    Box86 and Wine on RPi4
    box86wineqemux86windows
    475 Posts 40 Posters 283.6k Views
      dktpi
      https://github.com/Botspot/pi-apps
      On there, there is a script for wine and box86.
        MumboJumbo
        Hey while playing around with Box and Wine i got some questions i am a noob but I hope someone can help. I use the retropie 4.71 image on a pi4.
        How can I get information about the driver used from wine/box/xinit or are they all using the same ?
        In Diablo 2 I can switch between glide, direct3d and ddraw. direct3d doesn't work, ddraw works fine but the aspect ratio doesnt fit in fullscreen tough i set xrandr to 800x600 i get the impression that xrandre ignores ddraw out because it works on glide but on glide there are graphical bugs and its all multicolored lines.....
        In Starcraft there is also the problem with the aspect ratio seems to be also ddraw
        Is there a possibility to force wine to emulate a screen with a matching ratio like 1600x900 or would this also be ignored by ddraw ?
        And for D2 is there a possibility to get the glitvhes out of glide or is this sth the pi4 cant do?
        ectoE 1 Reply Last reply Reply Quote 0
        • ectoE
          ecto @MumboJumbo
          @mumbojumbo If you search this thread, there is at least one post by me with a link to a quality of life mod for Diablo 2. You can use this to set up Diablo to use all kinds of resolutions (even widescreen).
          The ddraw renderer is the fastest (cnc-ddraw, iirc). I'm using 960x540 and scale that to 1920x1080. This way it still looks like the old Diablo but in widescreen.
          To use this renderer you have to copy the ddraw.dll of the cnc-ddraw to the base diablo 2 folder and set WINEDLLOVERRIDES=ddraw=n,b in front of your wine command line.
          There might be further steps, but you can find them in the diablo 2 qol git.
          • SuperFromNDS SuperFromND referenced this topic on
            MumboJumbo @ecto
            @ecto puh still trying to get it running... don't know but opening with Plugy leads to crash. When I try in desktop i sometimes get a need CD window... but even with cd mounted it wont do... arg . Its also kind of strange the exe started in windows automatically with pluggy but when i start it on pi it wont use plugy and i get the normal stretched screen.
            • ectoE
              ecto @MumboJumbo
              @mumbojumbo You have to use a specific Diablo 2 version (1.13d). After you installed the QoL patch, you have to change the renderer to ddraw.
              You have to set your custom resolution in one of the .ini files, iirc. Probably in PlugY.ini, but I'd need to look that up, as I'm away from my Retropie.
              The game can then be started with the following command:
              #!/bin/bash
              xset -dpms s off s noblank
              cd "/home/pi/RetroPie/roms/wine/Files/Diablo2/"
              matchbox-window-manager &
              WINEDEBUG=-all LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/" setarch linux32 -L /opt/retropie/emulators/wine/bin/wine Game.exe -direct -txt
              I hope this helps a little.
              Ah, and one more important thing: When you have PlugY or any other mods enabled in Diablo 2 you should not play on Battle.net, as you might get banned! There is still the option to play on a private server, though. As I'm more of a single-player-guy, that never bothered me..
                MumboJumbo @ecto
                @ecto hmm I was on 1.13c but I also found out that some plugins need dx10 or win7 my wineprefix is running on XP which is yours?
                • ectoE
                  ecto @MumboJumbo
                  @mumbojumbo I'm also using a XP prefix without any winetricks.
                  I think only the preinstalled glide wrapper of the QoL patch is using dx10. That's why you have to change the renderer to ddraw (or use dxvk, which will not work on our pi4).
                  At first try to get it running with ddraw. If that works you can still change the resolution and everything else.
                  I remember that it took some time to get everything running, but eventually it will work! Have faith! ;)
                    MumboJumbo @ecto
                    @ecto is there a glide wrapper using dx9?
                    For now I got it running with D2SE and test each plugin. I have got the renderer on ddraw. I had a bug with plugy that when opening my character menu the game crashed in the logs there was sth with unimplemented opcode so i disabled the flag "ActiveDisplayBaseStatsValue" in Plugy.ini and now I can open it.
                    • Plugy works with setting
                    • cnc ddraw works too
                    • D2Multi Res works too
                    • with D2DX it directly crashed
                    • with BaseMod it also directly crashed
                    in D2SE i could check my open gl renderer I dont realy know what to do with this info but it said V3D 4.2
                    • ectoE
                      ecto @MumboJumbo
                      @mumbojumbo I have D2 also running with Svens Glide Wrapper (Glide -> Open GL). It arguably looks a bit better (pseudo 3d and better lighting/effects) but then again the framerate is only around 20 for me with 960x540.
                      I have not gotten nGlide (Glide -> DX / Vulkan) wrapper to work. I have one other game that works with the obscure (?) OpenGlide wrapper but other than that, I had no luck with Glide at all so far.
                      D2DX is for DirectX 11 and will not work without DXVK (and Vulkan for that).
                      EDIT I think BaseMod is running for me... I really just dropped the whole QoL patch into my D2 folder and edited the settings.
                        MumboJumbo @ecto
                        @ecto thx alot got it up and running with normal aspect radio and most of the qol mods. I first tried Basemod D2SE modpack it didnt work but after trying again with just the files it worked :). I am using version 1.13c with D2SE around there i had to set in the D2SE_SETUP.ini the flags
                        #Enable PlugY when ModAllowPlugY=1
                        EnablePlugY=1
                        Direct=1
                        Txt=1
                        The mods i am using are Plugy (14.03 disable "ActiveDisplayBaseStatsValue" ), cnc-ddraw (WINEDLLOVERRIDES=ddraw=n,b), D2MultiRes113c, BaseMod(1139_1) and BH (1.9.9)
                          MumboJumbo
                          I tried setting up all the things without d2se but starting Game.exe never loads Plugy when using Plugy.exe i always get ACESS_VIOLATION c0...05 or it directly quits.. I think i leave it wrapped in D2SE for me.
