    Box86 and Wine on RPi4
    box86wineqemux86windows
    475 Posts 40 Posters 237.8k Views
    • H
      h2805270 @mitu
      I really hate it when developers leave their games to rot indefinitely, but still keep a leash over them like they're going to earn any money from it today.
        George
        Thanks anyway @h2805270!
          George
          Hi @Folly and @mth75. Some updates on my end.
          I did a clean install and did a full on apt-get dist-upgrade and updated RetroPie to 4.7.7. I'm testing out modifications to my script to detect what has been installed. Looks like things have gotten simpler and I can just do the following as an example:
          if ! rp_isInstalled "wine" ; then
          I also am experimenting with a couple of lines which detect if a person is running at least RetroPie 4.7.7, since it's pretty much a requirement now that the method for detecting installed script modules has changed. If my scripts get accepted into RetroPie, that won't be necessary, as they'll automatically be part of the later versions.
          I'm installing things and running some tests. So far so good. I'll be on the lookout for audio issues (via Timidity) and performance slow downs. @Folly, thanks for the tip on UAS. I had found out about compatibility issues just a few months ago on my Ubuntu Desktop when I bought a Seagate USB 3.0 hard drive for backup purposes. Makes sense that it might affect Raspberry Pi as well. In my case, the system was spamming the log file with UAS error messages like crazy. You may want to check /var/log/ for a massive log file that gets added to constantly. The toughest part is that it's evidently such a common problem that there are several posts about it on various forums for various Linux based operating systems. So the idea that almost every USB 3.0 hard drive should be UAS compatible is probably a bit of an overstatement. The solution is quite a bit of work as well, considering the issue is fairly common, it would have made sense to simplify it. But I digress.
          I've been playing around with my script modules as "external" script modules. It works rather well! It could definitely be the solution for the ever increasing number of applications people want to cram onto their RetroPie boxes. Of course, I'd like the box86/wine script modules to become part of the RetroPie master repo. :-) I could see this as being a great option for single game ports though! I can see a conflict arising when two different repos have a script module with the same name though. One will be chosen over another. I'll have to submit that feedback somewhere.
          Anyway, if I make any further progress, I'll let you know!
          - George
          F M 2 Replies Last reply Reply Quote 1
          • F
            Folly @George
            @george
            Great to hear you found a solution and that you could use my UAS suggestion ;-)
            I am always testing your script both ways.
            From the terminal so I can see how it would react with an original RetroPie and if the games are in fullscreen.
            I test also in the desktop enviroment.
            What I see here is that wine is always installing mime types for fast opening of files. I you open a file with a wine application it doesn't work(you get sandbox only) and I prefer to use linux programs over wine. So I renamed this file to .bak manually to get rid of this (perhaps an idea to implement) :
            /home/pi/.local/share/applications/mimeinfo.cache.bak
            When you install software you get desktop icons, that is nice, but the desktop icons don't work because they have no good command to load the software in the desktop enviroment. So pehaps there is a way to prefent installing desktop icons on the linux desktop or else, that desktop icons are installed with the correct load command.
            Is this some good feedback for you ?
              mth75 @George
              @george said in Box86 and Wine on RPi4:
              Thx for the update. In the meantime, i'm pumping out wine prefixes :-).
              Which brings me to the other question regarding, how to install games. I think the only solution in a Retropie env. for end users is installing games with winetricks and configuring all opt and config files manual. I don't see another solution.
                mth75 @mth75
                @George I have to start almost all games multiple times before xinit actually starts. I believe this is a well known xinit problem?, is there anything we can do about that?
                  George
                  @Folly and @mth75, I really appreciate all the work you've done to test this out. I love all the feedback. You're making this really solid and people are going to love it! Thank you!
                  @Folly
                  I found this link for disabling Wine from managing MIME types. https://askubuntu.com/questions/323437/how-to-prevent-wine-from-adding-file-associations It can also disable creation of desktop items (I think). I'm not sure that the creation of desktop items could be customized to include the environment variable settings that are required. But it might not be too bad, considering the following on the command line:
                  • WINEDEBUG=-all - potentially can be removed. You'll just see warning messages.
                  • LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/" - Eventually, when Raspberry Pi OS is updated to use the latest Mesa drivers, this can be removed. A short term alternative is to add this to the .profile so it is set 100% of the time, but I don't know what effect that will have on the rest of the system.
                  • setarch linux32 -L - I'm not exactly sure this is needed, since we're already on a 32-bit linux system, but one could experiment with removing it.
