    Retropie 4.6 - Pi 4b - Zip problem snes9x
    zipretroarchpi4 bretropie 4.6snes9x
    5 Posts 2 Posters 666 Views
      Tounet
      Hi there,
      I'm new to emulation, but not to gnu linux, after some days of testing, i have all my roms who works well except in zip file (or 7z) for snes9x.
      The files are on the sd card (not mounted from usb or nas)
      It's not a naming problem because i had remove all space and special characters (to be sure)
      My conf :
      Pi Model 4 B
      Power Supply used: (If using a Pi) : 5V - 3 A
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.6
      Built From: Pre made image from PINN
      USB Devices connected: mouse keyboard
      Controller used: 8bitdo
      Error messages received:
      [libretro INFO] Try 'force no-header' option if the game doesn't work
      [libretro INFO] "y<L____V_|vC____!,__Yp" [bad checksum] LoROM, Corrupt, ROM, NTSC, SRAM:Corrupt, ID:_m__, CRC32:7FABE0EC
      [INFO] [Environ]: SET_PIXEL_FORMAT: RGB565.
      [INFO] [RCHEEVOS]: ext_hash 0b88c7d8 ('zip')
      [INFO] Échec à l'extraction de contenu depuis le fichier compressé.: /home/pi/RetroPie/roms/snes/SuperMarioWorldEuropeZip.zip.
      Emulator: Retroarch 1.8.5 with snes9x
      Log found in /dev/shm/runcommand.log with zip : https://pastebin.com/Swmx36wZ
      Log found in /dev/shm/runcommand.log without zip : https://pastebin.com/q9SQ54Bx
      I don't understand the bad checksum message as the rom works well outside the zip. I have try many times to recompress the zip, even with store only (nocompress) option.
      retroarch 1.8.5 is build with zip and 7zip support as the --features show.
      Is this a common problem ?
      I could doing more test or debug.
        Could be a zip compatibility issue. What's the output of
        zipinfo -vv /home/pi/RetroPie/roms/snes/SuperMarioWorldEuropeZip.zip
          Tounet
          I finally found the problem after searching on google, but i don't understand
          After renaming all flc files in the zip, no more problem.
          So the rom with flc or mgd work outside the zip, but in the zip only flc ?
          If someone have an explanation.
            mitu Global Moderator @Tounet
            @Tounet said in Retropie 4.6 - Pi 4b - Zip problem snes9x:
            I don't understand either - you renamed them to what ?
              Tounet
              All my snes rom have mgd file extension in each zip. After renaming all these rom to flc in the zip. No more problem...