                          • ectoE
                            ecto @MumboJumbo
                            @mumbojumbo Here are some of my .ini files for you to check:
                            PlugY.ini
                            ;                              "PlugY, The Survival Kit"                               ;
                            ;                                 Configuration file                                   ;
                            ;                                  by Yohann Nicolas                                   ;
                            ;                                    version 14.02                                     ;
                            ; See PlugY_The_Survival_Kit_-_Readme.txt file for more documentation.
                            ; Voir le fichier PlugY_The_Survival_Kit_-_LisezMoi.txt pour plus d'information.
                            ; Siehe PlugY_The_Survival_Kit_-_Liesmich.txt für weitere Informationen
                            [LAUNCHING]
                            Param=
                            Library=PlugY.dll
                            [GENERAL]
                            ActivePlugin=1
                            DisableBattleNet=1
                            ActiveLogFile=0
                            DllToLoad=Basemod.dll|BH.dll|D2HD.dll
                            DllToLoad2=
                            ActiveCommands=1
                            ActiveCheckMemory=1
                            [WINDOWED]
                            ActiveWindowed=0
                            RemoveBorder=0
                            WindowOnTop=0
                            Maximized=0
                            SetWindowPos=0
                            X=0
                            Y=0
                            Width=0
                            Height=0
                            LockMouseOnStartup=0
                            [LANGUAGE]
                            ;ENG|ESP|DEU|FRA|POR|ITA|JPN|KOR|SIN|CHI|POL|RUS
                            ActiveChangeLanguage=0
                            SelectedLanguage=ENG
                            [SAVEPATH]
                            ActiveSavePathChange=0
                            SavePath=Mod PlugY
                            ActiveAutoBackup=1
                            MaxBackupPerCharacter=20
                            [MAIN SCREEN]
                            ActiveVersionTextChange=1
                            VersionText=
                            ColorOfVersionText=0
                            ActivePrintPlugYVersion=1
                            ColorOfPlugYVersion=4
                            [STASH]
                            ActiveBigStash=1
                            ActiveMultiPageStash=1
                            NbPagesPerIndex=10
                            NbPagesPerIndex2=100
                            MaxPersonnalPages=0
                            AutoRenameStashPage=0
                            PersonalNormalPageColor=0
                            PersonalIndexPageColor=0
                            PersonalMainIndexPageColor=0
                            SharedNormalPageColor=4
                            SharedIndexPageColor=4
                            SharedMainIndexPageColor=4
                            ActiveSharedStash=1
                            ActiveSharedStashInMultiPlayer=0
                            SeparateHardcoreStash=1
                            OpenSharedStashOnLoading=0
                            DisplaySharedSetItemNameInGreen=1
                            MaxSharedPages=0
                            ActiveSharedGold=1
                            [STATS POINTS]
                            ActiveStatsUnassignment=1
                            KeyUsed=18
                            ActiveShiftClickLimit=1
                            LimitValueToShiftClick=10
                            [SKILLS POINTS]
                            ActiveSkillsUnassignment=1
                            ActiveSkillsUnassignmentOneForOne=0
                            [WORLD EVENT]
                            ActiveWorldEvent=0
                            ShowCounterInAllDifficulty=0
                            ItemsToSell=The Stone of Jordan
                            MonsterID=333
                            OwnSOJSoldChargeFor=100
                            InititalSOJSoldMin=200
                            InititalSOJSoldMax=3000
                            TriggerAtEachSOJSoldMin=75
                            TriggerAtEachSOJSoldMax=125
                            ActiveAutoSell=1
                            TimeBeforeAutoSellMin=0
                            TimeBeforeAutoSellMax=1200
                            [UBER QUEST]
                            ActiveUberQuest=0
                            UberMephistoX=25130
                            UberMephistoY=5143
                            UberDiabloX=25139
                            UberDiabloY=5139
                            UberBaalX=25139
                            UberBaalY=5135
                            ActiveUberMinions=1
                            UberMephistoSpawnPercent=80
                            UberMephistoSpawnRadius=30
                            UberBaalSpawnPercent=30
                            UberBaalSpawnRadius=30
                            UberDiabloSpawnPercent=30
                            UberDiabloSpawnRadius=30
                            ActiveUberDiabloRushTweekAI=1
                            ActiveUberBaalTeleportTweekAI=1
                            ActiveUberBaalChillingArmorTweekAI=1
                            UberBaalChillingArmorTimer=6000
                            [INTERFACE]
                            ActiveNewStatsInterface=1
                            SelectMainPageOnOpenning=1
                            [EXTRA]
                            ActiveLaunchAnyNumberOfLOD=1
                            AlwaysRegenMapInSP=0
                            NBPlayersByDefault=1
                            ActiveDisplayItemLevel=1
                            AlwaysDisplayLifeAndManaValues=0
                            EnabledTXTFilesWhenMSExcelOpenIt=1
                            ActiveDisplayBaseStatsValue=1
                            ActiveLadderRunewords=1
                            ActiveCowPortalWhenCowKingWasKilled=1
                            ActiveDoNotCloseNihlathakPortal=1
                            MoveCainNearHarrogathWaypoint=1
                            D2HD.ini
                            [Settings]
                            MPQ Name=D2MultiRes.mpq
                            Left Panel Background Color=0xffffffff
                            Left Panel Border Color=0xffffffff
                            Right Panel Border Color=0xffffffff
                            Right Panel Background Color=0xffffffff
                            Enable D2MR Border Panel Style=1
                            Invert D2MR Bottom Control Panel=1
                            Enable D2MR Panel Background Ribbon=1
                            Enable 800x600 Style Control Panel=1
                            Resolution=4
                            Custom Width (can't be larger than 1344)=960
                            Custom Height (can't be larger than 700)=540
                            Basemod.ini
                            ; YOU MUST FULLY EXIT THE GAME FOR ANY NEW CHANGES TO TAKE EFFECT
                            ; USAGE of ini values
                            ; valid enable	Enabled=1
                            ; valid disable	Enabled=0
                            ; Commented out strings will always start with ";" and are invalid unless uncommented
                            [BaseMod_ini]
                            Enabled=1
                            Version=1137
                            ; Version is just for reference - it does nothing
                            [AnimateInventory]
                            Enabled=0
                            ; Enabled allows Animated Inventory Items
                            [LifeManaAnimate]
                            Enabled=0
                            Class=0
                            ManaPurple=0
                            ; Animates Life/Mana Orb Graphics
                            ; Class=0  disabled  - use vanilla dc6 files
                            ; Class=1  Life/Mana - Same Dc6 files for all Classes
                            ; Class=2  Mana - different Dc6 files for all Classes
                            ; Mana Purple gfx display with non animated Orbs on State:  Default = 2  STATE_POISON
                            ; ManaPurple=0 to disable this gfx mode
                            [LadderRuneWords]
                            Enabled=1
                            ; Enables Ladder Only RuneWords in Single Player games
                            [EthSocketFix]
                            Enabled=1
                            ; Fixes the Ethereal Armor Socketing Defense Bug
                            [AutoPickup]
                            Enabled=1
                            SoundEn=0
                            InTown=0
                            Gold=1
                            Runes=0
                            Gems=0
                            Jewels=0
                            RinAmu=0
                            Scrolls=1
                            Keys=1
                            ; Enables Automatic Item Pickup when run over - Credits to Whist for original Gold Pickup code
                            ; SoundEn Gold 0 = disable, 1 for item pickup sound, or 2 for gold sound (only for gold atm)
                            ; InTown allows auto pickup items in town
                            ; Gold  0 = disable auto pickup
                            ; Runes 0 = disable auto pickup
                            ; Gems:  1 = pickup all, 2 exclude chipped, 3 exclude chipped an flawed,
                            ;        4 only flawless and perfect, 5 = perfect gems only
                            ; Jewels 1 = enable auto pickup
                            ; RinAmu 1 = enable auto pickup
                            ; Scrolls 1 = auto pickup scrolls until books are full. If no book is found, then skip.