                  @mth75
                  I think you might be right about installation of software, though doing all the manual configuration of ports scripts is a pain. I'm still looking at various solutions.
                  Can you edit one of your scripts to add: BOX86_LOG=1 and remove the WINEDEBUG statement, making the line look like this:
                  BOX86_LOG=1 LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/" setarch linux32 -L ...
                  This might help narrow down the issue.
                  Thanks again!
                  - George
                  • F
                    Folly @mth75
                    @mth75 said in Box86 and Wine on RPi4:
                    I have the same problem running Beebem.
                    But with Beebem I have the wine/desktop already open.
                    So I dont think it's an xinit problem.
                      George @Folly
                      Can you use the BOX86_LOG=1 flag and post your log? That will help narrow down where the issue might be. Thanks!
                      - George
                      • F
                        Folly @George
                        - George
                        I tried Beebem 1 time creating this log (Beebem starts and then stops directly):
                        (It boots ok if I press a key and also if I use the fullscreen option in beebem)
                        Parameters:
                        Executing: /opt/retropie/ports/wine/wineexplorer_xinit.sh
                        root window unavailable (maybe another WM is running?)
                        Debug level is 1
                        Dynarec for ARM, with extension: HALF FAST_MULT EDSP NEON VFPv4 IDIVA PageSize:4096
                        Box86 with Dynarec v0.2.0 b2d5587 built on Feb  1 2021 13:10:23
                        BOX86: Wine detected, WINEPRELOADRESERVE=""
                        Using default BOX86_LD_LIBRARY_PATH: ./:lib/:lib32/:x86/
                        Using default BOX86_PATH: ./:bin/
                        Counted 45 Env var
                        Looking for /opt/retropie/ports/wine/bin/wine
                        argv[1]="explorer"
                        argv[2]="/desktop=shell,1600x900"
                        argv[3]="explorer"
                        Using native(wrapped) libpthread.so.0
                        Using native(wrapped) libdl.so.2
                        Using native(wrapped) libc.so.6
                        Using native(wrapped) ld-linux.so.2
                        Using native(wrapped) librt.so.1
                        Using emulated /opt/retropie/ports/wine/bin/../lib/wine/ntdll.so
                        Using native(wrapped) libm.so.6
                        Debug level is 1
                        Counted 46 Env var
                        argv[1]="explorer"
                        argv[3]="explorer"
                        Debug level is 1
                        Counted 46 Env var
                        Looking for /opt/retropie/ports/wine/bin/wineserver
                        Using emulated /opt/retropie/ports/wine/lib/wine/../libwine.so.1
                        0064:err:ole:start_rpcss Failed to start RpcSs service
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/kernel32.so"/0x63d826a0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/kernelbase.so"/0x63dacc08, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/explorer.so"/0x63dbfe50, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/advapi32.so"/0x63ddb3a0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/sechost.so"/0x63ddc758, 2)
                        Using emulated /opt/retropie/ports/wine/lib/wine/ucrtbase.so
                        Using emulated /opt/retropie/ports/wine/lib/wine/gdi32.so
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/rpcrt4.so"/0x63e06a10, 2)
                        Using emulated /opt/retropie/ports/wine/lib/wine/user32.so
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/setupapi.so"/0x63e06a10, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/version.so"/0x63e06a10, 2)
                        Using native(wrapped) libfreetype.so.6
                        Using native(wrapped) libfontconfig.so.1
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/imm32.so"/0x641f7c20, 2)
                        Using emulated /opt/retropie/ports/wine/lib/wine/winex11.drv.so
                        Using native(wrapped) libXext.so.6
                        Using native(wrapped) libX11.so.6
                        Using native(wrapped) libxcb.so.1
                        Using native(wrapped) libXau.so.6
                        Using native(wrapped) libXdmcp.so.6
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winex11.so"/0x6425f590, 2)
                        Using native(wrapped) libXinerama.so.1
                        Using native(wrapped) libXxf86vm.so.1
                        Using native(wrapped) libXrender.so.1
                        Using native(wrapped) libXrandr.so.2
                        Using native(wrapped) libXcomposite.so.1
                        Using native(wrapped) libXi.so.6
                        Using native(wrapped) libXcursor.so.1
                        Using native(wrapped) libvulkan.so.1
                        Warning, function vkGetPhysicalDeviceSurfaceCapabilities2KHR not found in lib libvulkan.so.1
                        Warning, function vkGetPhysicalDeviceSurfaceFormats2KHR not found in lib libvulkan.so.1
                        Using native(wrapped) libpng16.so.16
                        Using emulated /opt/retropie/ports/wine/lib/wine/shell32.dll.so
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shell32.so"/0x64887a68, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shlwapi.so"/0x648dabc0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shcore.so"/0x648db430, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ole32.so"/0x648e31e0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/combase.so"/0x648e31e0, 2)
                        Debug level is 1
                        BOX86: Wine detected, WINEPRELOADRESERVE="000400000-000495000"
                        Counted 48 Env var
                        argv[1]="explorer"
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/kernel32.so"/0x63623c48, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/kernelbase.so"/0x6364e470, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/explorer.so"/0x63661718, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/advapi32.so"/0x6368cae0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/sechost.so"/0x6368de98, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/rpcrt4.so"/0x636b8470, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/setupapi.so"/0x636b8470, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/version.so"/0x636d1188, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/actxprxy.so"/0x429ed920, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/oleaut32.so"/0x429f3710, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/imm32.so"/0x63a96fd0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ole32.so"/0x63ad84b0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/combase.so"/0x63ada3a0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winex11.so"/0x63b5efa0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x63f77978, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/uxtheme.so"/0x63fed478, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/actxprxy.so"/0x6413cee0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/oleaut32.so"/0x64142c58, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shell32.so"/0x643d78e0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shlwapi.so"/0x643ea878, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shcore.so"/0x643eaf08, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/explorerframe.so"/0x646edcc8, 2)
