    Control issues in retropie 4.6 mame2003plus
    mame2003-plus
    3 Posts 3 Posters 317 Views
      BlancoLoco
      I currently have 2 joystick setups, a dolphin bar and a trackball in trying to setup. I somehow messed up the control options from the tab menu in golden tee 2 and now the joysticks do not work in any games. I'm seeing that I need to set that back to digital from the tab menu but I can no longer get to that menu using tab either. This will not work from any game now. What is the best option to get that reset and how do I get all of these working properly. Thanks in advance. #RespectTheGames
        mitu Global Moderator @BlancoLoco
        The input configuration is stored in <rom_folder>/mame2003/cfg/, general input is in default.cfg, game specific inputs are stored as <gamename>.cfg.
        To restore the inputs to default, delete the corresponding file.
          mahoneyt944
          You can access the mame menu from retroarch as well. There should be a setting under options to turn on the mame menu. Then you can remap the menu toggle button under general inputs.