                            ; Keys  1 = auto pickup until key stack is full. If no key stack is found, then skip.
                            [AutoPickup2]
                            Enabled=1	; This depends on [AutoPickup] Enabled=1
                            ;InTown		; Set this option in [AutoPickup]
                            ;SoundEn	; Set this option in [AutoPickup]
                            Quivers=0
                            BeltPickup=1
                            PotionMatch=2
                            Slot1Auto=0
                            Slot2Auto=0
                            Slot3Auto=0
                            Slot4Auto=0
                            ; Quivers=1 to enable filling stacks in weapon slots and/or inventory stack from ground.
                            ; BeltPickup enables auto potion pickup to match the potion type in the same in first row belt slot.
                            ; Manual operation: when there is no potion on the first row to match with it stops pickup.
                            ; PotionMatch compares whats in the first row belt slot to determine the match.
                            ; PotionMatch 0 = lazy match, any of same type | 1 = fuzzy match any+, -1, or same | 2 = strict match
                            ; SlotXAuto *only* chooses what type of potion to pickup *when* the slot is fully empty.
                            ; 0 is manual operation - when the slot is empty, manual load first item, then autopick resumes
                            ; 0 = manual | 1 = hp1 | 2 = hp2 | 3 = hp3 | 4 = hp4 | 5 = hp5 | 6 = any hp |
                            ; 7 = mp1 | 8 = mp2 | 9 = mp3 | 10 = mp4 | 11 = mp5 | 12 = any mp | 13 = rejuv | 14 full rejuv
                            ; 15 = any rejuv
                            ; stamina, thawing, and antidote potions require manual loading of the first slot for autopick
                            ; to fill remaining slots
                            [NoPickup]
                            Enabled=1
                            ; Enables start game with console option /nopickup
                            [RedPortals]
                            Enabled=1
                            SkipReq=1
                            ForceQuestCheck=1
                            ; Enables/Disables [all of] Pandemonium Portals, & Uber Quests
                            ; Pandemonium Portals only spawn in Hell Act 5 Town
                            ; SkipReq - Uber Tristram Portal skip requirement for all 3 Pandemonium Portals to be open
                            ; before Portal to Uber Tristram will open.
                            ; ForceQuestCheck - Forces Quest and WayPoint checks before Cube Custom Red Portals will
                            ; open to Destination level. Use to prevent skipping quests in Game
                            [UberMinions]
                            Enabled=1
                            UDMinions=6
                            UDSpawnRadius=15
                            UDChanceToSpawn=10
                            UBMinions=6
                            UBSpawnRadius=20
                            UBChanceToSpawn=10
                            UMMinions=12
                            UMSpawnRadius=25
                            UMChanceToSpawn=10
                            ; Enables Minion Spawning in Uber Tristram (0 | 1)
                            ; UDMinions - Number of minions in spawn radius - range (0 - 25) - 0 disables
                            ; UDSpawnRadius valid range (10 - 50)
                            ; UDChanceToSpawn - rolls a random chance to spawn - valid range (1 - 100)
                            ; UBMinions - Number of minions in spawn radius - range (0 - 25) - 0 disables
                            ; UBSpawnRadius valid range (10 - 50)
                            ; UBChanceToSpawn - rolls a random chance to spawn - valid range (1 - 100)
                            ; UMMinions - Number of minions in spawn radius - range (0 - 25) - 0 disables
                            ; UMSpawnRadius valid range (10 - 50)
                            ; UMChanceToSpawn - rolls a random chance to spawn - valid range (1 - 100)
                            ; The entire feature requires BaseMod [RedPortals] to be enabled to work, due to spaghetti global variables.
                            [ExtraDll1]
                            Enabled=0
                            LoadDll1=""
                            [ExtraDll2]
                            Enabled=0
                            LoadDll2=""
                            [ExtraDll3]
                            Enabled=1
                            LoadDll3=""
                            ; ExtraDll allows you to load other dlls in the order above, up to 31 char in length.
                            ; Example LoadDll1="PlugY.dll"
                            ; Observe case sensitive file names, and place Extra dlls in the same folder as Game.exe.
                            ; If using D2SE, use D2SE_SETUP.ini to load extra dlls instead.
                            ; When D2SE loads the game, this set of options is ignored.
                            [SpawnMissingSU]
                            Enabled=1
                            ; Enables/Disables spawning of all missing SuperUnique Monsters in the game.
