    PPSSPP - Mapping Problem - Wireless Xbox controller
    xboxwirelesscontrollermappingppsspp
    17 Posts 5 Posters 10.3k Views
    • theinkT
      theink
      Hi.
      Update... Adding my specs.
      • Raspberry Pi 4 - 4GB model.
      • Power Supply: 5.1V 3A USB-C
      • Retropie 4.6, installed from SD Image
      • Using PPSSPP (not Ir-ppsspp)
      • Controller Used - Official Wireless Xbox 360 Controller with the official receiver.
      I'm having problems mapping a wireless Xbox 360 controller inside the ppsspp menu.
      For some reason, it does not recognize any input from the D-pad at all when I try to remap the button function.
      Up and Down buttons don't work.
      Left button registers as Up
      Right button registers as down.
      The analog works fine. The X,[], O, Triangle buttons are mapped correctly as well.
      There are some other mismatched button functions as L and R, but my main problem at the moment is that the D-pad.
      I have a small 8bitdo controller that maps correctly, but I would prefer to use the xbox one.
      Have someone encountered this problem?
        Please add some info about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        theinkT 1 Reply Last reply Reply Quote 1
        • theinkT
          theink @mitu
          @mitu Thank you.
          I had just updated my post by adding the specs.
          • quicksilverQ
            quicksilver @theink
            @theink official Xbox one or 360 controller?
            theinkT 1 Reply Last reply Reply Quote 0
            • theinkT
              theink @quicksilver
              @quicksilver Xbox 360
              • quicksilverQ
                quicksilver @theink
                @theink Thats odd, im using a wireless xbox 360 controller as well and the dpad just works out of the box in PPSSPP. Try resetting the PPSSPP controller mappings to default. Can you use the dpad to navigate the menus in PPSSPP? When was the last time you updated PPSSPP?
                • theinkT
                  theink @quicksilver
                  @quicksilver
                  I had updated the script probably a weeks ago.
                  I can navigate inside the menu, but as I said if I want to move up and down I have to press left and right.
                  I thought I can easily fix this inside the controller config options menu, but this happens...
                  I reach the remapping menu. I press the + button under one of the dpad buttons and press A on the controller to confirm my choice. Ppsspp registers the press of A, but when. I press UP to actually remap the button, nothing happens, untill I finally press some of the other buttons.
                  It is weird as the other emulators work fine with the this controller.
                    I think PPSSPP uses the SDL2 gamepad API to identify and map controller buttons - it may be worth trying to update it's mapping database.
                    Grab the gamecontrollerdb.txt file from https://github.com/gabomdq/SDL_GameControllerDB and replace the file in /opt/retropie/emulators/ppsspp/assets with it, then try again and see if the gamepad is handled better.
                    • theinkT
                      theink
                      @mitu said in PPSSPP - Mapping Problem - Wireless Xbox controller:
                      I tried replacing the file.
                      Nothing changed.
                      I did more testing. I noticed one more thing.
                      While I'm on the menu and I push the Left Analog UP, I go down.
                      When I press Left Analog UP DOWN I go up.
                      Pushing Left and Right work as expected.
                      Here is what PPSSPP registers on button press when I try to remap the controls to the XBOX360 controller.
                      • Dpad Up - pressing UP does not register anything
                      • Dpad Down - pressing DOWN does not register anything
                      • Dpad Left - pressing Left registers as pad1.Up
                      • Dpad Right - pressing Right registers as pad1.Down
                      • O - Pressing B registers as pad1.b3
                      • X - Pressing A registers as pad1.b2
                      • [] - Pressing X registers as pad1.b4
                      • Triangle - Pressing Y registers as pad1.b1
                      • Start - Pressing Start registers as ThumbL
                      • Select - Pressing Back registers as pad1.back
                      • L - Pressing LT registers as pad1.b9
                      • R - Pressing RT registers as pad1.10
                      • Analog Up - Pressing X registers as pad1.Y Axis -
                      • Analog Down - Pressing X registers as pad1.Y Axis +
                      • Analog Left - Pressing X registers as pad1.X Axis -
                      • Analog Right - Pressing X registers as pad1.X Axis +
                      I had also updated the Xbox 360 controller driver.
                      No change occurred.
                      • quicksilverQ
                        quicksilver @theink
                        @theink try this
                        Edit:
                        /etc/modprobe.d/xpad.conf
                        Change
                        xpad triggers_to_buttons=1 to xpad triggers_to_buttons=0
                        Then remap your controller in emulation station. Then try remapping in ppsspp. I had a similar situation where I couldn't get the xbox 360 right analog stick mapped in ppsspp. This fixed it for me.
