    Box86 and Wine on RPi4
    box86wineqemux86windows
    475 Posts 40 Posters 283.8k Views
    • shavecatS
      shavecat @mth75
      @mth75
      Thanks a LOT !!!
      doing it now .
      After the boot wine i got this -
      pi@retropie:~/Downloads $ wine wineboot
      Box86 with Dynarec v0.1.5 1e20a9ef built on Nov 14 2020 01:22:25
      0024:err:environ:run_wineboot failed to start wineboot c000007b
      wine: could not load kernel32.dll, status c000007b
      Thats OKAY ???
      After that how can i run the games ?
      like with exe file form sh file ???
      now think im lost a bit ;
        mth75 @shavecat
        @shavecat said in Box86 and Wine on RPi4:
        OKAY ???
        No, that's not okay. Check your file permissions/ownership?
        you can start simply (if your install is ok) with: wine <gamename>.exe
          mth75 @mth75
          @mth75 Btw, that's an old Box86 version, my Dynarec version on the Pi400 Desktop is v0.1.9.
          shavecatS 1 Reply Last reply Reply Quote 0
          • shavecatS
            shavecat @mth75
            @mth75
            How do i do that ? (Check your file permissions/ownership?) where and how ?
            im using putty on retropie 4.6 and i have pi4 2gb.
            So thats mean i can do an .sh file from ports in retrpoie with
            wine<gamename>.exe
            and it will work ??? :):):):)):):)<3<3<3<3(SOUNDS AMIAZING ! )
              mth75 @shavecat
              @shavecat
              Sorry mate, can't advise your there except:
              1. make sure to install box86 and wine maybe on a clean system.
              2. try to install an easy game for test purposes, maybe Space Cadet 3D pinball
              3. and build further ... with all of the above ...
              • FollyF
                Folly @mth75
                @mth75 said in Box86 and Wine on RPi4:
                @folly said in Box86 and Wine on RPi4:
                What is your rom folder now ?
                /home/pi/RetroPie/roms/Box86
                Indeed, /home/pi/RetroPie/roms/Box86/<Game folder> is my rom folder.
                The <Game folder> is my wineprefix for example:
                <Game folder>
                -- dosdevices
                -- drive_c
                --- system.reg
                --- user.reg
                etc.
                OK, I understand how you do it, I think.
                But now I wonder, does this also work if you run emulationstation from your "cli" instead of the "Desktop" ?
                Because it needs to run xinit to display it all in te terminal/cli enviroment.
                The ultimate goal is that it's working in standard "RetroPie".
                  mth75 @Folly
                  I'm running EmulationStation as part of a "standard" RetroPie image (so no LXDE Desktop installed) on my Pi4 build. I just build the packages (wine_prefixes) on my Pi400 (Raspbian OS/LXDE with no RetroPie/ES installed).IMG_1321.jpg
                  • FollyF
                    Folly @shavecat
                    Hey all
                    I have Shovel Knight/unepic /Worldofgoo/Postal1/crimsonland runing on the box86 too.
                    And can i have more Info plz ,
                    How to run
                    Commands or AOE2 ?
                    plz
                    Got lost here abit :)
                    I am doing it different than @mth75.
                    I just used the scripts from @George to install it all.
                    To make it simple just use the repository of George instead or the original.
                    I rename your old setup directory !
                    Then install it with these commands :
                    cd
                    git clone --depth=1 https://github.com/GeorgeMcMullen/RetroPie-Setup.git
                    edit: goto https://retropie.org.uk/forum/topic/28528/box86-and-wine-on-rpi4/77
                    And then just install it from the Retropie-setup in this order :
                    (information from the pull request from George)
                    The scripts must be run in order, and they will check to make sure the preceding dependencies have been met.
                    mesa.sh - This is an updated Mesa driver, which is required by Box86. The version that is installed with the RetroPie distribution is not yet compatible.
                    box86.sh - This is set as an emulator because it is.
                    wine.sh - This is the x86 version of Wine and requires box86 in order to run. It is installed as a Port, because as the name says, Wine Is Not an Emulator.
                    spacecadet3dpinball.sh - This is the original Windows XP game, hosted on the Internet Archive. It is also installed as a Port as it is more like a rom and not an emulator. It is included mostly as a reference to installing other games. One note - you must not hit the Escape key to quit or you will be in a hung state in the game. Use Alt-F4 instead.
