    retropie wifi problems
    help
    5 Posts 2 Posters 346 Views
      jack28090
      Press J to jump to the feed. Press question mark to learn the rest of the keyboard shortcuts
      RetroPie
      Posts
      1
      Posted byu/jack28090
      28 minutes ago
      gpi case wifi problems
      Sorry, this post has been removed by the moderators of r/RetroPie.
      Moderators remove posts from feeds for a variety of reasons, including keeping communities safe, civil, and true to their purpose.
      i just bought a retroflag gpi case and a raspberry pie zero W I hooked everything up installed the screen patch but no mater what i try it will not connect to my 2.4 wifi i tryed the code:
      country=US
      ctrl_interface=DIR=/var/run/
      wpa_supplicantGROUP=netdev
      update_config=1
      network={
      ssid=" my ssid"
      psk="password"
      key_mgmt=WPA-PSK
      priority=1
      after checking to make shure it was a conf file ext and double and triple checking my ssid and password and failed then i decided to go into my router and open the network with no password at all it still says "unable to connect to network'
      im stuck please help
        jack28090
        country=US
        update_config=1
        network={
        ssid=" my ssid"
        psk="password"
        key_mgmt=WPA-PSK
        priority=1
          You already posted a topic with your problem - there's no need to open another one. Topics merged.
          What version of RetroPie are you using and how did you install it - see the details asked in https://retropie.org.uk/forum/topic/3/read-this-first.
          Are you sure you're formatting correctly the file ? The way you posted its contents, it doesn't look like it. Try
          country=US
          ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
          update_config=1
          network={
          ssid=" my ssid"
          psk="password"
            jack28090
            it should be the latest version because i downloaded it yesterday i used windows disk imager the file don't matter anymore because my wifi is now open
              jack28090
              retropie-buster-4.6-rpi1_zero is the file i used
              (sorry for the double post)
