash scripts even on linked fat32 device.
                                would this have a side-effect for people not using fat32/mapped drives? seems like a useful default if not!
                                it's how I used to do it :) I think they're much the same in terms of results and number of steps. interested to hear from any "Linux professionals" as to what is actually 'best'
                                cyperghostC mediamogulM 2 Replies Last reply Reply Quote 1
                                  cyperghost @dankcushions
                                  @dankcushions afaik as I know - No.
                                  Because it does not matter how you execute a shell-script. I know 3 ways in doing this
                                  • chmod -x and direkt call via ./script.sh
                                  • bash script.sh
                                  • sh script.sh
                                  Both sh und bash are shells. I do not know which one is better, but so far everthing is working as long as the sh or bash package is installed.
                                  As you see FAT32 does not know file permissions, so you can not CHMOD a FAT32 script. Exceptions of this rule apply, if you do the mounting per fstab :) So I also think we can use this behaviour as standard. I am also sure this would work on NTFS, any UNIX-FS can be CHMODed. FAT32 gives the great chance to transfer huge files (ISO Images) directly to needed device by just plugging a USB-Stick to your PC.
                                    mediamogul Global Moderator @dankcushions
                                    @dankcushions said in Can my usb device have data on it already?:
                                    The only exception to this would be the elements in RetroPie that don't entirely reference the es_systems.cfg file for rom location. When any technical issues arise, it will always be a good idea to mention that this particular method of rom migration was used in order to expedite the troubleshooting process. As far as I know, these issues will only come up when using the Amiga emulators, BasiliskII, Daphne, DOSBox, ScummVM and possibly a few of the ports, but it's still worth noting.
                                      dankcushions Global Moderator @mediamogul
                                      @mediamogul can you be more specific ? which method has a problem with direct rom locations - mounting USB as /home/pi/RetroPie, symbolic linking USB as /home/pi/Retropie, or both?
                                      cyperghostC mediamogulM 2 Replies Last reply Reply Quote 0
                                        @dankcushions Well I think he talks about the issues in searching errors via this forum.
                                        There are several ways to change the location to the roms.
                                        1. use fstab
                                        2. change the es_system.cfg
                                        3. use symbolic link
                                        but you have always tell the forum members what you have done and what kind of file format on your usb-stick you are using. If there are some issues with the linking, then it will be the Amiga, Daphne, DosBox, ScummVM and Ports. I can only admit, that the Ports work flawless if you add to the es_system.cfg a BASH or SH command.
                                        Usually 99% of the users use the Console Emulators so there are no issues and linking is an easy way in handling ROMS.
                                          @dankcushions
                                          Neither actually. I thought you were making reference to simply altering the es_systems.cfgfile, which I admit kind of surprised me. Both mounting and sym-linking an external roms folder to ~/RetroPie/roms should of course work in any situation imaginable. I misread an earlier post and was continuing on with the same misunderstanding here. Sorry for the confusion.
                                            @mediamogul said in Can my usb device have data on it already?:
                                            @dankcushions
                                            thought so :) that's fine.
                                            to confirm, the only know downsides to the recommended method:
                                            • bash issue mentioned above (i'm still not sure that applies to direct mounting, or whether there's any side effect if it was a default for ALL retropie installs)
                                            • can't use internal symlinks on FAT32 drive (eg, the way latest advmame symlinks /RetroPie/roms/arcade/advmame/cfg/ to /RetroPie/roms/mame-advmame/cfg/(etc)
                                            editing es_systems.cfg is not recommended for a bunch of reasons, but using a symlink is probably ok
