    FB Neo hiscore help
    high scoresfbneo
    3 Posts 2 Posters 457 Views
      aldomontoya
      Hi,
      I have random success with hiscores with FB Neo. I've donwnloaded the latest hiscore.dat from the lr fbneo github, and placed it in /BIOS/fbneo/
      I have some hiscores working, but most don't. I don't even see *.hi for most games. some select games, e.g. pacman, has a pacman.hi file and it works, but others such as Xain'd Sleena and 1942 just don't seem to appear.
      Hiscore is set to On in LR. any suggestions please?
      Pi Model or other hardware: 3B
      Power Supply used: Standard Pi
      RetroPie Version Used: 4.6
      Built From: Pre made SD Image on RetroPie website, no updates yet.
      USB Devices connected: iPac 32.
      Controller used: iPac
      Error messages received: None
      Log found in /dev/shm/runcommand.log (if relevant): NA
      Guide used: ALL!
      Emulator: FB Neo
        barbudreadmon @aldomontoya
        @aldomontoya Not every game in FBNeo has support for hiscores (sleena doesn't support hiscore atm), however 1942's hiscores work fine.
          aldomontoya
          thank you @barbudreadmon , i had made the leap of faith that since, for example, Xain'd Sleena had an entry in the file it was supported. I'll retry 1942...
          Appreciate the confirmation.I'll just have to keep grabbing a save state until some support hopefully comes! If i had the ability I'd look into how to do it myself...