                            ; "FlameSpike the Crawler" (Razor Spine) Near the Cathedral Doors in Act1 Inner Cloister
                            ; "Taintbreeder" (Stygian Hag) random location in Act4 Outer Steppes
                            ; "The Tormentor" (Burning Soul) Guarding entrance to the PLains of Despair - Act4
                            ; "Darkwing" (Venom Lord)  random location in the Plains of Despair - Act 4
                            ; "Riftwraith the Cannibal" (Corpse Spitter) random location in City of the Damned - Act4
                            ; "Hell's Belle" (Hell Temptress) -- in the Halls of Vaught - Act 5
                            ; "Blaze Ripper" (Death Brigadier) -- In the Frozen Tundra - Act 5
                            ; "Magma Torquer" (Demon Sprite) -- Guarding Entrance to the Ancients Way - Act 5
                            ; "Vinvear Molech" (Vile Witch) -- Guarding Entrance to Arreat Summit - Act 5
                            ; "Axe Dweller" (Blood Lord) -- Guarding Entrance to Worldstone Keep Level 3 - Act 5
                            [WorldEvent]
                            Enabled=1		; 0 to Disable
                            AutoSellSoJ=1		; 0 to Disable
                            Interval=600		; Valid Range 3 - 1200 seconds
                            MinItems=100		; Valid Range 1 - 400 Min # of Items to Trigger World Event
                            MaxItems=100		; Valid Range 5 - 550 Max # of Items to Trigger World Event
                            EnableAllDiff=1		; 1 to Enable World Event in all Difficulty
                            TriggerType=2		; use UniqueName =1, use 3 letter Item Code =2
                            ItemQuality=7		; required item quality to sell (1-9 valid range)
                            UniqueName="Nagelring"	; Copy and paste from column 1 in UniqueItems.txt and "USE QUOTES"
                            ItemCode=rin		; valid 3 letter Item Code to sell  rin = ring
                            ; # Enabled Enables WorldEvent
                            ; # AutoSellSoJ Automate SOJ's Sold to Vendors, in random amounts
                            ; You must sell at least one specified Item to trigger Autosell. When you do they vanish forever.
                            ; Random Items sold (1-4), every - Interval time period (in seconds)
                            ; Default Interval=20 (20 seconds).
                            ; # MinItems Defines Min amount of Items sold to trigger World Event
                            ; # MaxItems Defines Max amount of Items sold to trigger World Event
                            ; # --> MinItems Cannot be greater than MaxItems <--
                            ; # EnableAllDiff - Enables World Event in Normal and NM difficulty - Default Hell only
                            ; # TriggerType use 1 or 2
                            ; # UniqueName - Copy and paste from column 1 in UniqueItems.txt and "USE QUOTES"
                            ; # ItemCode must be valid 3 letter Item Code
                            ; # ItemQuality (Low = 1, Normal = 2, Superior =  3, Magic = 4, Set = 5, Rare = 6, Unique = 7, 8 = Crafted, 9 = Tempered)
                            ; Example trigger with Stone of Jordan    TriggerType=1 & UniqueName="The Stone of Jordan"
                            ; Example trigger with ANY Unique ring    TriggerType=2 & ItemCode=rin & ItemQuality=7
                            ; Example trigger with Perfect Diamond    TriggerType=2 & ItemCode=gpw & ItemQuality=2
                            ; Example trigger with ANY Rare Amulet    TriggerType=2 & ItemCode=amu & ItemQuality=6
                            ; (Annihilus drops only in Hell Difficulty)
                            ; Uber Diablo spawns in place of a SuperUnique after 40-70 Items are sold in example above.
                            ; Once Uber Diablo is killed, or a new game is started, the SoJ counter resets to zero.
                            [WEMinions]
                            Enabled=1
                            UberDExtra_SP=0
                            UberDExtra_MP=0
                            Minions=6
                            SpawnRadius=10
                            ChanceToSpawn=10
                            ; Enables World Event Minions and/or Uber Diablo Pack spawning (0 | 1)
                            ; Spawn Uber Diablo Pack in SP. Extra Uber Diablo Units valid range (0 - 4)
                            ; Extra Uber Diablo Pack in MP. Scales based on party size upto 4 extra with 8 players.  (0 | 1)
                            ; Number of minions in spawn radius - range (0 - 25) - 0 disables
                            ; SpawnRadius valid range (10 - 50)
                            ; ChanceToSpawn - rolls a random chance to spawn - valid range (1 - 100)
                            ; The entire feature requires BaseMod [WorldEvent] to be enabled to work, due to spaghetti global variables.
                            [IlvlDisplay]
                            Enabled=0
                            MaxSockEna=1
                            ItemLevelEna=1
                            HideUnidentified=1
                            IlvlAniTorch=0
                            ; IlvlDisplay - Display Item Level, (and/or) Max Sockets for unsocketed Items
                            ; MaxSockEna - is a bulk switch to enable/disable all display of Max Sockets.
                            ; ItemLevelEna - is a bulk switch to enable/disable all display of Item Level.
                            ; HideUnidentified - bulk switch to hide Ilvl & MaxSock Strings for Unidentified Items.
                            ; IlvlAniTorch - enables Item Level display for these Unique Items.
                            ; It's suggested to enable [StringTable] for customization with UTF8 UNICODE
                            ; strings and colors for different Item Quality.
                            [PlayersX]
                            Enabled=0
                            PlrsCount=3		; (1 to 8) or (1 to 127) if Players127 is enabled
                            Notify=1		; 0 to disable
                            ; This will do "/Players X" command at game startup
                            ; Where X is specified as Players Count
                            ; Notify PlayersX count at Game start in Single Player Games
                            [Language]
                            Enabled=0
                            Locale=00		; Default = 00 English
                            			; This might conflict with D2SE if enabled in both
                            ; To use Change Language - You need to install a language pack first.