                        • theinkT
                          theink @quicksilver
                          @quicksilver said in PPSSPP - Mapping Problem - Wireless Xbox controller:
                          modprobe
                          Hi.
                          I'm keen on trying that, but that file seems to be inaccessible through my network and I don't have Linux to browse the card.
                          It seems to be something in PPSSPP that does not recognize the buttons correctly.
                          • quicksilverQ
                            quicksilver @theink
                            @theink from emulationstation drop to the terminal (f4) and type
                            sudo nano /etc/modprobe.d/xpad.conf
                            That will allow you to edit that file. Make the change I suggested above then press cntrl-x. It will ask if you want to save the changes make sure you say yes. Then type emulationstation to go back to emulationstation. Remap your controller and try PPSSPP again. It's a possibility that PPSSPP isn't perceiving the controller correctly because of that above option.
                            You can also try updating the xpad driver in retropie-setup.
                            • theinkT
                              theink @quicksilver
                              @quicksilver
                              Thank you.
                              I will try that in the coming days. I don't have a wireless keyboard at hand :p
                              I did a complete test of the Xbox360 controller inside PPSSPP.
                              This is a list of the buttons I'm pressing and how PPSSPP recognizes them in the menu.
                              Main Buttons
                              Back - pad1.back
                              Start - pad1.ThumbL
                              X-Box - pad1.ThumbR
                              Directional Pad
                              Up - Don't Register!
                              Down - Don't Register!
                              Left - pad1.Up
                              Right - pad1.Down
                              Face Buttons
                              A - pad1.b2
                              B - pad1.B3
                              X - pad1.b4
                              Y - pad1.b1
                              Left Analog
                              L3 - pad1.Left
                              Up - pad1.Y Axis -
                              Down - pad1.Y Axis +
                              Left - pad1.X Axis -
                              Right - pad1.X Axis +
                              Right Analog
                              R3 - pad1.Right
                              Up - pad1.Pressure -
                              Down - pad1.Pressure +
                              Left - Don't Register!
                              Right - pad1.TouchMajor +
                              Shoulder Buttons
                              LB - pad1.b6
                              LT - pad1.b9
                              RB - pad1.b5
                              RT - pad1.b10
                                rodolfoaguilar @theink
                                @theink Have you had any luck with this? I'm running into the same issue with a third-party wireless controller that I got from local Best Buy manufacturer. Weird thing is that it works well with the other platforms like SNES or GBA. First time I set it up, left analog joystick worked fine as well as A, B and Y but dpad, shoulders and X buttons didn't do anything Tried reconfiguring it on retropie setup screen and when I got back into PPSSPP this time dpad worked instead of left analog. Thank you
                                • theinkT
                                  theink @rodolfoaguilar
                                  @rodolfoaguilar
                                  Hi.
                                  I did not have time to research any further.
                                  I can only guess what is causing the problem, but it is definitely something tied to ppsspp.
                                  I guess that not enough people had stumbled on it yet. Hoping for an update from the retropie team working on ppsspp.
                                  • F
                                    Firebird_WS6
                                    I have exactly the same problem with a Raspberry Pi4 4Gb installed in a PiBoy DMG handheld game case. The D-Pad functions incorrectly in the same way as the OP.
                                    • theinkT
                                      theink
                                      @quicksilver
                                      It had passed 4 months before I actually tried your fix proposal.
                                      It worked. The X-box controller is now fully compatible. Thank you!
                                      @rodolfoaguilar @Firebird_WS6
                                      I'm summing up what quicksilver proposed.
                                      This solution worked for me.
                                      1. Plug in a Keyboard
                                      2. While in Emulation Station press F4 to open the Terminal
                                      3. Type
                                      1. Change
                                      2. Press cntrl-x
                                      3. Accept the changes.
                                      4. Return back to Emulation Station by typing
                                      emulationstation
                                      1. Restart Retropie.
                                        (In my case, I noticed that the X-box controller had started acting strangely while in Emulation Station.
                                        The D-pad buttons swapped positions in Emulation Station as they were previously in PPSSPP.)
                                      2. Remap the controller in Emulation Station.
                                      3. Remap the controller in PPSSPP if necessary.
                                        (In my case, this was not needed.)
                                      I'm not sure why this issue is affecting some people and not others.
                                      Apparently, the problem is caused by the Trigger buttons somehow.
