    Audio issues after latest Raspbian updates (June 2020)
    audiobusteremulationstatioraspbianupdate
    104 Posts 27 Posters 70.4k Views
      @VictimRLSH said in Audio issues after latest Raspbian updates:
      Is there a way to output decent sound to GPIO pins that an audio amp chip can use?
      Either via GPIO - there's a plethora of Audio DACs that work like that - or with an external audio card connected via USB.
      • momentarydogmaM
        momentarydogma @mitu
        @mitu Yes, I have tried every option... at first I had "HDMI", "Headphone", "Sound Mixer" and "Default" none of which worked. When I added the above text to the cmdline.txt file, it expanded to add "Auto" and changed the "Headphone" option to something like "Headphone - 3.5mm". When I select "Sound Mixer" (or whatever it is), it allows me to hit F6 to select my soundcard. Previously, I only had 2-3 options, but now I have six, none of which make any difference.
        momentarydogmaM mituM 2 Replies Last reply Reply Quote 0
        • momentarydogmaM
          momentarydogma @momentarydogma
          I would also add this-- the amp I'm using is only connected to the Pi via 3.5mm audio. It plugs into power on its own, and it works perfectly when I connect it to other devices via the 3.5mm jack. I'm not trying to output to a USB soundcard or anything-- I just want the audio output to go through the headphone jack on the Pi. I have also tried connecting the Pi to other powered speakers and I have the same issue. What is preventing the Pi from sending an audio signal through the headphone jack? Or is that even the problem?
            mitu Global Moderator @momentarydogma
            @momentarydogma Don't modify the cmdline.txt, it shouldn't be needed and you should remove the lines you added.
            If you selected the Analog/Headphone audio option in the Audio settings, then in EmulationStation the settings should be Card: Default and Device: Headphone.
            momentarydogmaM 1 Reply Last reply Reply Quote 0
            • momentarydogmaM
              Okay, I removed the lines I added to the cmdline.txt file and selected the Headphone audio option in the Audio settings, then selected "Default" and "Headphone" in the EmulationStation settings. This actually got rid of the "failed to find mixer elements" message temporarily, but it unfortunately did not end up providing any sound... I tried restarting ES to see if that would help, but then the "mixer elements" message just automatically came back. On a whim, I tried selecting HDMI from the Audio settings and the ES settings (even though I'm using the 3.5mm output), but that just resulted in THREE iterations of the "mixer elements error". There is another setting in the ES audio settings titled "OMX Player Audio Device"-- do you have any idea what I should set that to?
                @momentarydogma said in Audio issues after latest Raspbian updates:
                Check the volume - software and hardware.
                Re-read my first post, at the top of the topic.
                • momentarydogmaM
                  @mitu okay, here are the lines from my es_settings.cfg file:
                  <string name="AudioCard" value="default" />
                  <string name="AudioDevice" value="headphone" />
                  <string name="CollectionSystemsAuto" value="" />
                  <string name="CollectionSystemsCustom" value="" />
                  <string name="GamelistViewStyle" value="automatic" />
                  <string name="OMXAudioDev" value="alsa" />
                  Those seem to match up with your original post-- should I change them to something else? Also, the software volume is currently set to 90%, but sometimes it randomly goes back to 0% upon reboot.
                    @momentarydogma The settings are correct.
                    • momentarydogmaM
                      @mitu Well, if that's correct, where do I go from here? I have verified that those settings are as they are supposed to be, but I still get the mixer settings error. The only other thing I could point out is that the OMX options also include "ALSA:HW:0,0" and "ALSA:HW:0,1". Does that mean anything? Keep in mind, this is a fully fresh install of Retropie 4.6-- I encountered this problem directly out of the box.
                        If you haven't updated anything on your image, then the instructions here don't apply, though I outlined the correct settings - before updating - in the first post. You can check if you have the updated kernel/firmware as described in the 1st post.
                        Verify that you have the updated kernel/firmware, otherwise the settings you posted above don't apply.
                        • momentarydogmaM
                          @mitu The very first thing I did was update the kernel and firmware. I did this before I realized that there was an issue with the audio. The first thing I was attempting to do was to install Attract Mode, and the very first step in the guide for that is to update the kernel and firmware. The first time I saw the "mixer elements" error was when I went into the package management console immediately after I had done those updates. I can also verify that I put in a different SD card with a 4.2 build from a prior setup (different 3B+) and the audio works with no issues. Thanks for all of your help!
                            This is not what 'out-of-the-box' means.
                            I advise you to reflash the image, update your system and packages and then re-do the settings for Audio as outlined in the first post. You don't to edit any files, just use RetroPie-Setup and the EmulationStation's settings from its menu.
                            • momentarydogmaM
                              momentarydogma
                              That's precisely what I did to begin with... I flashed the image, updated the system and packages, then I came upon this post once I realized that the audio wasn't working properly. I initially used the Retropie setup and configured the ES settings exactly how you described at the beginning of this post, to no avail. The only reason I edited any files was because you recommended doing so in order to revert to the previous audio configuration. But I'll try it again and see if that works. Thanks again!
                              • IdelacioI
                                Idelacio
                                Since updating my install sound has been working without changing options fine with one exception:
                                OMX player won't play sound.
                                No option corrects this and if I try and run a preview of a splash screen video it crashes the system. Video does play on startup though.
                                When going into the terminal I get the following errors depending on my settings:
                                Failed to find mixer elements (as above)
                                amixer: Unable to find simple control 'PCM' ,0 (get this twice)
                                This is using an updated official image on a Pi4 (4GB
                                5.4.51-v7+
                                RP - 4.6.6
                                ES - 2.9.3
                                I'm guessing this is part of the same problem though honestly not a massive issue, it's mainly presentation that's affected. If it is not sure there's anything that could be suggested for this other than wait for the general problem to be fixed?
                                Welp moot anyway because it won't boot into the OS now: rainbow screen of fail! You gotta love it when the raspi-config screws up... still useful to know when I load up the backup image as I believe that's pre update.
                                IdelacioI 1 Reply Last reply Reply Quote 0
                                • IdelacioI
                                  Idelacio @Idelacio
                                  This post is deleted!
                                  • IdelacioI
                                    Idelacio
                                    So after reloading the image and updating it (versions listed above) I now get new errors!
                                    ALSA lib control .c:1375:(snd_ctl_open_noupdate) Invalid CTL hdmi
                                    VolumeControl::init() - Failed to attach to default card!
                                    I have sound across OMX, BG music and games but volume control does not work in the ES menu and the options in teh ES menu for Audio card/device etc are pre update style despite having updated everything.
                                    • IdelacioI
                                      Idelacio
                                      Okay so started from SCRATCH, joys, and updated the system IMMEDIATELY (after applying wireless settings) and then applied audio settings. Did toss up the errors before setup but now it's working fine for all sound playing functions.
                                        RussellB
                                        Hi all,
                                        I posted a new topic on this but this might be better here...
                                        Can someone who has updated their configuration try lzdoom to see if it generates sound? It used to before; I must have updated something that updated my sound configuration and now that is the only program that doesn't output sound to the HDMI.
                                        By the way, uname -r returns: 4.19.97-v8+
                                        RussellB.
                                          mitu Global Moderator @RussellB
                                          @RussellB said in Audio issues after latest Raspbian updates:
                                          This topic is for the changes in the audio settings when using this kernel version 4.19.118 or later, so it doesn't really apply to your case.
                                            RussellB
                                            Sorry about that.
                                            I updated to the latest kernel and I'm still having this problem. :-(