                            ; - USE THE NUMERIC LANGUAGE CODE -
                            ;00 - (English) USA - Default
                            ;01 - (Spanish)
                            ;02 - (German)
                            ;03 - (French)
                            ;04 - (Portuguese)
                            ;05 - (Italian)
                            ;06 - (Japanese)
                            ;07 - (Korean)
                            ;08 - (Sinhalese)
                            ;09 - (Chinese)
                            ;10 - (Polish)
                            ;11 - (Russian)
                            ;12 - (English) NON USA
                            [ExtendLevels]
                            Enabled=0
                            ; No need to enable this unless your modding and have a need for it
                            ; Extends to 255 levels
                            ; May need to delete existing character map save files charname.ma0, charname.ma1, charname.ma2,
                            ; and charname.ma3 files before enabling this
                            [ExtendObjects]
                            Enabled=0
                            ; Enables Extended Objects - Credits to Nefarius for these patches
                            ; This allows you to add new Objects starting at ID #586
                            ; See Folder ExtObjects for examples
                            [ExtendSounds]
                            Enabled=0
                            MusicLimit=4698
                            ; Enables adding new music record entries to Sounds.txt
                            ; MusicLimit is the last entry for Music in sounds.txt. Music must be consecutive.
                            ; Be sure to view documentation in the folder ExtendSoundsMusic
                            ; if you want to expand music.
                            [PerfectDrops]
                            Enabled=0		; 0 to disable
                            DropIdentified=0	; 1,5,6,7 to enable
                            RareAffix=0		; 1 to enable
                            MagicAffix=0		; 1 to enable
                            StaffMods=0		: 1 to enable
                            PerfectItems=1		; 1 to enable
                            DropRepaired=0		; 1 to enable
                            RepairNormal=0		; 1 to enable
                            UniqueNoLimit=1		; 0 to disable
                            Force2Sockets=1		; 0 to disable
                            ; DropIdentified - 1 to enable all | 5 = set, rare & uniq | 6 = rare & uniq | 7 = uniq only.
                            ; RareAffix - Force 4 Affix rares on jewels & 6 Affix rares on weapons/armor - rings/amulets
                            ; MagicAffix - Force Magic Items to get both Prefix & Suffix
                            ; StaffMods - Force 9 skill points to class specific items [except low quality]
                            ; PerfectItems - ALL items Drop Perfect [except normal and low quality]
                            ; DropRepaired - ALL Items Drop repaired [except normal and low quality]
                            ; RepairNormal - ALL Normal Items Drop Repaired
                            ; UniqueNoLimit - Bypass Unique Item limit of one drop per game
                            ; Force2Sockets - Normal items > ilvl 25 get 2 sockets as minium instead of 1 when possible.
                            [NilPortalFix]
                            Enabled=1
                            ; Enables Nilathek Portal Fix so it don't close after quest is completed.
                            [MapAutoRegen]
                            Enabled=0
                            ; Enabled auto generate new maps in each game for SP mode
                            [Players127]
                            Enabled=0
                            ; Enable allows upto 127 virtual player count
                            [DynHealthBar]
                            Enabled=0
                            ; Enables Dynamic Monster Life Bar Colors - A cool invention by Ogodei
                            Life1R=80
                            Life1G=0
                            Life1B=0
                            Life2R=255
                            Life2G=128
                            Life2B=0
                            Life3R=90
                            Life3G=0
                            Life3B=90
                            ; Life1 is RGB decimal values (0-255) for monster life < 33%
                            ; Life2 is RGB decimal values (0-255) for monster where 33% > life < 66%
                            ; Life3 is RGB decimal values (0-255) for monster life > 66%
                            [GoblinPatch]
                            Enabled=0
                            ; Enables the Patch for Nizari and Jettaman's Treasure Goblin Plugin,
                            ; to read Umon field from levels.txt.
                            ; You have to add the rest of the files yourself
                            [MFLinear]
                            Enabled=1
                            ; Option for Linear Magic Find Drop Rates
                            ; Improves Unique, Rare, and Magic Item Drops
                            ; Restores the drop rate algorithm used in Diablo II v1.09
                            [MercMod]
                            FullEquip=0
                            RogueCrossBow=1
                            RogueAmaBow=1
                            ; FullEquip allows Hireling to equip boots, gloves, belt, amulet and one ring.
                            ; Allow Act 1 Rogue Hire to equip Cross Bows
                            ; Allow Act 1 Rogue Hire to equip Amazon Bows
                            [BypassFPS]
                            Enabled=1
                            ; Adds the option to disable 25 FPS Bypass to make BaseMod compatible
                            ; with SlashDiablo plugin. This also disables the CPU fix.
                            [GambleRefresh]
                            Enabled=1
                            ItemCount=24
                            ; Option to adjust item count for Gamble Screen between 1 and 100 items.
                            ; The default is 24 items.  Increased item count for multires mods
                            [CharmZone]
                            Enabled=0
                            CZLeft=5
                            CZRight=7
                            CZTop=3
                            CZBottom=4
                            ; Enables Dav92's Charm Zone to player inventory
                            ; Inventory values for Charm Zone
                            [GameFVFB]
                            Enabled=0
                            Version=113c
                            ; Game File Version Fallback - This is ONLY used in situations where Game.exe is
                            ; not the Game parent process. It allows user override of default the game file
                            ; version patching [1.13C] to fallback to a different version. Valid strings are:
                            ; 113c, 113C, 113D, 113d, 114d, 114D - DO NOT use "QUOTES" or SPACES. This
                            ; variable is read before the first patch is applied, long before an MPQ is loaded.
                            [CtrlLClick]
                            Enabled=1
                            ; Option to Disable Ctrl Left Click Item extended to Inventory, Stash, Cube & Ground Drop
                            ; for compatibility with a Filter plugin.
                            [StringTable]
                            Enabled=1
                            IlvlMaxSock=1
                            RenameUbers=1
                            ; Enable custom strings in BaseMod.tbl. UPDATED to work from index like CustomString1.tbl
                            ; You can use this table to store and display your own strings in the game.
                            ; See \StringLocalization\StringTable.txt for info. First 49 strings reserved for BaseMod use.
                            ; You can disable most reserved strings from showing by blanking them with AFJ tbl Edit.
                            ; IlvlMaxSock - Enable custom strings for [Lowq-Mag], Set, Rare, Unique, crafted and Tempered.
                            ; RenameUbers - Enable custom Strings in BaseMod.tbl for Ubers.
