    Pi 4 + Running ROMS from USB stick
    raspberrypi4usb romusb rom service
    22 Posts 2 Posters 2.6k Views
      @Chapster5 said in Pi 4 + Running ROMS from USB stick:
      does this look correct:
      https://ibb.co/kJXyT8j
      It does, but it's missing a partition. Your USB partition is at /dev/sda5, which is the 1st logical partition, but you also have another primary partition (/dev/sda1) which might be un-formatted and I assume it was that partition that was causing issues with the boot.
      Anyway, all is well when it ends well. Out of curiosity, how did you format the USB drive - did you use Windows or other OS ?
        Chapster5 @mitu
        @mitu perfect thank you
        I formatted using the USB formatting guide here:
        https://www.makeuseof.com/tag/format-large-hard-drive-fat-fat32/
        Using FAT32 Format
        Plugged the stick in, clicked format and waited haha.
