    Is it possible to run FUSE (ZX Spectrum emu) at over 100% speed?
    fusespectrum
    6 Posts 2 Posters 1.0k Views
      SuperFella
      Question as per title, really. FUSE itself allows up to 500% speed with sound, is there any way to get it above 100% in the Retropie version?
        There's no 'RetroPie' version of Fuse, when you install Fuse you get the same version as the upstream project (fuse-emulator.sf.net), so you should have the same options - including increasing the speed of the emulator.
          SuperFella @mitu
          @mitu I thought that and I've been trying to figure out where they might be hidden, but I've drawn a blank, hence my query. I tried a CFG file with
          speed = "200"
          but that did nothing. F4 is supposed to bring up the menu where speed is located but that did nothing either.
            SuperFella
            Sorry - just realised I should have been clear that by "Retropie version" I was talking about lr-fuse. Didn't realise there was a "bare" version. But I just tried that, and while F4 does bring up the menu and allow you to select 200% speed, it still doesn't actually work. When you go back to the game it's still at normal speed.
              I find it that saving the settings and then re-starting the game works.
                SuperFella @mitu
                @mitu Nope, did nothing, just reverted to 100% when I quit reloaded. And wouldn't be much use anyway, as I want to play it specifically in lr-fuse.