                            [QuestMods]
                            Enabled=1
                            Respec=0		; 1 to enable
                            RespecCost=3000		; 3000 gold * clvl - valid input 500 to 10000  - minium cost 5000
                            Imbue=1			; 1 to enable
                            ImbueCost=500		; 500 gold * clvl - valid input 500 to 10000   - minium cost 5000
                            Socketing=1		; 1 to enable
                            SocketCost=20000	; fixed  - valid input 5000 to 500000          - minium cost 5000
                            Personalize=1		; 1 to enable
                            InscribeCost=20000	; fixed - valid input 5000 to 500000           - minium cost 5000
                            ; Infinite Quest Rewards from Akara, Charsi, Larzuk and Anya
                            ; Vendors charge gold after their quest is completed
                            ; Respec --> Akara Infinite Respec
                            ; Imbue --> Charsi & ATMA Infinite Imbue
                            ; Socketing --> Larzuk Infinite Socketing
                            ; Personalize --> Anya Infinite Personalize
                            ui.ini
                            [Settings]
                            Minimized=1
                            X=154
                            Y=173
                            minimizedX=1
                            minimizedY=17
                            [BH 1.9.9]
                            Minimized=1
                            X=328
                            Y=75
                            minimizedX=112
                            minimizedY=475
                            ddraw.ini
                            ; cnc-ddraw - https://github.com/CnCNet/cnc-ddraw - https://cncnet.org
                            [ddraw]
                            ; ### Optional settings ###
                            ; Use the following settings to adjust the look and feel to your liking
                            ; Stretch to custom resolution, 0=defaults to the size game requests
                            width=0
                            height=0
                            ; Override the width/height settings shown above and always stretch to fullscreen
                            ; Note: Can be combined with 'windowed=true' to get windowed-fullscreen aka borderless mode
                            fullscreen=true
                            ; Run in windowed mode rather than going fullscreen
                            windowed=false
                            ; Maintain aspect ratio
                            maintas=true
                            ; Windowboxing / Integer Scaling
                            boxing=false
                            ; Real rendering rate, -1=screen rate, 0 = unlimited, n = cap
                            ; Note: Does not have an impact on the game speed, to limit your game speed use 'maxgameticks='
                            maxfps=-1
                            ; Vertical synchronization, enable if you get tearing - (Requires 'renderer=auto/opengl/direct3d9')
                            ; Note: vsync=true can fix tearing but it will cause input lag
                            vsync=false
                            ; Automatic mouse sensitivity scaling
                            ; Note: Only works if stretching is enabled. Sensitivity will be adjusted according to the size of the window
                            adjmouse=false
                            ; Preliminary libretro shader support - (Requires 'renderer=opengl') https://github.com/libretro/glsl-shaders
                            ; 2x scaling example: https://imgur.com/a/kxsM1oY - 4x scaling example: https://imgur.com/a/wjrhpFV
                            shader=Shaders\interpolation\bilinear.glsl
                            ; Window position, -32000=center to screen
                            posX=-32000
                            posY=-32000
                            ; Renderer, possible values: auto, opengl, gdi, direct3d9 (auto=try direct3d9/opengl, fallback = gdi)
                            renderer=auto
                            ; Developer mode (don't lock the cursor)
                            devmode=false
                            ; Show window borders in windowed mode
                            border=false
                            ; Save window position/size/state on game exit and restore it automatically on next game start
                            ; Possible values: 0=disabled, 1 = save to global 'ddraw' section, 2 = save to game specific section
                            savesettings=1
                            ; Should the window be resizable by the user in windowed mode?
                            resizable=true
                            ; Enable linear (D3DTEXF_LINEAR) upscaling filter for the direct3d9 renderer
                            d3d9linear=true
                            ; Enable upscale hack for high resolution patches (Supports C&C1, Red Alert 1 and KKND Xtreme)
                            vhack=false
                            ; cnc-ddraw config program language, possible values: auto, english, chinese, german, spanish, russian, hungarian, french
                            configlang=auto
                            ; Where should screenshots be saved
                            screenshotdir=.\Screenshots\
                            ; ### Compatibility settings ###
                            ; Use the following settings in case there are any issues with the game
                            ; Hide WM_ACTIVATEAPP and WM_NCACTIVATE messages to prevent problems on alt+tab
                            noactivateapp=false
                            ; Max game ticks per second, possible values: -1=disabled, -2 = refresh rate, 0 = emulate 60hz vblank, 1-1000 = custom game speed
                            ; Note: Can be used to slow down a too fast running game, fix flickering or too fast animations
                            ; Note: Usually one of the following values will work: 60 / 30 / 25 / 20 / 15 (lower value=slower game speed)
                            maxgameticks=0
                            ; Windows API Hooking, Possible values: 0=disabled, 1 = IAT Hooking, 2 = Microsoft Detours, 3 = IAT+Detours Hooking (All Modules), 4 = IAT Hooking (All Modules)
                            ; Note: Change this value if windowed mode or upscaling isn't working properly
                            ; Note: 'hook=2' will usually work for problematic games, but 'hook=2' should be combined with renderer=gdi
                            hook=4
                            ; Force minimum FPS, possible values: 0=disabled, -1 = use 'maxfps=' value, -2 = same as -1 but force full redraw, 1-1000 = custom FPS
                            ; Note: Set this to a low value such as 5 or 10 if some parts of the game are not being displayed (e.g. menus or loading screens)
                            minfps=60
                            ; Disable fullscreen-exclusive mode for the direct3d9/opengl renderers
                            ; Note: Can be used in case some GUI elements like buttons/textboxes/videos/etc.. are invisible
                            nonexclusive=false
                            ; Fixes issues where the pitch of a surface is not a multiple of 4
                            ; Note: Enable this if some parts of the screen are being displayed diagonally
                            fixpitch=false
                            ; Force CPU0 affinity, avoids crashes/freezing, *might* have a performance impact
                            singlecpu=true
                            ; Available resolutions, possible values: 0=Small list, 1 = Very small list, 2 = Full list
                            ; Note: Set this to 2 if your chosen resolution is not working, set to 1 if the game is crashing
                            resolutions=0
                            ; Child window handling, possible values: 0=Disabled, 1 = Display top left, 2 = Display top left + repaint, 3 = Hide
                            ; Note: Disables upscaling if a child window was detected
                            fixchilds=2
                            ; Set the precision for Direct3D9 floating-point calculations to the precision used by the calling thread
                            ; Note: Enable this if there are desyncs in online games
                            fpupreserve=false
                            ; ### Hotkeys ###
                            ; Use the following settings to configure your hotkeys, 0x00=disabled
                            ; Virtual-Key Codes: https://docs.microsoft.com/en-us/windows/win32/inputdev/virtual-key-codes
                            ; Switch between windowed and fullscreen mode=[Alt] + ???
