    Vertical Games in a cocktail mode not going vertical
    vertical gamesvertical screen
    5 Posts 3 Posters 557 Views
      j_infamous
      Games like pac man and 1942 are displaying as horizontal and not vertical. I am using a 1080 hdtv and a pi4. Any help would be excellent! Thank you in advance.
        mitu Global Moderator @j_infamous
        @j_infamous Please add more info about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        What emulator are you using ?
          j_infamous
          Pi Model or other hardware: 4gb 4b
          Power Supply used: canakit one
          RetroPie Version Used 4.6 i believe
          Built From: retropie site
          Using mame2003 with the 0.78 set.
            Cocktail mode doesn't rotate the screen, it will flip it when alternating between players. Have you rotated you display and expected that cocktail mode would also rotate the video ?
              dankcushions Global Moderator
              https://retropie.github.io/RetroPie-Docs/lr-mame2003/#tate-mode may be of use
