    Running roms from network share does not work
    networkretropie
    9 Posts 2 Posters 776 Views
    • KITNK
      KITN
      Hi there,
      I have a second Raspberry Pi (Pi4 4GB) in my network which stores my data as a network share. I want to run the games on Retropie from this network share too.
      In order to do that I followed the tutorial on Github.
      Here is the folder structure on my network share
      On "Boot Options" I selected Yes
      I did:
      sudo nano /opt/retropie/configs/all/autostart.sh
      This is what I added:
      sudo mount -t cifs -o username=pi,password=mypassword,nounix,noserverino //192.168.2.109/media/medienspeicher/Retropie/roms /home/pi/RetroPie/roms
      sudo mount -t cifs -o username=pi,password=mypassword,nounix,noserverino //192.168.2.109/media/medienspeicher/Retropie/BIOS /home/pi/RetroPie/BIOS
      sudo mount -t cifs -o username=pi,password=mypassword,nounix,noserverino //192.168.2.109/media/medienspeicher/Retropie/splashscreens /home/pi/RetroPie/splashscreens
      It does not work. What do I have to do in order to make it work?
      If you have done the above steps please create a new topic and add the following relevant information so that we can help narrow down the cause of your issue. Please do not add a "me too" to an old topic, as the cause of your issue may be different. Make sure your topic title summarises the issue - do not use topic titles like "HELP ME".
      Pi Model or other hardware: 3B
      RetroPie Version 4.6
      Guide used: see abowe
        @KITN said in Running roms from network share does not work:
        What happens when you run the mount commands manually, from the command line/SSH session:
        Do you get an error message or the command succeeds ?
        • KITNK
          KITN
          I get a error message, that the directory does not exist:
          mount error(2): No such file or directory
          kevin@SIDNEZ ~ $ ssh pi@192.168.2.109
          pi@192.168.2.109's password:
          Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Wed Jun  3 10:53:42 2020 from 192.168.2.125
          pi@raspberrypi:~ $ cd /media/medienspeicher/Retropie/roms/
          pi@raspberrypi:/media/medienspeicher/Retropie/roms $
          But I can connect to the directory via ssh so I think the part "//192.168.2.109/" seems to be wrong.
            mitu Global Moderator @KITN
            @KITN Is the /media/medienspeicher folder (or the RetroPie subfolder) shared by the server via Samba ?
            • KITNK
              KITN
              yes
                yes
                Yes what ? Which folder is shared on the network ? Can you browse the shares from a PC and see a listing of the shares ? Is the pi user allowed to access the share(s) ?
                • KITNK
                  KITN
                  Heres the smb.conf
                  [medienspeicher]
                  comment = Medienspeicher
                  path = "/media/medienspeicher"
                  public = yes
                  only guest = yes
                  browseable = yes
                  read only = no
                  writeable = yes
                  create mask = 0644
                  directory mask = 0755
                  force create mask = 0644
                  force directory mask = 0755
                  force user = pi
                  force group = pi
                    Alright then, so you should be accessing the file share as //<server_ip>/medienspeicher (name of the share) and not as //<server_ip>/media/medienspeicher.
                    Since you configured the share as 'guest only', you can probably remove the username and password mount options and use guest instead.
                    • KITNK
                      KITN
                      Now it works. Thank you very much.
