    nds drastic keys not right
    nds
    6 Posts 3 Posters 540 Views
    • shavecatS
      shavecat
      pi4 retropie 4.6
      so im trying to fix my controls on the drastic but its going nuts a bit also with keyboard
      only on that nds ..
      tried reinstall it again and all ...
      any ideas plz ?
      • ClipoC
        Clipo
        It seems that there is something like a bug with the drastic menu. There is a delay in one input command, what you see is the previous key you pressed. I had the same problem, you just need to keep track of what are you doing in your mind and you can manage to do it.
        shavecatS 1 Reply Last reply Reply Quote 1
        • shavecatS
          shavecat @Clipo
          @Clipo
          ByteThisB 1 Reply Last reply Reply Quote 0
          • ByteThisB
            ByteThis @shavecat
            @shavecat There was a post in reddit helping controls for 4.6. I haven't tried it myself but he says it works : https://www.reddit.com/r/RetroPie/comments/ghsxay/drastic_2504_for_rpi4_controller_config_fix/
            shavecatS 1 Reply Last reply Reply Quote 0
            • shavecatS
              shavecat @ByteThis
              @ByteThis
              took it from my old pi3b+ image...yeha
              • ByteThisB
                ByteThis @shavecat
                @shavecat Good to know there is a workaround for now if it works for you on the Pi4. .