                        00d8:fixme:nstc:NSTC2_fnSetControlStyle2 mask & style (0x00000004) contains unsupported style(s): 0x00000004
                        00d8:fixme:shell:IShellBrowser_fnSendControlMsg stub, 0x4e2ad0 (2, 1026, a003, 0, 0x7af55c)
                        00d8:fixme:shell:IShellBrowser_fnSendControlMsg stub, 0x4e2ad0 (2, 1026, a004, 1, 0x7af55c)
                        00d8:fixme:shell:IShellBrowser_fnSendControlMsg stub, 0x4e2ad0 (2, 1025, a003, 1, 0x7af55c)
                        00d8:fixme:shell:IShellBrowser_fnSendControlMsg stub, 0x4e2ad0 (2, 1025, a004, 1, 0x7af55c)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/appwiz.so"/0x45358a70, 2)
                        Using emulated /opt/retropie/ports/wine/lib/wine/bcrypt.so
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x45358fe0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comdlg32.so"/0x4536ed48, 2)
                        Using emulated /opt/retropie/ports/wine/lib/wine/winspool.drv.so
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winspool.so"/0x4536ed48, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/urlmon.so"/0x4537fbe8, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wininet.so"/0x45382d48, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/mpr.so"/0x45383a88, 2)
                        Using emulated /opt/retropie/ports/wine/lib/wine/ws2_32.dll.so
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ws2_32.so"/0x45383a88, 2)
                        Using native(wrapped) libgnutls.so.30
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/uxtheme.so"/0x45856e88, 2)
                        Using native(wrapped) libcups.so.2
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/bthprops.so"/0x45391358, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/inetcpl.so"/0x458f8a80, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x458f8a80, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/irprops.so"/0x45a9c5e8, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/joy.so"/0x45a90188, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x45a90188, 2)
                        Using emulated /opt/retropie/ports/wine/lib/wine/dinput8.dll.so
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/dinput8.so"/0x45a90188, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/appwiz.so"/0x45d96ce8, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x45d96ce8, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comdlg32.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winspool.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/urlmon.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wininet.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/mpr.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ws2_32.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/bthprops.so"/0x45da15d8, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/inetcpl.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/irprops.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/joy.so"/0x45d9aec0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/dinput8.so"/0x45d9aec0, 2)
                        0024:fixme:shell:ISF_ControlPanel_fnGetDisplayNameOf retrieve display name from control panel app
                        0024:fixme:exec:SHELL_execute flags ignored: 0x00000004
                        0024:fixme:exec:SHELL_execute flags ignored: 0x00004000
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/appwiz.so"/0x45eb4720, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x45eb4720, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comdlg32.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winspool.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/urlmon.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wininet.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/mpr.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ws2_32.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/bthprops.so"/0x45eb9dc8, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/inetcpl.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/irprops.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/joy.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/dinput8.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/appwiz.so"/0x45eb8200, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/bthprops.so"/0x45ec7568, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/irprops.so"/0x45ec75e8, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/appwiz.so"/0x45eb9d88, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x45eb9d88, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comdlg32.so"/0x45eb9d88, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winspool.so"/0x45eb9d88, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/urlmon.so"/0x45eb9d88, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wininet.so"/0x45eb9d88, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/mpr.so"/0x45eb9d88, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ws2_32.so"/0x45eb9d88, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/bthprops.so"/0x45ed4c70, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/inetcpl.so"/0x45ed0850, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x45ed0850, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/irprops.so"/0x45ed4c18, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/joy.so"/0x45ed0850, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/dinput8.so"/0x45ed0850, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/appwiz.so"/0x45ecc7c8, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x45eb9db0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comdlg32.so"/0x45eb9db0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winspool.so"/0x45eb9db0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/urlmon.so"/0x45eb9db0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wininet.so"/0x45eb9db0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/mpr.so"/0x45eb9db0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ws2_32.so"/0x45eb9db0, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/bthprops.so"/0x45ecca80, 2)
                        Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/irprops.so"/0x45edeb50, 2)
                        0158:fixme:d3d:wined3d_guess_card_vendor Received unrecognized GL_VENDOR "Broadcom". Returning HW_VENDOR_NVIDIA.
