    No sound on LZDOOM on RPI4
    alsadoomlzdoomsound
    21 Posts 4 Posters 7.0k Views
      RussellB
      Hi all,
      I think my sound set on RPI4 updated because now lzdoom does not generate sound at all. It used to work fine. I have not performed any updates though I have installed other packages.
      lzdoom now generates: AL lib: (EE) ALCplaybackAlsa_mixerProc: Wait timeout... buffer size too low?
      After it opened the ALSA Default device.
      I read the post here: https://retropie.org.uk/forum/topic/26628/audio-issues-after-latest-raspbian-updates/8
      I modified my cmdline.txt to 'revert' back but it looks like these changes are incompatible with lzdoom.
      Has anyone else experienced this?
      RussellB
        BuZz administrators
        More info about your system would be useful. Which change did you make to cmdline.txt? Using built in audio? Please fill out info as detailed in link in my signature
        I'll test lzdoom but it worked last time I tried on my rpi4.
          RussellB @BuZz
          @BuZz
          The first post in the link I mentioned said to 'revert' back to the settings by adding this to cmdline.txt:
          snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_compat_alsa=1
          I did that and it didn't do anything for lzdoom. I tested multiple emulators, BGM, ES and they all have sound except for lzdoom.
          I'm using built-in audio, HDMI.
          Pi Model or other hardware: 4, 4GB
          Power Supply used: 5.1V, 3000mA
          RetroPie Version Used: 4.5.18
          Built From: Buster Base
          USB Devices connected: USB keyboard and mouse, 2TB WD Essentials 3.0 drive
          Controller used: 2 Logitech F710 controllers
          Error messages received: AL lib: (EE) ALCplaybackAlsa_mixerProc: Wait timeout... buffer size too low?
          Verbose log (if relevant): No
          Guide used: No
          File: N/A
          Emulator: lzdoom
          I ran into this issue when I did a firmware and OS update and I ended up reverting back to an older OS. I think lzdoom is making some bad assumption about the default ALSA sound device.
          RussellB
            BuZz administrators
            Remove any added lines, and do an update of packages
            sudo apt update: sudo apt dist-upgrade
            I will test lzdoom shortly if it's at fault.
              BuZz administrators
              You installed manually btw? How are you starting emulationstation?
                BuZz administrators
                Sound works fine here with lzdoom btw. Kernel 5.4.51 / rpi4 with no changes to audio settings.
                I will need more info and examples of logs to advise. An install log for lzdoom also as it gives some info on kernel etc. Can use a pastebin site for logs.
                  BuZz administrators
                  Sorry. Just noticed your retropie is also massively out of date, I recommend updating.
                  [Correction - not massively, but your kernel may be out of date also]
                    RussellB
                    I updated the kernel to 5.4.59-v8+, as well as the OS and the issue is still happening.
                    Here is my runcommand.log: https://pastebin.com/9uMpK3WG
                    and aplay -l: https://pastebin.com/HYrNYXQ0
                    It looks like lzdoom can't open the default device anymore. I'll try building lzdoom from source and see if that makes a difference.
                      Try renaming the lzdoom.ini file (should be visible in \\retropie\configs\ports\doom) and re-starting the game again.
                      RenetroxR 1 Reply Last reply Reply Quote 0
                        RussellB
                        Same thing. No sound.
                        Without lzdoom.ini here is the runcommand.log: https://pastebin.com/W7XUaRTi
                        I'm now also getting this message:
                        "lvl0: VolumeControl::init() - Failed to find mixer elements!"
                          RussellB @RussellB
                          So following this thread:
                          https://retropie.org.uk/forum/topic/23954/audio-not-working-rpi3b
                          I was able to fix this message I was encountering:
                          ALSA lib control.c:1373:(snd_ctl_open_noupdate) Invalid CTL hdmi
                          1v10: VolumeControl::init() - Failed to attach to default card!
                          lzdoom is the only software that is having a problem with sound. Splash screen, BGM, ES videos and other games I've tested all work.
                            RussellB
                            For posterity...
                            I found this wiki page: https://zdoom.org/wiki/Compile_ZDoom_on_Raspberry_Pi
                            I added .alsoftrc to /home/pi and put this in:
                            [alsa]
                            mmap = false
                            And voila... all sounds and music came back.
                            I hope this helps someone. It was driving me crazy.
                            • RenetroxR
                              Renetrox @mitu
                              @mitu this is related to pulseaudio. I discovered that I can use "apulse", just type in terminal: apulse lzdoom to have sound with pulseaudio uninstalled, but ... How do I create a shortcut for emulationstation telling it to use "apulse" together with the game?
                                mitu Global Moderator @Renetrox
                                @renetrox said in No sound on LZDOOM on RPI4:
                                I'm not sure your issue is related to the error reported in this topic. apulse is a 'fake PulseAudio' implementation for programs that need PulseAudio - the fact that a program needs it means it was compiled with PulseAudio and expects it to use it - but lzdoom is not using PulseAudio on the Pi. Are you using a Pi or some other platform ?
                                • RenetroxR
                                  Renetrox @mitu
                                  @mitu Lzdoom does not produce any sound without pulseaudio. I have tried all kinds of proposed solutions for that problem, that's why I got to "apulse" because I discovered that it emitted sound by analog when I installed pulseaudio. This on a raspberry pi 3b
                                    @renetrox Looks like a different problem then the one in this topic, so I advise to open a separate topic, add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first and post the lzdoom.ini configuration file (use pastebin.com for posting the file, since it's quite large).
                                    RenetroxR 3 Replies Last reply Reply Quote 0
                                    • RenetroxR
                                      Renetrox @mitu
                                      @mitu I appreciate your answer, but I don't think it goes out of context. lZdoom has no sound. I applied the solution proposed here without success, that's why I shared my experience. If you can't tell me how to create an access in emulationstation telling the system to use "apulse" then there isn't much to add. At the moment I don't directly use that emulator, I wanted it for action doom 2 and brutal doom, I can live without that;)
                                      i will share the lzdoom.ini file in case it helps anyone
                                      RenetroxR 2 Replies Last reply Reply Quote 0
                                      • RenetroxR
                                        Renetrox @Renetrox
                                        This post is deleted!
                                        • RenetroxR
                                          Renetrox @Renetrox
                                          @renetrox https://pastebin.com/me3a1JNV
                                          • RenetroxR
                                            Renetrox @mitu
