    Skyscraper Mimic Built In Scraper Settings Possible?
    scrapeskyscraperamiga
    12 Posts 3 Posters 988 Views
    • George SpiggottG
      George Spiggott
      I have noticed that I can scrape some Amiga games using the built in scraper on Retropie that I cannot get to scrape with Skyscraper. Both scrapers are using Screenscraper as a source.
      Some examples are:
      Gloom Deluxe (filename: Gloom_Deluxe.adf)
      Alien Breed 3D (filename: AlienBreed3D_v1.2_CD32.lha)
      Pinball Fantasies (filename: PinballFantasies_v2.7_CD32.lha)
      Is there a way to get Skyscraper to mimic whatever settings the built in scraper is using in Skyscraper?
      Also when Skyscraper scrapes a file with .bin/.cue files which file is it using to search?
      Currently running:
      Retropie 4.8.9 on a Pi Zero 2W (Overclock Settings: CPU 1400Mhz)
      ES-DE on a GMKtec K6 (Windows 11, 32GB RAM)
        @George-Spiggott said in Skyscraper Mimic Built In Scraper Settings Possible?:
        You can use the --query parameter and scrape using romnom option, so that it scrapes using the name of the game, instead of using the checksum of the file.
        /opt/retropie/supplementary/skyscraper/Skyscraper -p amiga -s screenscraper --query romnom=Alien+Breed+3d AlienBreed3D_v1.2_CD32.lha
        #1/1 (T1) Pass 1 ---- Game 'AlienBreed3D_v1.2_CD32' found! :) ----
        Scraper:        screenscraper
        From cache:     NO
        Search match:   100 %
        Compare title:  'Alien Breed 3D'
        Result title:   'Alien Breed 3d' ()
        Platform:       'Amiga CD32' ()
        Release Date:   '1995-01-01' ()
        Developer:      'Team 17' ()
        Publisher:      'Team 17' ()
        Players:        '2' ()
        Ages:           '' ()
        Tags:           'Shooter' ()
        Rating (0-1):   '' ()
        Cover:          YES ()
        Screenshot:     YES ()
        Wheel:          YES ()
        Marquee:        NO ()
        It depends on what Skyscraper considers as a ROM file, if both extensions are registered, it will try to find a match for each file. You can override this I think in the configuration.
        • George SpiggottG
          George Spiggott
          Thanks. It took a bit of doing but I got most of them. I've created a script file to take the hassle out of this if I have to do it again.
          The only game I couldn't get to work was Xenon 2 Megablast CDTV (filename: Xenon_2_Megablast_CD32.cue) I'm not sure if the filename is throwing it off but labelling the .cue as "_CD32" is the only way I can get it to boot on Amiberry.
          Currently running:
          muldjordM 1 Reply Last reply Reply Quote 0
          • muldjordM
            muldjord @George Spiggott
            @George-Spiggott You can also consider trying with some of the other sources in Skyscraper. openretro is an Amiga-centric database (and really good, even with the lha files), and mobygames is also very good for Amiga games. thegamesdb probably also.
            George SpiggottG 1 Reply Last reply Reply Quote 2
            • George SpiggottG
              George Spiggott @muldjord
              @muldjord Thanks I will look. Xenon 2 Megablast CDTV is definitely on Screenscraper though. I've tried every possible name combination I can think of.
              https://www.screenscraper.fr/rechercheroms.php?numpage=0&action=newrecherche
              Currently running:
              • George SpiggottG
                George Spiggott
                Now I'm really confused:
                This will not scrape: /opt/retropie/supplementary/skyscraper/Skyscraper -p amiga -s screenscraper --query romnom=xenon+2 Xenon_2_Megablast_CD32.cue
                This will: /opt/retropie/supplementary/skyscraper/Skyscraper -p amiga -s screenscraper --query romnom=xenon+2 Xenon2_v1.7_CDTV.lha
                Only the filename is changed, everything else is the same. Can anyone shed light on this please?
                Currently running:
                  Works for me:
                  #1/1 (T1) Pass 1 ---- Game 'Xenon2_v1.7_CDTV' found! :) ----
                  From cache:     NO
                  Search match:   100 %
                  Compare title:  'Xenon 2'
                  Result title:   'Xenon 2 - Megablast' ()
                  Platform:       'Amiga CDTV' ()
                  Release Date:   '' ()
                  Developer:      'Bitmap Brothers' ()
                  Publisher:      'Image Works' ()
                  Players:        '2' ()
                  Ages:           '' ()
                  Tags:           'Shooter' ()
                  Rating (0-1):   '0.6' ()
                  Cover:          YES ()
                  Screenshot:     YES ()
                  Wheel:          YES ()
                  Marquee:        NO ()
                  Description: ()
                  'Xenon 2: Megablast i[...]
                  'screenscraper' requests remaining: 1993
                  • George SpiggottG
                    George Spiggott
                    @mitu Yes for me too but the first entry (the .cue file) does not.
                    Currently running:
                    • muldjordM
                      @George-Spiggott Always remember to quote your queries if there's spaces in the name:
                      /opt/retropie/supplementary/skyscraper/Skyscraper -p amiga -s screenscraper --query "romnom=xenon+2 Xenon_2_Megablast_CD32.cue"
                      • George SpiggottG
                        George Spiggott
                        @muldjord I copy pasted that entry into Putty and got the following error from Skyscraper
                        '--query' was set but more than one filename was provided on command line or using the '--fromfile' option. Please provide only a single rom file name you wish to scrape using the query, now quitting...
                        Currently running:
                        • muldjordM
                          @George-Spiggott Yeah sorry, I misread your post. But you do need those quotes in case you want to use spaces in the romnom name. In this case you used a + instead. You should use %20 which is an url encoded space. It should be:
                          /opt/retropie/supplementary/skyscraper/Skyscraper -p amiga -s screenscraper --query "romnom=xenon%202" Xenon_2_Megablast_CD32.cue
                          But "romnom=xenon%202" is not a good match for the ScreenScraper romnom query. I suggest using --query sha1=SHA1SUM instead where you substitute SHA1SUM with a rom's sha1 sum that you have found for the correct game on their website.
                          • George SpiggottG
                            George Spiggott
                            Thanks @muldjord The "xenon+2" bit works because "/opt/retropie/supplementary/skyscraper/Skyscraper -p amiga -s screenscraper --query romnom=xenon+2 Xenon2_v1.7_CDTV.lha" scrapes no problem. I have the scraped image now from that file/scrape. My plan is to get Skyscraper use a local image now I have it.
                            I tried sha1 and crc, neither of them work. For some reason it just doesn't like my .cue/.iso copy of Xenon 2 CDTV.
                            Scraping for Amiga can be a bit tricky especially if, like me, you're determined to use specific roms rather than common ones.
                            Currently running:
