    How can I use a USB DVD Drive without having to mount it?
    helpphysical disc
    31 Posts 5 Posters 5.1k Views
      Clyde @RetroFloppy08
      @RetroFloppy08 See https://www.raspberrypi.org/documentation/configuration/external-storage.md (edit:) and https://wiki.debian.org/CDDVD.
        RetroFloppy08 @mitu
        @mitu What after ?
        mount
          mitu Global Moderator @RetroFloppy08
          @RetroFloppy08 You need to learn to use it - @Clyde's 2nd link is pretty extensive.
            RetroFloppy08 @mitu
            @mitu the only problem is: I have no idea what i'm doing. I've implemented a seperate folder that can (partially) run Scratch, and thats practically all i've done to modify the core of the sd card.
            Could you possibly provide me with a full command that can mount a dvd drive?
              @RetroFloppy08 said in How can I use a USB DVD Drive without having to mount it?:
              Unlikely - your questions are rather vague and don't provide enough context in order to determine what you're trying to achieve and what you've done so far/what does not work.
              That's probably the reason why there's no solution or clear advice for you here.
                RetroFloppy08
                Ok, so i read an (Official) documentation on how to mount one (using the command line, modifying a file), and it still doesn't work. I think I should just about give up.
                  Clyde
                  Sorry, but you're still not giving enough information. Which documentation did you read? What exactly did you try, what should have happened, and what did or didn't? Where there any messages?
                  If you want to continue your endeavor, please copy & paste your exact command(s) and any output from them.
                    RetroFloppy08 @Clyde
                    @Clyde Ok, I literally just realized it wasn't official but here's the guide anyway: https://www.raspberrypi-spy.co.uk/2014/05/how-to-mount-a-usb-flash-disk-on-the-raspberry-pi/
                    I'm using an LG M-Disc R&W USB Disc Drive, and a Raspberry Pi 3B 1.2, running Retropie... idk. I'll check later.
                    I modified a file that was meant to run commands on startup, as well as other commands.
                    Instead of getting the intended result, it just created some files and mounted absolutely nothing.
                    It was supposed to read from the disc at startup and, through the Retroarch Menu, load the contents of the disc and run them.
                    I'm starting to think this is a hardware problem.
                      RetroFloppy08
                      Still no luck.
                      Gonna get a Raspberry Pi 4.
                        RetroFloppy08
                        NVM, I updated to 4.6, and it recognizes the disc but there's 1 problem:
                        It boots me out as soon as it loads.
                        Please Help???
                          dankcushions Global Moderator @RetroFloppy08
                          @RetroFloppy08 please fill out https://retropie.org.uk/forum/topic/3/read-this-first
                          • dankcushionsD dankcushions referenced this topic on