                        0158:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
                          George @Folly
                          Thanks @folly. Quick question. Are you running a Windows version of Beebem through Wine Explorer?
                          - George
                          • F
                            Folly @George
                            - George
                            Yes I do.
                            Forgot to mention, wine explorer keeps working though.
                              mth75 @Folly
                              @George I updated to:
                              Box86 Master version (latest 0.2.1), Mesa 20.3.4 and Wine v-6.1-devel.
                              I'm fearly sure that this combination gives a noticeable better performance (and more games work).
                              Wine games are running almost 5 degrees Celsius cooler ... Simcity 3000 for instance would throttle my SOC in the Pi4. Not any more.
                              M G 2 Replies Last reply Reply Quote 1
                                mth75 @mth75
                                Who is willing for taking part in a challenge :-) ... getting Thimbleweed Park to work in Wine? My prefix starts in a blackscreen with sound. I believe this is due to (for now) lacking DX12 support in the mesa/vulkan drivers. I also believe that it's a matter of time ...
                                • F
                                  Folly @mth75
                                  Who is willing for taking part in a challenge :-) ... getting Thimbeweed Park to work in Wine? My prefix starts in a blackscreen with sound. I believe this is due to (for now) lacking DX12 support in the mesa/vulkan drivers. I also believe that it's a matter of time ...
                                  Seems you already did much work.
                                  I have no idea on how to get this game working.
                                  Perhaps others ?
                                    George @mth75
                                    @mth75 thanks for the update. I did see Mesa got updated to 20.3.4, but haven't updated my script modules yet. So many moving pieces in this! Are you still experiencing crashes where you have to start the game multiple times before being able to run a game?
                                    Regarding Thimbleweed Park, I've never played it, but the web site says that it's compatible with Linux. Perhaps using a Linux version through Box86 would work better. I don't know the installation process though.
                                    - George
                                      mth75 @George
                                      Yes, still the same behaviour but less frequently. I suspect Box86.
                                      The Linux version is 64bits (sadly) ... so I'm trying my luck with a 32bits GOG Windows version.
                                        mth75 @George
                                        I'm curious if you'll notice any difference. My RPi4 as you know is build in the C= Plus4 case, with a Pimoroni Fanshim which kicks in at 68C. For example, the AGS adventure game Chronicles of Innsmouth always throttled the SOC (T above 80), the difference I now notice is almost 8 degrees C. This means that some component has become a lot more efficient.
                                          George @mth75
                                          It could be Box86, but there are so many things going on and are in early development, like the Mesa Broadcom driver.
                                          Early on in my testing, I saw a problem with one of the games I was testing. Through a ton of debugging, I believe I narrowed down the issue to an ARB vertex program test that Wine passing on to Mesa. I filed a bug with Mesa:
                                          https://gitlab.freedesktop.org/mesa/mesa/-/issues/4018
                                          I may have been able to workaround the issue using the following Mesa override in the command line:
                                          MESA_EXTENSION_OVERRIDE="-GL_ARB_vertex_program"
                                          Perhaps give that a shot and let me know if you see any improvement in reliability. You may of course see a change in performance, either good or bad. Let us know.
                                          - George
                                            mth75 @George
                                            @george Hi George, I didn't notice any difference.
