    [RetroPie/pifba] Sprites and backgrounds has lines and incorrect aspect in vertical scrolling and movement.
    pifbaissuevertical sync
    3 Posts 2 Posters 379 Views
    • H
      handlolo
      Hi, I am using this fantastic emulator in a raspberry 1 model b overclocked 1ghz, Retropie 4.6, and perfect speed, but I have found a fault that occurs in all situations.
      When there is movement of sprites or backgrounds, annoying drawing lines appear during painting, it is as if the aspect ratio is not correct, this does not occur when the movement is horizontal, it only appears vertically.
      I have tried all the options and it doesn't matter if the scanlines or Aspect ratio options are activated.
      I am using a Dell P1130 Trinitron with different resolutions where this same problem appears (640x480, 1024x768, etc.)
      Best Regards
        NOTE: Please don't post the same topic in multiple categories, one is enough. Thank you.
        • H
          handlolo
          Sorry, i put one in wrong place and i couldnt delete it
