    Wifi passwords issue with RasPi4
    raspberrypi4retropieroms
    3 Posts 2 Posters 80 Views
    • hawkes_84H
      hawkes_84
      I'm trying to put some roms on retro-pie on my Raspberry Pi 4 via Bluetooth and the "Pi" & "raspberry" username and password aren't recognised. Is there any way of checking what the username and password are or resetting them? thanks
        The username is pi, not Pi. If you didn't manually changed them and you've used the RetroPie image, then there's no need to check.
        • hawkes_84H
          hawkes_84
          yes sorry meant "pi" . It was the password that had been changed but not sure when. Was able to change back through sudo raspi-config. Thanks for you help
