    Pi Zero USB sound card, setup?
    pi zeroaudiousb audio cardusb audio
    2 Posts 2 Posters 577 Views
      AussieBeefPi
      Hey guys, I am planning on building my first Gameboy Zero and was wondering if I need to do any configurations or setups for the USB sound card to work. Or is it a plug and play device?
      Here is the one I am planning on purchasing: https://www.aliexpress.com/item/32850806730.html?spm=a2g0o.productlist.0.0.f4cc52a1xiO0Kp&algo_pvid=a83831ac-59f9-476a-99e7-64b2fe670125&algo_expid=a83831ac-59f9-476a-99e7-64b2fe670125-2&btsid=0b0a556d16061215002281245e299c&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
        If the sound card is compatible with Linux (should be), then all you need is disable the on-board sound card and it should be automatically used.
        Some details, added over time by various RetroPie users, are in Sound docs.