                            keytogglefullscreen=0x0D
                            ; Maximize window without frame=[Alt] + ???
                            keytogglemaximize=0x22
                            ; Unlock cursor 1=[Ctrl] + ???
                            keyunlockcursor1=0x09
                            ; Unlock cursor 2=[Right Alt] + ???
                            keyunlockcursor2=0xA3
                            ; Screenshot
                            keyscreenshot=0x2C
                              MumboJumbo @ecto
                              @ecto
                              1. copied a blank version of the D2 files on my pi
                                2 installed Patch 1.13d
                              2. copied d2 qol master file in D2 folder
                                4 used all your ini files
                                5 Started the Game.exe -txt -direct
                              When I start it like that it doesn't use Plugy just enters the game in stretched mode
                              M ectoE 2 Replies Last reply Reply Quote 0
                                MumboJumbo @MumboJumbo
                                I also tried coping the Plugy.exe into the folder but when i run it i throws me back to emustation. Started from desktop i can shortly see the blue "Blizzard" before it hangs.
                                  Now i also copied the 14.02 Plugy.exe this wont start ... Then I tried the file Patcher ... allready patched. I also used the Plugy installer buit also not starting...
                                  I dont see sth bad in my log in think....
                                  Parameters:
                                  Executing: xinit /dev/shm/retropie_xinitrc -- vt1 -keeptty
                                  _XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
                                  X.Org X Server 1.20.4
                                  X Protocol Version 11, Revision 0
                                  Build Operating System: Linux 5.4.0-72-generic armv8l Raspbian
                                  Current Operating System: Linux retropie 5.10.63-v7l+ #1496 SMP Wed Dec 1 15:58:56 GMT 2021 armv7l
                                  Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:45:57:FB vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4bf27f5c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait loglevel=3 consoleblank=0 plymouth.enable=0
                                  Build Date: 04 January 2022  10:05:34AM
                                  xorg-server 2:1.20.4-1+rpt4+deb10u4 (https://www.debian.org/support)
                                  Current version of pixman: 0.36.0
                                  	Before reporting problems, check http://wiki.x.org
                                  	to make sure that you have the latest version.
                                  Markers: (--) probed, (**) from config file, (==) default setting,
                                  	(++) from command line, (!!) notice, (II) informational,
                                  	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
                                  (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Thu Mar  3 09:19:02 2022
                                  (==) Using system config directory "/usr/share/X11/xorg.conf.d"
                                  (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
                                  Set mode 1920x1080@60Hz on HDMI-1
                                  Executing (via xinit): /home/pi/RetroPie/roms/wine/Wine Desktop.sh /home/pi/RetroPie/roms/wine/Diablo2.sh
                                  ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: Datei oder Verzeichnis nicht gefunden
                                  Fehler beim Öffnen des Sequenzers
                                  Launching Wine with params: /home/pi/RetroPie/roms/wine/Diablo2.sh
                                  Launching with script
                                  Starting TiMidity
                                  Requested buffer size 32768, fragment size 8192
                                  ALSA pcm 'default' set buffer size 32768, period size 8192 bytes
                                  ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: No such file or directory
                                  error in snd_seq_open
                                  TiMidity starting in ALSA server mode
                                  (==) Log file: "/home/pi/.local/share/xorg/Xorg.1.log", Time: Thu Mar  3 09:19:14 2022
                                  (EE)
                                  Fatal server error:
                                  (EE) parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
                                  (EE)
                                  (EE)
                                  Please consult the The X.Org Foundation support
                                  	 at http://wiki.x.org
                                   for help.
                                  (EE) Please also check the log file at "/home/pi/.local/share/xorg/Xorg.1.log" for additional information.
                                  (EE)
                                  (EE) Server terminated with error (1). Closing log file.