                    If it works, then you can try different stuff.
                    shavecatS 1 Reply Last reply Reply Quote 1
                    • FollyF
                      Folly @mth75
                      Thanks for explaining.
                      Now I know that this could be a good standard solution.
                      • shavecatS
                        shavecat @Folly
                        @folly
                        Thanks a lot for helping :)
                        so i did that
                        pi@retropie:~ $ git clone --depth=1 https://github.com/GeorgeMcMullen/RetroPie-Setup.git
                        fatal: destination path 'RetroPie-Setup' already exists and is not an empty directory.
                        and i dont have any new from Retropie-setup when i launch it to install them ...
                        so i do i install them ? :)
                          mth75 @Folly
                          You're welcome. Indeed, George Ports solutions combined with wine_prefixes make it a very feasible solution but a manual one ...
                          • FollyF
                            Folly @shavecat
                            @folly
                            so i did that
                            Ok, perhaps i made a mistake.
                            I will look into it.
                            • FollyF
                              Folly @shavecat
                              @folly
                              so i did that
                              You have to rename your original RetroPie-Setup directory with the mv command.
                              So then RetroPie-Setup becomes RetroPie-Setup.original.
                              This becomes your backup.
                              Then the RetroPie-Setup directory can be made again.
                              You can do it like this :
                              cd
                              mv RetroPie-Setup RetroPie-Setup.original
                              Then it should work.
                              • shavecatS
                                shavecat @Folly
                                @folly
                                pi@retropie:~ $ mv RetroPie-Setup RetroPie-Setup.original2
                                Cloning into 'RetroPie-Setup'...
                                remote: Enumerating objects: 392, done.
                                remote: Counting objects: 100% (392/392), done.
                                remote: Compressing objects: 100% (357/357), done.
                                remote: Total 392 (delta 65), reused 124 (delta 19), pack-reused 0
                                Receiving objects: 100% (392/392), 1.75 MiB | 1.94 MiB/s, done.
                                Resolving deltas: 100% (65/65), done.
                                looks like it worked but when its semmes i dont have them *.sh files to install in the setup retropie itself yet .
                                • FollyF
                                  Folly @shavecat
                                  I see, indeed, cant find those files either.
                                  Will look for a solution.
                                  • shavecatS
                                    shavecat @Folly
                                    @folly
                                    thanks a lot <3 :)
                                    • FollyF
                                      Folly @Folly
                                      @shavecat
                                      Use the mv command to your needs.
                                      Pfff. there are different branches.
                                      That's why it didn't work.
                                      Now it should work !, I hope.
                                      cd
                                      git clone --depth=1 --branch box86wine https://github.com/GeorgeMcMullen/RetroPie-Setup.git
                                      • shavecatS
                                        shavecat @Folly
                                        @folly
                                        Thank u so much !
                                        Its install it !! ITS WORKING ! :)
                                        do i need to put back my retroipesetup ?
                                        or just update that and it will go back ?
                                        And i cant get Wine to run EXE file
                                        it gives me
                                        BAD EXE format
                                        I can get it working for the Wine DESKTOP !
                                        like Commands run great ...
                                        Got also heroes of might and magic 3 runing but it getting stuck after the logo movie :\
                                        with wine desktop .
                                        still getiing BAD EXE from retropie itself with sh file.
                                        M FollyF 2 Replies Last reply Reply Quote 0
                                          mth75 @shavecat
                                          BAD EXE format
                                          I suspect Box86 isn't running?
                                            mth75
                                            @George
                                            And Blitzkrieg 1 running on the Pi400 (Raspbian OS) and Pi4 (Retropie). Maybe I should start a seperate thread for the games which will run on the Pi4 or keep posting in your topic?
