    Problem with HDMI and RCA
    hdmircaretropie4b model
    9 Posts 2 Posters 1.6k Views
      Composer
      Hello everyone;
      Im in a project that consist on put a Raspberry Pi 4B in a PS1 case. And i wanna use the HDMI port and the RCA port.
      Now i can get image with the RCA with a 240p resolution, but when i reboot the raspberry with the HDMI plugged and the RCA unplugged i didn't recieve any image.
      I have a mini Jack to females RCA and a microHDMI to male HDMI and a Female HDMI to Female HDMI connected.
      Any help??
      Os paso mi archivo config.txt
      This is my config.txt
      # http://rpf.io/configtxt
      #hdmi_safe=1
      disable_overscan=1
      overscan_left=16
      overscan_right=16
      overscan_top=16
      overscan_bottom=16
      # overscan.
      framebuffer_width=352
      framebuffer_height=240
      hdmi_force_hotplug=1
      #hdmi_group=2
      #hdmi_mode=4
      #hdmi_drive=2
      # no display
      config_hdmi_boost=4
      # uncomment for composite PAL
      enable_tvout=1
      #sdtv_mode=0
      sdtv_aspect=1
      sdtv_mode=2
      #arm_freq=800
      #dtparam=i2c_arm=on
      #dtparam=i2s=on
      #dtparam=spi=on
      # Uncomment this to enable infrared communication.
      dtparam=audio=on
      [pi4]
      # Enable DRM VC4 V3D driver on top of the dispmanx display stack
      dtoverlay=vc4-fkms-v3d
      max_framebuffers=2
      [all]
      #dtoverlay=vc4-fkms-v3d
      overscan_scale=1
      Thank you!
        @Composer said in Problem with HDMI and RCA:
        enable_tvout=1
        Remove/comment the line above and the HDMI output should work.
          Composer @mitu
          @mitu said in Problem with HDMI and RCA:
          enable_tvout=1
          But when i comment this line i cant use the RCA.
          I need to use the HDMI and when i disconnect the HDMI i need to use the RCA without edit the config.txt file.
          Thanks for the quick answer!
            That's not possible on the Pi4 - it worked on previous models though. On the Pi4, you need to explicitly enable the analog output, since it's disabled by default:
            Cf. https://www.raspberrypi.org/documentation/configuration/config-txt/video.md:
            On the Raspberry Pi 4, composite output is disabled by default, due to the way the internal clocks are interrelated and allocated. Because composite video requires a very specific clock, setting that clock to the required speed on the Pi 4 means that other clocks connected to it are detrimentally affected, which slightly slows down the entire system. Since composite video is a less commonly used function, we decided to disable it by default to prevent this system slowdown.
              Composer @mitu
              oh... i see, there is a fix or workaround to do that i need?
                mitu Global Moderator @Composer
                @Composer There's no fix - you'll have to workaround having different configuration files or using some conditional configuration.
                You can have 2 different files - one for RCA and one for HDMI video output - and switch between them with a pair of scripts that you can call from the RetroPie menu. You can drop any .sh script in $HOME/RetroPie/retropiemenu and they'll appear in the RetroPie menu in EmulatonStation, you can execute the script (that switches the configuration) and then reboot.
                A conditional config.txt could also work. One method that might work is to have flip switch that you can toggle to activate a GPIO pin, then you can put the enable_tvout option behind this GPIO condition
                [gpio4=1]
                # Settings here are applied if GPIO 4 is high
                enable_tvout=1
                [all]
                enable_tvout=0
                If you decide on this approach, I'd encourage you to ask in the Raspberry PI forums for confirmation that it would work - I haven't tested it.
                C M 2 Replies Last reply Reply Quote 0
                  Composer @mitu
                  @mitu Ok i see...
                  To use the GPIO i need to connect the switch to a GPIO that give 5v right?
                  And to have a workaround.... can i have a menu like another emulator that give me the option to run a script to change the config file?
                  Thank you!
                    @mitu Ok i see...
                    Probably one of the ground pins.
                    Yes, I just explained that in my previous post.
                      Composer @mitu
                      @mitu Oh Sorry!!
                      My english is very bad jaja.
                      So.. im gonna to try the scripts and when i have a switch im gonna try it connecting it to ha 5V and ground GPIO.
                      Thank you so much!
                      • mituM mitu forked this topic on
                      • mituM mitu referenced this topic on
