    Backup from 32gb card and restore to 64gb card
    retropie
    28 Posts 3 Posters 4.0k Views
    • X
      xNYARLx
      And i save, off game and when run game again my config not saved, and for another game not saved too.
        mitu Global Moderator @xNYARLx
        @xNYARLx This looks like the Shader settings in RetroArch's Ozone menu . There is no shader configured by default in RetroPie and the RetroArch's menu is configured with RGUI (not Ozone). So you're either not using the RetroPie image or you changed those settings yourself - which one is it ?
        X 1 Reply Last reply Reply Quote 0
        • X
          xNYARLx @mitu
          @mitu i change theme myself to ozone but i still dont can save settings :( and change this what i say. And i do this what u say, but dont work... with font.20200919_170526.jpg
            This should work:
             CONFIGURATION FILE FOR SETUPCON
            # Consult the console-setup(5) manual page.
            ACTIVE_CONSOLES="/dev/tty[1-6]"
            CHARMAP="UTF-8"
            CODESET="guess"
            FONTFACE="Lat2-Terminus"
            FONTSIZE="22x11"
            VIDEOMODE=
            # The following is an example how to use a braille font
            # FONT='lat9w-08.psf.gz brl-8x8.psf'
            Since this is a system file, you need to use the root account to edit it - from the console, you can run
            sudo nano /etc/default/console-tools
            and do your edits.
            • X
              xNYARLx @mitu
              @mitu Don't work. Still don't have polish letters. (yes i edit this in this way, only foto i make from computer from wordpad)
                Can't why it's not working, works on my system (based on Raspbian Buster).
                • X
                  xNYARLx @mitu
                  @mitu i don't know why. On another cards with Raspbian and Kodi i have polish letters there no :/
                  I see some errors when i try change keyboard layout in raspi-config - console says not found anything
                  and this error Volume control init: Failed to find mixer elements im fix this
                  • X
                    xNYARLx
                    I have this problem:
