    xm7 and sdltrs not present in retropie 4.6 for rpi4
    raspberry pi 4retropie 4.6sdltrsxm7trs-80
    6 Posts 3 Posters 955 Views
      shift
      I noticed that the emulators for RadioShack TRS-80 (sdltrs) and for Fujitsu FM-7 (xm7) have disappeared in the experimental packages. Is it a forgetfulness or is it precisely because they are no longer compatible with the raspberry pi 4?
        They're not compatible with the Pi4 platform.
          comegetsome
          Pardon my ignorance, are they not compatible for now (temporarily), or is this indefinite due to the structure of the Pi4 platform?
            mitu Global Moderator @comegetsome
            @comegetsome It's a software compatibility issue - they're no longer working properly with the Pi4 . You could say it's a temporary situation, but the fact is it depends on the upstream emulator and not entirely on RetroPie's side.
            Which one of the emulators are you most interested to have it back in RetroPie (on the Pi4) ?
              comegetsome @mitu
              @mitu cool, thank you much for the info.
              Personally I'm definitely more interested in sdltrs for the Pi4.
                @comegetsome sdltrs has been recently updated and it should be available on the Pi4 again. Just update your RetroPie-Setup script and then you can install it.