                                  No systemtrayicon available
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\wineboot.exe" at 00400000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ws2_32.dll" at 6D780000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winemenubuilder.exe" at 00400000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\win32u.dll" at 66B00000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 00C30000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 6ED00000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 68500000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 007B0000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 00110000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 64A40000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 00E60000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\oleaut32.dll" at 64EC0000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\propsys.dll" at 69940000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\windowscodecs.dll" at 01C50000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\services.exe" at 00400000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 007C0000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
                                  003c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\userenv.dll" at 00110000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winedevice.exe" at 00400000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\hal.dll" at 669C0000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntoskrnl.exe" at 68E80000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\explorer.exe" at 00400000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  0048:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 00DC0000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\win32u.dll" at 66B00000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 007D0000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 6ED00000: builtin
                                  005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\mountmgr.sys" at 6CFC0000: builtin
                                  005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
                                  005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
                                  0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\win32u.dll" at 66B00000: builtin
                                  0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
                                  0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 6ED00000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winedevice.exe" at 00400000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\hal.dll" at 669C0000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntoskrnl.exe" at 68E80000: builtin
                                  0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at 41D00000: builtin
                                  0070:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 00DC0000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\wineusb.sys" at 42030000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\uxtheme.dll" at 68700000: builtin
                                  0050:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\uxtheme.dll" : builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\hidparse.sys" at 6F400000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\winebus.sys" at 6A700000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\win32u.dll" at 66B00000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 01650000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\hidclass.sys" at 00180000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\winehid.sys" at 6B780000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 01950000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 014D0000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 01480000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 01360000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 67EC0000: builtin
                                  0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\oleaut32.dll" at 01CE0000: builtin
                                  0050:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\actxprxy.dll" at 61D00000: builtin
                                  009c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\winexinput.sys" at 6FFC0000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\plugplay.exe" at 00400000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 00760000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\win32u.dll" at 66B00000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 6ED00000: builtin
                                  00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
                                  00c4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\svchost.exe" at 00400000: builtin
                                  00c4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  00c4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  00c4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  00c4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  00c4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  00c4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  00c4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\wevtsvc.dll" at 6CF40000: builtin
                                  00c4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 00CB0000: builtin
                                  005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\nsiproxy.sys" at 6AD80000: builtin
                                  005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\dnsapi.dll" at 6E4C0000: builtin
                                  005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\nsi.dll" at 01C10000: builtin
                                  005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\iphlpapi.dll" at 61500000: builtin
                                  005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\ndis.sys" at 6D980000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\win32u.dll" at 66B00000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 013F0000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 6ED00000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 012A0000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 00E20000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 00180000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 00D00000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 67EC0000: builtin
                                  00dc:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcss.exe" at 00400000: builtin
                                  00dc:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  00dc:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  00dc:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  00dc:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  00dc:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  00dc:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  00dc:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 00780000: builtin
                                  002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
                                  0024:trace:loaddll:build_module Loaded L"F:\\Diablo2\\PlugY.exe" at 00400000: native
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\win32u.dll" at 66B00000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 00410000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\USER32.dll" at 6ED00000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\winsxs\\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_deadbeef\\MSVCR90.dll" at 6B300000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at 44560000: builtin
                                  0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\uxtheme.dll" at 68700000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\conhost.exe" at 00400000: builtin
                                  0034:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\uxtheme.dll" : builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\win32u.dll" at 66B00000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 007C0000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 00110000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 6ED00000: builtin
                                  0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
                                  0100:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
                                  0108:trace:loaddll:build_module Loaded L"F:\\Diablo2\\Game.exe" at 00400000: native
                                  0108:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
                                  0108:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
                                  Stopping TiMidity
                                  0108:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
                                  0108:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
                                  0108:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
                                  0108:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
                                  timidity: Kein Prozess gefunden
                                  xinit: connection to X server lost
                                  waiting for X server to shut down xinit: giving up
                                  xinit: unable to connect to X server: Connection refused
                                  xinit: unexpected signal 1
                                  (II) Server terminated successfully (0). Closing log file.
                                  thats the log from this call
                                  #!/bin/bash
                                  startx & qjoypad 'Diablo2' &
                                  WINEDEBUG=+loaddll BOX_LOG=1 WINEDLLOVERRIDES=ddraw=n,b  LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/" setarch linux32 -L /opt/retropie/emulators/wine/bin/wine F:/Diablo2/PlugY.exe -direct -txt
                                  • ectoE
                                    ecto @MumboJumbo
                                    @MumboJumbo Hmmm, strange.
                                    Here are some pointers what you could look for next:
                                    • Have You started your wine diablo2 folder from scratch? Maybe there are some leftovers from a previous installation?
                                    • Have you changed the wine registry for Disblo 2 so it's using the ddraw renderer? Dou you have the ddraw dll override set up?
                                    • Is your desktop resolution 1920x1080? Because that's what my d2hd.ini file is for.
                                    • Do you also have the Lord of Destruction expansion? Idk if that makes a difference.
                                    • Have installed the latest cnc-ddraw library? Mine might be 4.4.6, as the latest release is only 6 days old.
                                    I can't think of anything else atm... Fingers crossed...
                                    Ah no. One other thing: do you have a Windows PC? You might set up everything on that one, try everything if it works and then copy the folder over to the Pi.
                                    • ectoE
                                      ecto @MumboJumbo
                                      @MumboJumbo I can't see much, but there are some errors in the log, I think.
                                      Have a look if there are no more wine processes running. This sometimes happen for me, if a windows exe crashes. This prevents wine from starting correctly.
                                      Also, I always change into the game directory and start the exe from there. Some games just like to have it that way. ;)
                                      EDIT
                                      And I think your .sh file shouldn't´t have startx in it. The wine launcher (Wine Desktop.sh) is already started with the XINIT:flag.
                                      ... ah no. I see now that you're starting directly from the shell, and not using the runcommand.sh, right? That shouldn't be a problem then.
                                        MumboJumbo @ecto
                                        @ecto
                                        Tried again from clean plate. Set the renderer in the registry. Don't know what you mean with desktop resolution my monitor is 1920:1080. i tried virtual destop with 1920:1080 but also fails. Yes its with LOD. Used cnc-ddraw 4.4.6. I also exchanged the startx with matchbox but it never started the game...
                                        I get the impression that there is a pluggy task and when it finished it calls game.exe and closes and this closing causes the quitting but i dont know how to check. Its different when callled vie D2SE.exe (here 1.13c) i think there is a wrap around the processes and it seems like one but thats just a guess
                                        • ectoE
                                          ecto @MumboJumbo
                                          @MumboJumbo I'm definitely starting Diablo 2 from its directory with wine game.exe -txt -direct. I think the -txt -direct options are there to inject the plugy code. I don't really know why it's not working for you.
                                          Maybe you could have a look at your error messages about ALSA. Are thy always there and your sound works otherwise with other games? Or you could start with a whole new wineprefix... Sometimes it helps me to fiddle with another game first and come back later with fresh ideas?
                                          I'm sorry I have no other ideas now. :(
                                            MumboJumbo @ecto
                                            @ecto all good thx a lot for your help. I can run it from D2SE just one click more. But i tried sth different this time i created a new D2SE Mod copying my working one. Then i transferred your changes into my files. I needed to copy some missing files and search for a plugy (11.02) which could manipulate D2gfx(1.13c). Now the game starts via D2SE but I get the same error as before as soon as I open the charaktermenu diablo suddenly quits and i get this error on console:
                                            12143|0x6ab42e3: Unimplemented Opcode (C9) 66 3E 8B 4E 08 51 50 E9
                                            I think i need to uncheck all changes plugy makes to the charactermenu then it will open just like in the working one probably thats because the internal version of plugy(10) in D2SE doesn't know the command.... Hmm can't start plugy without D2SE but D2SE only can do Plugy 10 or so.....
