    8BitDo SF30 not working in retroarch, "not configured"
    8bitdobluetoothretroarch
    11 Posts 4 Posters 10.2k Views
    • UberLumbyU
      UberLumby @xwons
      @xwons I got the 8bitdo bluetooth adapter.
      I know that doesn't help your current situation, but I was never really fond of the on board bluetooth. It was always temperamental when I used it. It's strange though how retroarch isn't picking it up. I'm assuming you configured it in the start menu in emulation station right?
      [Linux 5.10.103-v7+ armv7l GNU/Linux
      Retropie 4.8
      Raspberry Pi 3B+]
      X 1 Reply Last reply Reply Quote 0
        mitu Global Moderator @xwons
        @xwons said in 8BitDo SF30 not working in retroarch, "not configured":
        To sum up, the bluetooth controller works in EmulationStation and Kodi, but not in the games (retroarch).
        This means the Input Configuration in EmulationStation didn't generate the RetroArch gamepad auto-configuration file. It does this by default, did you disable the gamepad auto-configuration from Configuration/Tools in RetroPie-Setup ?
        • X
          xwons @UberLumby
          @UberLumby Thanks for your answer. Yes, I configured it in EmulationStation. Actually, it detected that there was a new device on boot (I restarted after pairing it) and asked to configure it, without any issues. Except if it was paired in Windows mode (Start+X), where it detected there was a gamepad but the controls did not respond.
          @mitu I don't think I have disabled anything manually, everything is pretty much by default, except making Kodi run on startup instead of EmulationStation. I checked the retroarch option, but there isn't anything related to auto-configuration there. In bluetooth devices, I paired the controller, I set up the udev rule and set the bluetooth connect mode to boot, leaving the 8Bitdo mapping hack OFF (because I use the last firmware), which seems to work because the controller is paired as soon as I turn it on and I can see it in jtest. I believe retroarch is actually able to "see" the controller, as it states that it is "not configured" when it starts.
          This problem seems to be quite common with this controller, as a quick search on this forum demonstrates:
          https://www.google.com/search?q=retropie+8bitdo+bluetooth+retroarch+site:retropie.org.uk
          Is there any way to force retroarch to re-generate its controller mapping? Or to trigger a remapping dialog from command line? (similar to the one in ES, where it asks you to press each key).
          Also, why does it not respond in Windows mode, the one that supposedly is recommended by the retropie documentation? How can I troubleshoot that?
          At the end of the day, I don't mind which mode I use as long as it works.
          (Oh, by the way, I am configuring this retropie machine remotely via ssh, so I don't have a local keyboard to enter the retroarch menu once a game has started)
            It's in emulationstation's options.
            None of the above should be necessary.
            Not quite - there are a lot of posts about 8Bitdo controllers because they are used extensively. With your similar issue ? Not so many.
            Re-generation is done by re-configuring the device in EmulationStation.
            Where exactly is that recommended ?
            Once you get to pair the controller, use jstest to test the gamepad and see if it accepts inputs. Note that Xinput mode has a timeout issue when used in RetroArch - see here.
            Pair manually via bluetoothctl.
            • X
              xwons @mitu
              @mitu said in 8BitDo SF30 not working in retroarch, "not configured":
              Ok, I will check that out this afternoon when I have the chance.
              It is the recommended procedure as explained in https://retropie.org.uk/docs/8Bitdo-Controller/ but anyway, I think that part already works.
              Ok, that's fair, I read a number of posts with people with the exact same problem using the same gamepad, and some reported that once the gamepad was configured in Windows mode, the problem disappeared. That is why I wanted to try it.
              The thing is that it pairs, I can see the button presses in jstest (except in windows mode), and it works in EmulationStation and Kodi. I meant how to troubleshoot why windows mode is not registering keypresses in jstest.
              Also, according to the manual, after mapping it in EmulationStation:
              1. When that is complete your 8bitdo controller is ready to use!
              The process will have written various controller configuration files for you. The main RetroArch controller file will now be in: /opt/retropie/configs/all/retroarch-joypads/
              But that folder is empty in my Raspberry Pi. I tried downloading the keymap file from https://github.com/libretro/retroarch-joypad-autoconfig/blob/master/udev/8BitDo_SN30_Pro%2B_BT_B.cfg and changing the input device to my controller's actual input device name "8Bitdo SF30 Pro" (obtained from cat /proc/bus/input/devices), but that did not work either.
                Run cat /proc/bus/input/devices and udevadm info -q all /dev/input/js0 to see if it's registered as a gamepad.
                If it's empty, check your gamepad auto-configuration option in EmulationStation or the EmulationStation's log file ($HOME/.emulationstation/es_log.txt).
                • X
                  xwons @mitu
                  @mitu Ok, I will try both things this afternoon, when the person to whom I am configuring the raspberry and has access to the controller comes home, and report back. Thanks so much for your time so far!
                  • X
                    xwons
                    Ok, so I noticed that the controller was not the SN30 Pro, but the SF30 Pro. I manually copied the gamepad autoconfig file and placed it in 8Bitdo_Pro_SF30_BT_B.cfg (from the link above), and now it seems to work in raspbian! However, the hotkey does not work, so I can't exit any games. But progress is progress. And that still does not explain why emulationstation did not generate the config file by itself...
                    • X
                      xwons
                      Ok, I finally managed to make the hotkeys work.
                      I needed to add the following section in /opt/retropie/configs/all/retroarch-joypads/8Bitdo_Pro_SF30_BT_B.cfg
                      #Hotkeys
                      input_enable_hotkey_btn = "10"
                      input_load_state_btn = "7"
                      input_exit_emulator_btn = "11"
                      input_reset_btn = ""
                      input_save_state_btn = "6"
                      input_menu_toggle_btn = "3"
                      Problem solved!
                      • L
                        lucianthorr
                        Just wanted to say Thanks for this question and answer. I had been struggling to get my 8bitdo Ultimate Wireless controller working in the games also and it turned out to be the same issue.
                        Adding /opt/retropie/configs/all/retroarch-joypads/8BitDo_Ultimate_wireless_Controller.cfg from https://github.com/libretro/retroarch-joypad-autoconfig/blob/master/udev/8BitDo_SN30_Pro%2B_BT_B.cfg worked.
                        As a total RetroPie/EmulationStation/RetroArch newbie, how is anyone supposed to know that they needed to manually add these controller configs? Is it supposed to be an automated system that's just not working correctly because I never saw any documentation anywhere that pointed users to the libretro GitHub.
