    lr-pcsx-rearmed controller not working
    lr-pcsx-rearmedcontroller
    5 Posts 2 Posters 782 Views
    • Y
      yelworC
      Hi there!
      Yesterday i updated lr-pcsx-rearmed via retropie setup to the latest binary. Since then the emulator does no longer react to any button press. I can activate retroarch menu and navigate there with my joypad but inside the emulation there is no controller "plugged in". Some games show a "please insert controller" message.
      This seems only to happen in pcsx and all other emulation cores i tested work fine.
      Before this update all worked fine. :-/
      I am using a Pi 3B+ still running stretch but with all retropie related software updated to current version. Controller is a "iBuffalo" SNES style controller and as i said it works in all other retroarch cores. I know there is L2 and R2 missing on this controller but i don't think thats the point.
      Can someone help mit with this issue?
        Did you also update RetroArch ? What is Pad1 Type set in the Core options ?
        Y 1 Reply Last reply Reply Quote 0
        • Y
          yelworC @mitu
          There was no update available for retroarch and controller type is set to "default"
          I think i fixed the problem by first enabling "Show other input settings" and then switching "Multitap 1" and "Multitap 2" from "Auto" to "Off".
          Is this Multitap thing a new feature? Since i never touched this setting (it was hidden) and the issue was not there before updating.
          mituM 1 Reply Last reply Reply Quote 1
            mitu Global Moderator @yelworC
            Did you update from binary the lr-pcsx-rearmed package ? That is not the most recent version (upstream). It could be that something was fixed and multitap has started working, whereas before that option was ignored.
            • Y
              yelworC @mitu
              @mitu i installed the latest precompiled binary from retropie setup script. but at least everything works now again and i do not even know what to do with this multitap thing.. not a funktion that i am missing now :)
