    USB wifi dongle and retropie
    wifi
    14 Posts 3 Posters 2.5k Views
      Donkbot
      I bought a Foktech AC600 USB wifi dongle (linux compatible apparently) so I could connect my rasberry pie to my network. However, when I goto set the wifi region it says that no wireless interface has been found. I've searched all over for a guide on installing a wifi dongle on retopie, but they all start with setting the wifi region. I'm expecting to install some drivers or something, but being a total newbie to retropie and linux in general I have no idea how.
      Thanks for any help
      • IanDaemonI
        IanDaemon
        What model Pi are you using? Wifi may be built-in thus not needing a dongle.
        Why the double topics?
        • Cocktail Cabinet Games
        • Check out the MAME RoW
          Donkbot
          oops, my mistake, didn't see topic appear so reposted. Can remove now
          I have a raspebery 2 i think, thats whats written on the board
          IanDaemonI 1 Reply Last reply Reply Quote 0
          • IanDaemonI
            IanDaemon @Donkbot
            @Donkbot https://www.electronicshub.org/setup-wifi-raspberry-pi-2-using-usb-dongle/#:~:text=Setting up WiFi on Raspberry,adapter like a WiFi Dongle.
            Does this help?
            • IanDaemonI
              IanDaemon
              Sounds like you could use dmesg | more to check things out, but then you still have to configure the dongle.
                Donkbot
                Thanks, I'll have a go, presumeably there is a way of accessing the linux CLI from retropie
                • IanDaemonI
                  IanDaemon
                  The terminal? Just press F4 or "quit 'emulation station'" if you're using that. Where are you?
                  Exit to command line/terminal.
                    Although the vendor page says there's no Linux support, it looks like it's using the RTL 8821CU chipset, so it might work by installing the driver from https://github.com/brektrou/rtl8821CU.
                      Donkbot
                      I exited emustation and dropped into a CLI. entered "dmesg | more " and it returned Command not found
                      I'm in the UK
                      Really? just checked the amazon page where I bought it and your right, that'll teach me not to read the specs carefully
                      So im assuming a supported dongle would be pretty much plug & play?
                        mitu Global Moderator @Donkbot
                        @Donkbot said in USB wifi dongle and retropie:
                        You need to leave spaces around the pipe character (|).
                        If it's supported by the Linux kernel, then yes.
                          Donkbot
                          Thought I has done that, anyway working now.
                          Looks like the device is being recognised, I can see:
                          usb 1-1.2: new high-speed USB device number 6 using dwc_otg
                          usb 1-1.2: New USB device found, idVendor-Obda, idProduct=c811, bcdDevice= 2.00
                          usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                          usb 1-1.2: Product: 802.11ac NIC
                          usb 1-1.2: Manufacturer: Realtek
                          usb 1-1.2: SerialNumber: 123456
                            Donkbot
                            Do I still need to install I a driver I wonder? That guide seems to go straight onto configuring the wifi (which I thought could be done through retropie-config)
                              Donkbot
                              Also, that driver on githib doesn't appear to have any releases. Am I going to have to build the project first?
                                There are installation instructions (using dkms) on the project page - there's no need for a 'release'.
