    Using Retropie From Within Raspbian
    amigaamiga retropiearmraspbian
    3 Posts 2 Posters 500 Views
      JonnyAlpha
      Hi;
      Bottom line up front - I am building an Amiga and want the machine to boot into Amiberry when the device is switched on - simulating a real Amiga.
      Background:
      I built a Desktop Arcade machine using an Intel board, Linux Mint OS and Retropie installed. I wanted to be able to use an Amiga Emulator and everyone was saying that Amiberry is the way to go, however Amiberry will not work in a Non Arm environment.
      So what I decided to do was to install Amiberry onto an existing Raspberry Pi but as a stand alone, but cannot seem to find out how.
      So next option is to install a slimmed down version of RetroPie with Amiberry, but I want to run it from Raspbian.
      Can anyone help?
      This will be on a Rapberry Pi 3
        Clyde
        If you're using a Pi and it shall boot into Amiberry directly, why do you want to use a full Raspbian installation? The raspbian desktop will add some unneccessary system load, while RetroPie doesn't come with a desktop. There's even a comprehensive installation guide for Amiberry on RetroPie:
        https://github.com/midwan/amiberry/wiki/Using-Amiberry-with-RetroPie---Installation-and-Setup
        You may also want to look at this thread from 2016 about booting directly into Amiga:
        https://retropie.org.uk/forum/topic/3405/boot-directly-into-amiga
        Disclaimer: I don't have any experience with Amiberry on RetroPie, just with RetroPie itself and emulators for other systems on it.
        edit: Two more threads I stumbled upon.
        https://retropie.org.uk/forum/topic/24698/how-to-boot-directly-in-to-amiga-emulation
        https://retropie.org.uk/forum/topic/12656/amiga-amiberry-whdload-holy-grail-amiberry-s-official-thread
          JonnyAlpha
          Many thanks - some great links.
