    Low Resolution Theme
    84 Posts 10 Posters 61.8k Views
    • gamer85G
      gamer85 @Rookervik
      @Rookervik Wanted to report back with feedback after using Pixel for TFT Displays 0.1. Its really perfect for using a small screen. You can read the titles and really see scan art. I will post some pictures below. One item, its missing art work for emulator sdltrs ie TRS-80 computer. Will this be something you can add?
      RookervikR 1 Reply Last reply Reply Quote 0
      • RookervikR
        Rookervik Global Moderator @gamer85
        @gamer85 Yeah I never made trs80 since it is extremely close to the Coco (I think anyway.) Herb made me make trs80 for Carbon, so I will need to do it for Pixel. Soooo, give me a little time and I'll update it.
        gamer85G 1 Reply Last reply Reply Quote 0
        • gamer85G
          gamer85 @Rookervik
          @Rookervik Thank you. Appreciate your efforts. Hope this theme gets added to Retropie distribution (under the optional user theme )/
          • RookervikR
            @gamer85 Yeah everywhere I look I see pictures of the TRS80... Color Computer. Which is CoCo. I can't find any decent pictures of the TRS80 Model 1. I'm wondering if we can't just call this an upgrade like we do with C64/128 and all the different Amigas. I'd hate to think of doing DOS and drawing all the different generations of DOS-wielding computers.
            • gamer85G
              gamer85 @Rookervik
              @Rookervik the problem is that the TRS-80 Model 1 and TRS-80 Model 3 (the update to the Model 1, there was no Model 2) are completely different architecture and OS than the CoCo. Can you use the TRS-80 Model 3 as basis for the icon instead of the Model 1? If you search TRS-80 Model 3, do you find enough images to build the icon? If not I can post many images of the TRS-80 Model 3 here in this thread.
              • RookervikR
                Model 3 looks like the keyboard is attached to the screen and diskette drives... is that the correct one to use? I found a lot of pictures of that.
                herb_fargusH gamer85G 2 Replies Last reply Reply Quote 0
                • herb_fargusH
                  herb_fargus administrators @Rookervik
                  @Rookervik the sdltrs emulator emulates the model 1-4p so any will technically work ;) I like the look of the model 1 but you're the one doing the art so if the available resources are better for you with the model 3 then do whatever works best for you :)
                  Your skills are appreciated :D
                  • gamer85G
                    gamer85 @Rookervik
                    @Rookervik Here are pictures of the two models. The top image is the TRS-80 Model I. The bottom image is the TRS-80 Model 3. Let me know if you have any questions. Thank you again for your help with this request.
                    • InsecureSpikeI
                      InsecureSpike
                      theres my take on a TFT theme, i took Rookervik's theme and edited it a lil,
                      basically-tft
                      https://www.dropbox.com/s/2jbxvq560inaufx/basically-tft.zip?dl=0
                      only tested on a tv
                      RPi 3 - RetroPie + 500gb HDD [consoles] + Razer Onza Tournament
                      RPi 3 - RetroPie + 32gb USB [computers] + Keyboard
                      both with AttractMode + FuzzBoxx Layout
                      • RookervikR
                        @gamer85 Ah that's perfect. I'll do the Model 1 you found. I couldn't find an image that clear.
                        gamer85G 1 Reply Last reply Reply Quote 1
                        • gamer85G
                          gamer85 @Rookervik
                          @Rookervik Great. Let me know if there is anything else I can help out with.
                          • RookervikR
                            Pixel TFT 0.2 Now with more TRS-80 ACTION!
                            Updated Pixel with TRS-80, so I also added TRS-80 to the TFT version.
                            -Sorry for the Genesis games, I don't have TRS-80 so I just tested with Genesis. Bad screenshot, too. Looks better in ES.
                            undefined
                            Download Pixel TFT 0.2: https://db.tt/STeV9NLf
                            • gamer85G
                              gamer85 @Rookervik
                              @Rookervik Thank you for the update. Looks awesome, but if you want feedback, I have just one suggestion. The TRS-80 Model I and TRS-80 Model III did not display color. Your header theme looks great, but the three color bars (red, green & blue) that you are using in pixel-tft_0.2 were part of the CoCo logo not TRS-80 Model I and Model III. One suggestion would be to remove the 3 color bars and make the TRS-80 text bigger to match the same font as Radio Shack. I have included a picture of the TRS-80 Model I power supply to get an idea of what the original text looked like. Also I have included two game images to give you an idea what the actual graphics looked like. The last image is the CoCo (Color Computer) where you can see the logo in the upper right corner. Again, those color bars were not part of the Model I and Model III.
                              • RookervikR
                                @gamer85 GOSH! I'll fix it one day. TRS-80 has given me more problems than any other system. Promise I will fix it. Soonish. :D
                                gamer85G 2 Replies Last reply Reply Quote 2
                                • gamer85G
                                  gamer85 @Rookervik
                                  @Rookervik No rush. Your talent and work is brilliant. Much appreciated.
                                  • RookervikR
                                    @gamer85 Before I go and waste time drawing it in pixel, will this logo suffice?
                                    undefined
                                    • gamer85G
                                      gamer85 @Rookervik
                                      @Rookervik Looks perfect to me. Thank you.
                                      • RookervikR
                                        @gamer85
                                        Ok, links have been updated with new TRS-80 logo. Download from previous link: https://db.tt/STeV9NLf
                                        • gamer85G
                                          gamer85 @Rookervik
                                          @Rookervik The TRS-80 Model I/III Icon looks great. Fantastic job. Thank you.
                                          • gamer85G
                                            gamer85 @Rookervik
                                            @Rookervik wanted to mention that pixel-tft_0.2 was missing the Texas Instruments TI-99 4A icon. Just an fyi if you ever have time to add. Absolutely no rush and no urgency. I have included a few images of the TI-99 4A for your review. Again, understand if this item is something that you may not be able to get to.
