    Running jstest causes small issue when restarting Emulationstation
    jstestretropie 4.6emulationstatio
    5 Posts 2 Posters 565 Views
    • RiverstormR
      Riverstorm
      It's not a big issue but I thought I would mention it. Running RP 4.6.2 (af6f0e1e) & ES 2.9.1RP on a Pi 4. When exiting ES and running jstest /dev/input/js0 everything works fine. When you exit with CTRL-Z it shows [1]+ Stopped jstest /dev/input/js0. Then when you type exit to restart ES it shows logout--There are stopped jobs. and you have to type exit a second time to start ES. It doesn't hurt anything but I thought I would mention it if it's a small bug.
      • I
        IyonUK @Riverstorm
        @Riverstorm hi, you’re not closing the process but suspending it
        https://askubuntu.com/questions/510811/what-is-the-difference-between-ctrl-z-and-ctrl-c-in-the-terminal
        • RiverstormR
          Riverstorm
          @IyonUK - Ok, thanks for the information I appreciate it. Is there a proper way to close it so you don’t have to type exit twice?
          • RiverstormR
            Riverstorm
            @IyonUK - Jinkies, reading it now, thank you!
            • I
              IyonUK @Riverstorm
              @Riverstorm no worries. 😊
